    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 78.2k Views 9 Watching
      roramirez Core Contributors
      Well, autoplay is a option of Youtube,
      Add autoplay=1 to url
      https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF&autoplay=1
      • E
        eugekiller
        Thank You Guys worked like a charm. :)
        • K
          kasperb @yawns
          @yawns Great, thanks so much, it’s working now :-)
          • Mitch1138M
            Mitch1138
            I am able to get iFrame to display a widget and it works well, the the widget is not updated. Is there a way to force an update every 15 min or so?
            Thanks, Mitch
            R 1 Reply Last reply
              roramirez Core Contributors @Mitch1138
              @Mitch1138 There no way to force update using iFrame. Its a something is possible add a option for autorefresh. I think will not difficult added. Why do you no try?
              • Mitch1138M
                Mitch1138
                Thanks, I like your confidence in my abilities! I will keep working on trying to find a way to update the link.
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Mitch1138
                  @Mitch1138 as a hint, check how other modules update their content.
                  • Mitch1138M
                    Mitch1138
                    Thanks for the tip, but I didn’t have a lot of success. I punted and installed Auto Refresh Plus extension in Chrome. Running in server mode I can use this to refresh the page on a predefined time cycle.
                      Is more easy than that. Check out the function and use of scheduleUpdate function.
                      https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js
                      Is of currentweather module.
                      • michael24hM
                        michael24h
                        hello
                        I also heve problem with iframer. This is what put in my config. but can’t make auto play with adding -->&autoplay=1
                        			module: 'iFrame',
                        			position: 'bottom_left', // This can be any of the regions.
                                        url:  src="https://www.youtube.com/embed/I7hV-5GHWhc",
                                        width: '360px', // Optional. Default: 100%
                                        height: '360px', //Optional. Default: 100px
                        • michael24hM
                          michael24h
                          @roramirez said in Display web widget on mirror through iFrame?:
                          &autoplay=1
                          Anyone
                          • michael24hM
                            michael24h
                            already resolved the problem, replace “&” with “?” in the url the video.
                            • L
                              looolz
                              same problem, still not working. Loading the module breaks the file. Here is my code:
                                      module: 'iFrame',
                                      position: 'bottom_bar', // This can be any of the regions.
                                              url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png"
                                              width: "828px" // Optional. Default: 100%
                                              height: "272px" //Optional. Default: 100px
                              The only detail I’ve found in the documentation that seems a little off, is that it suggests the URL formatting to be as such:
                              url: "http:http://example.com/"
                              But that still doesn’t work.
                              • michael24hM
                                michael24h
                                @looolz said in Display web widget on mirror through iFrame?:
                                this one work on my clock
                                module: ‘iFrame’,
                                position: ‘bottom_left’, // This can be any of the regions.
                                // See ‘Configuration options’ for more information.
                                url: “http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png”,
                                width: ‘220%’, // Optional. Default: 100%
                                height: ‘360px’, //Optional. Default: 100px
                                • michael24hM
                                  michael24h
                                              url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png",
                                  L 1 Reply Last reply
                                  • L
                                    looolz @michael24h
                                    @michael24h aaaaaaaah!
                                    Yes! That worked, thanks!
                                    • michael24hM
                                      michael24h
                                      no worries
                                      • L
                                        looolz @michael24h
                                        @michael24h By the way, the example config from the readme.md also lacks the comma.
                                        • michael24hM
                                          michael24h
                                          Usual thing good use to
                                          • foxF
                                            fox
                                            Does the page i want to embedd should meet minimum requirements?
                                            I checked here: https://validator.w3.org/#validate_by_input and no problems found. But iFrame-module does not show the page
                                            Issues With MMM-WatchDog known?
                                            https://forum.magicmirror.builders/post/29827
                                            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                            michael24hM 1 Reply Last reply
