    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 76.7k Views 9 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Mitch1138
      @Mitch1138 as a hint, check how other modules update their content.
      • Mitch1138M Offline
        Mitch1138
        Thanks for the tip, but I didn’t have a lot of success. I punted and installed Auto Refresh Plus extension in Chrome. Running in server mode I can use this to refresh the page on a predefined time cycle.
          roramirez Core Contributors
          Is more easy than that. Check out the function and use of scheduleUpdate function.
          https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js
          Is of currentweather module.
          • michael24hM Offline
            michael24h
            hello
            I also heve problem with iframer. This is what put in my config. but can’t make auto play with adding -->&autoplay=1
            			module: 'iFrame',
            			position: 'bottom_left', // This can be any of the regions.
                            url:  src="https://www.youtube.com/embed/I7hV-5GHWhc",
                            width: '360px', // Optional. Default: 100%
                            height: '360px', //Optional. Default: 100px
              michael24h
              @roramirez said in Display web widget on mirror through iFrame?:
              &autoplay=1
              Anyone
                michael24h
                already resolved the problem, replace “&” with “?” in the url the video.
                • L Offline
                  looolz
                  same problem, still not working. Loading the module breaks the file. Here is my code:
                          module: 'iFrame',
                          position: 'bottom_bar', // This can be any of the regions.
                                  url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png"
                                  width: "828px" // Optional. Default: 100%
                                  height: "272px" //Optional. Default: 100px
                  The only detail I’ve found in the documentation that seems a little off, is that it suggests the URL formatting to be as such:
                  url: "http:http://example.com/"
                  But that still doesn’t work.
                    michael24h
                    @looolz said in Display web widget on mirror through iFrame?:
                    this one work on my clock
                    module: ‘iFrame’,
                    position: ‘bottom_left’, // This can be any of the regions.
                    // See ‘Configuration options’ for more information.
                    url: “http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png”,
                    width: ‘220%’, // Optional. Default: 100%
                    height: ‘360px’, //Optional. Default: 100px
                      michael24h
                                  url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png",
                      • L Offline
                        looolz @michael24h
                        @michael24h aaaaaaaah!
                        Yes! That worked, thanks!
                          michael24h
                          no worries
                          • L Offline
                            looolz @michael24h
                            @michael24h By the way, the example config from the readme.md also lacks the comma.
                              michael24h
                              Usual thing good use to
                              • F Offline
                                fox
                                Does the page i want to embedd should meet minimum requirements?
                                I checked here: https://validator.w3.org/#validate_by_input and no problems found. But iFrame-module does not show the page
                                Issues With MMM-WatchDog known?
                                https://forum.magicmirror.builders/post/29827
                                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                michael24hM 1 Reply Last reply Reply Quote 0
                                  michael24h @fox
                                  @fox
                                  can you post config
                                  • F Offline
                                    fox @michael24h
                                    @michael24h
                                                            module: "MMM-iFrameReload",
                                                            header: "",
        url: "http://192.168.188.30/indexsmall.html",
        width: "100%",
        height: "150px"
                                    page:
                                    http://pastebin.com/KjhxUpYZ
                                      michael24h
                                      will do if you do:
                                      open frame in new tab
                                      and then paste in:
                                      url:src=“http://cdnx.tribalfusion.com/media/6869616/assets/tab2/tab2.html”,
                                        michael24h
                                        Or
                                        http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4
                                        if you like this one :-)
                                          michael24h
                                          @fox said in Display web widget on mirror through iFrame?:
                                          url: “http://192.168.188.30/indexsmall.html”,
                                          this won’t work url: “http://192.168.188.30/indexsmall.html”,
                                          only way :
                                          ->index or home.html
                                          • F Offline
                                            fox
                                            @michael24h said in Display web widget on mirror through iFrame?:
                                            You mean that i change my config of iFrame with your URL?
                                            like this?
        header: "",
        url: "http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4",
        width: "100%",
        height: "150px"
                                            • 2 / 3
