    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 77.7k Views 9 Watching
      roramirez Core Contributors
      Why dont use the URL http://service.mta.info/ServiceStatus/status.html?widget=yes into module https://github.com/desertblade/iFrame ?
      K 1 Reply Last reply
      • K
        kasperb @roramirez
        @roramirez I tried that, but for some reason I can’t get the iFrame module to work. When I enter the code from the instructions/readme in the config.js it breaks the file (I wish I could post it here, but I just broke my micro sd when putting the RPI in a case :-I)
        • E
          eugekiller
          Hi I am also having the same problem. I am trying to load a youtube playlist to iFrame. I cloned iFrame in to modules, then navigated in to it did npm install. Then put this in config.js
          var config = {
          port: 8080,
          language: 'en',
          timeFormat: 12,
          units: 'imperial',
          		module: 'alert',
          		module: 'clock',
          		position: 'top_right'
          		module: 'currentweather',
          		position: 'top_left',
          			locationID: '',  //ID from http://www.openweathermap.org
          			appid: '2159d1e91ad638a2b6face1e0cc76bce'
          		module: 'weatherforecast',
          		header: 'Weather Forecast',
          			locationID: '5105455',  //ID from http://www.openweathermap.org
          		module: 'calendar',
          		header: 'Oksanas Calendar',
          					symbol: 'calendar-check-o ',
          					url: 'NONE'
          		module: 'calendar',
          		header: 'TYLER JOBS',
          		position: 'top_right',
          					url: 'NONE'
          		module: 'calendar',
          		header: 'SHANE JOBS',
          					url: 'NONE'
          module: 'MMM-Traffic',
          header: 'OFFICE DRIVE',
          position: 'bottom_right',
          classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
              api_key: 'NONE',
              mode: 'driving',
              origin: '43 Madison St, Pequannock Township, NJ 07440',
              destination: '99 Dell Glen Avenue, Lodi, NJ 0764',
              arrival_time: '', //optional, but needs to be in 24 hour time if used.
              route_name: 'Home to Work',
              changeColor: true,
              showGreen: false,
              limitYellow: 5, //Greater than 5% of journey time due to traffic
              limitRed: 20, //Greater than 20% of journey time due to traffic
              traffic_model: 'pessimistic',
              interval: 120000 //2 minutes
          header: 'Oksana Russian Office',
          position: 'bottom_left',
              api_key: 'NONE',
              mode: 'driving',
              destination: '45 U.S. 46, Ridgefield Park, NJ 07660',
              changeColor: true,
              showGreen: false,
              module: 'iFrame',
              position: 'bottom_bar', // This can be any of the regions.
                      url: "<iframe width="560" height="315" src="https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF" frameborder="0" allowfullscreen></iframe>"
                      width: "50px" // Optional. Default: 100%
                      height: "50px" //Optional. Default: 100px
          		module: 'newsfeed',
          		position: 'top_bar',
          			feeds: [
          					title: "NEWS 12",
          					url: "http://newjersey.news12.com/cmlink/1.4124770#"
          			showSourceTitle: true,
          			showPublishDate: true
          • Y
            yawns Moderator
            I see several formatting errors (missing , and too many } ). I did not test it, but please try this instead. Oh, and please remove your api keys and your personal calendar urls before posting the config file on the internet :)
            	module: 'iFrame',
            		url: "https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF",
            		width: "50px", // Optional. Default: 100%
            		height: "50px", //Optional. Default: 100px
            E K 2 Replies Last reply
              @kasperb @eugekiller as said @yawns, you need config only the URL not html code for iframe tag.
              • E
                eugekiller @yawns
                @yawns said in Display web widget on mirror through iFrame?:
                module: ‘iFrame’,
                position: ‘bottom_bar’, // This can be any of the regions.
                // See ‘Configuration options’ for more information.
                url: “https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF”,
                width: “50px”, // Optional. Default: 100%
                height: “50px”, //Optional. Default: 100px
                Thanks that did it :). But one question any way to make it auto play?
                Right now it loads it but i have to use the mouse to hit play on it.
                  Well, autoplay is a option of Youtube,
                  Add autoplay=1 to url
                  https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF&autoplay=1
                  • E
                    eugekiller
                    Thank You Guys worked like a charm. :)
                    • K
                      kasperb @yawns
                      @yawns Great, thanks so much, it’s working now :-)
                      • Mitch1138M
                        Mitch1138
                        I am able to get iFrame to display a widget and it works well, the the widget is not updated. Is there a way to force an update every 15 min or so?
                        Thanks, Mitch
                        R 1 Reply Last reply
                          roramirez Core Contributors @Mitch1138
                          @Mitch1138 There no way to force update using iFrame. Its a something is possible add a option for autorefresh. I think will not difficult added. Why do you no try?
                          • Mitch1138M
                            Mitch1138
                            Thanks, I like your confidence in my abilities! I will keep working on trying to find a way to update the link.
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @Mitch1138
                              @Mitch1138 as a hint, check how other modules update their content.
                              • Mitch1138M
                                Mitch1138
                                Thanks for the tip, but I didn’t have a lot of success. I punted and installed Auto Refresh Plus extension in Chrome. Running in server mode I can use this to refresh the page on a predefined time cycle.
                                  Is more easy than that. Check out the function and use of scheduleUpdate function.
                                  https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js
                                  Is of currentweather module.
                                  • michael24hM
                                    michael24h
                                    hello
                                    I also heve problem with iframer. This is what put in my config. but can’t make auto play with adding -->&autoplay=1
                                    			module: 'iFrame',
                                    			position: 'bottom_left', // This can be any of the regions.
                                                    url:  src="https://www.youtube.com/embed/I7hV-5GHWhc",
                                                    width: '360px', // Optional. Default: 100%
                                                    height: '360px', //Optional. Default: 100px
                                    • michael24hM
                                      michael24h
                                      @roramirez said in Display web widget on mirror through iFrame?:
                                      &autoplay=1
                                      Anyone
                                      • michael24hM
                                        michael24h
                                        already resolved the problem, replace “&” with “?” in the url the video.
                                        • L
                                          looolz
                                          same problem, still not working. Loading the module breaks the file. Here is my code:
                                                  module: 'iFrame',
                                                          url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png"
                                                          width: "828px" // Optional. Default: 100%
                                                          height: "272px" //Optional. Default: 100px
                                          The only detail I’ve found in the documentation that seems a little off, is that it suggests the URL formatting to be as such:
                                          url: "http:http://example.com/"
                                          But that still doesn’t work.
                                          • michael24hM
                                            michael24h
                                            @looolz said in Display web widget on mirror through iFrame?:
                                            this one work on my clock
                                            module: ‘iFrame’,
                                            position: ‘bottom_left’, // This can be any of the regions.
                                            url: “http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png”,
                                            width: ‘220%’, // Optional. Default: 100%
                                            height: ‘360px’, //Optional. Default: 100px
