    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 77.7k Views 9 Watching
    • E
      eugekiller
      Hi I am also having the same problem. I am trying to load a youtube playlist to iFrame. I cloned iFrame in to modules, then navigated in to it did npm install. Then put this in config.js
      var config = {
      port: 8080,
      language: 'en',
      timeFormat: 12,
      units: 'imperial',
      		module: 'alert',
      		module: 'clock',
      		position: 'top_right'
      		module: 'currentweather',
      		position: 'top_left',
      			locationID: '',  //ID from http://www.openweathermap.org
      			appid: '2159d1e91ad638a2b6face1e0cc76bce'
      		module: 'weatherforecast',
      		header: 'Weather Forecast',
      			locationID: '5105455',  //ID from http://www.openweathermap.org
      		module: 'calendar',
      		header: 'Oksanas Calendar',
      					symbol: 'calendar-check-o ',
      					url: 'NONE'
      		module: 'calendar',
      		header: 'TYLER JOBS',
      		position: 'top_right',
      					url: 'NONE'
      		module: 'calendar',
      		header: 'SHANE JOBS',
      					url: 'NONE'
      module: 'MMM-Traffic',
      header: 'OFFICE DRIVE',
      position: 'bottom_right',
      classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
          api_key: 'NONE',
          mode: 'driving',
          origin: '43 Madison St, Pequannock Township, NJ 07440',
          destination: '99 Dell Glen Avenue, Lodi, NJ 0764',
          arrival_time: '', //optional, but needs to be in 24 hour time if used.
          route_name: 'Home to Work',
          changeColor: true,
          showGreen: false,
          limitYellow: 5, //Greater than 5% of journey time due to traffic
          limitRed: 20, //Greater than 20% of journey time due to traffic
          traffic_model: 'pessimistic',
          interval: 120000 //2 minutes
      header: 'Oksana Russian Office',
      position: 'bottom_left',
          api_key: 'NONE',
          mode: 'driving',
          destination: '45 U.S. 46, Ridgefield Park, NJ 07660',
          changeColor: true,
          showGreen: false,
          module: 'iFrame',
          position: 'bottom_bar', // This can be any of the regions.
                  url: "<iframe width="560" height="315" src="https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF" frameborder="0" allowfullscreen></iframe>"
                  width: "50px" // Optional. Default: 100%
                  height: "50px" //Optional. Default: 100px
      		module: 'newsfeed',
      		position: 'top_bar',
      			feeds: [
      					title: "NEWS 12",
      					url: "http://newjersey.news12.com/cmlink/1.4124770#"
      			showSourceTitle: true,
      			showPublishDate: true
      • Y
        yawns Moderator
        I see several formatting errors (missing , and too many } ). I did not test it, but please try this instead. Oh, and please remove your api keys and your personal calendar urls before posting the config file on the internet :)
        	module: 'iFrame',
        		url: "https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF",
        		width: "50px", // Optional. Default: 100%
        		height: "50px", //Optional. Default: 100px
        E K 2 Replies Last reply
          roramirez Core Contributors
          @kasperb @eugekiller as said @yawns, you need config only the URL not html code for iframe tag.
          • E
            eugekiller @yawns
            @yawns said in Display web widget on mirror through iFrame?:
            module: ‘iFrame’,
            position: ‘bottom_bar’, // This can be any of the regions.
            // See ‘Configuration options’ for more information.
            url: “https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF”,
            width: “50px”, // Optional. Default: 100%
            height: “50px”, //Optional. Default: 100px
            Thanks that did it :). But one question any way to make it auto play?
            Right now it loads it but i have to use the mouse to hit play on it.
              Well, autoplay is a option of Youtube,
              Add autoplay=1 to url
              https://www.youtube.com/embed/6kgH6kqNuWM?list=PL24DEF584E7DBB4CF&autoplay=1
              • E
                eugekiller
                Thank You Guys worked like a charm. :)
                • K
                  kasperb @yawns
                  @yawns Great, thanks so much, it’s working now :-)
                  • Mitch1138M
                    Mitch1138
                    I am able to get iFrame to display a widget and it works well, the the widget is not updated. Is there a way to force an update every 15 min or so?
                    Thanks, Mitch
                    R 1 Reply Last reply
                      roramirez Core Contributors @Mitch1138
                      @Mitch1138 There no way to force update using iFrame. Its a something is possible add a option for autorefresh. I think will not difficult added. Why do you no try?
                      • Mitch1138M
                        Mitch1138
                        Thanks, I like your confidence in my abilities! I will keep working on trying to find a way to update the link.
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @Mitch1138
                          @Mitch1138 as a hint, check how other modules update their content.
                          • Mitch1138M
                            Mitch1138
                            Thanks for the tip, but I didn’t have a lot of success. I punted and installed Auto Refresh Plus extension in Chrome. Running in server mode I can use this to refresh the page on a predefined time cycle.
                              Is more easy than that. Check out the function and use of scheduleUpdate function.
                              https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js
                              Is of currentweather module.
                              • michael24hM
                                michael24h
                                hello
                                I also heve problem with iframer. This is what put in my config. but can’t make auto play with adding -->&autoplay=1
                                			module: 'iFrame',
                                			position: 'bottom_left', // This can be any of the regions.
                                                url:  src="https://www.youtube.com/embed/I7hV-5GHWhc",
                                                width: '360px', // Optional. Default: 100%
                                                height: '360px', //Optional. Default: 100px
                                • michael24hM
                                  michael24h
                                  @roramirez said in Display web widget on mirror through iFrame?:
                                  &autoplay=1
                                  Anyone
                                  • michael24hM
                                    michael24h
                                    already resolved the problem, replace “&” with “?” in the url the video.
                                    • L
                                      looolz
                                      same problem, still not working. Loading the module breaks the file. Here is my code:
                                              module: 'iFrame',
                                                      url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png"
                                                      width: "828px" // Optional. Default: 100%
                                                      height: "272px" //Optional. Default: 100px
                                      The only detail I’ve found in the documentation that seems a little off, is that it suggests the URL formatting to be as such:
                                      url: "http:http://example.com/"
                                      But that still doesn’t work.
                                      • michael24hM
                                        michael24h
                                        @looolz said in Display web widget on mirror through iFrame?:
                                        this one work on my clock
                                        module: ‘iFrame’,
                                        position: ‘bottom_left’, // This can be any of the regions.
                                        url: “http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png”,
                                        width: ‘220%’, // Optional. Default: 100%
                                        height: ‘360px’, //Optional. Default: 100px
                                        • michael24hM
                                          michael24h
                                                      url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png",
                                          L 1 Reply Last reply
                                          • L
                                            looolz @michael24h
                                            @michael24h aaaaaaaah!
                                            Yes! That worked, thanks!
