    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 77.7k Views 9 Watching
    • michael24hM
      michael24h
      @fox said in Display web widget on mirror through iFrame?:
      http://poolpi/home.html
      Because this address http://poolpi/home.html don’t exist.
      you pooling public domain ->poolpi
      you basically telling MM to pull public domain which this is address -> http://poolpi/home.html
      but in local network need be local address
      ->http://192.168.0.12/photo/#!Albums
      • michael24hM
        michael24h
        if I’m go to my documents and create folder called 5html. and in this folder paste my tample home.html. and then open on thisame pc or mac computer using web browser will work ok.
        but from another machine won’t open, because I’m not sharing this doc on my local network
        • F
          fox
          I changed it to the local ip:
          alt text
          also the config
                                  module: "MMM-iFrameReload",
                                  header: "",
                                          url: "http://192.168.188.30/home.html",
                                          width: "100%",
                                          height: "100%px"
          then restarted mm but still nothing :(
          alt text
          Despite, thank you very much @michael24h that you help me in such details :)
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          • michael24hM
            michael24h
            can you open this html doc from anather machine ? in local network
            if not you not sharing this document called .html in local net
            • michael24hM
              michael24h
              next
              next
              • F
                fox @michael24h
                @michael24h said in Display web widget on mirror through iFrame?:
                Now i have created also a folder “pool” and point to the folder (file is now index.html) and the config points only to the folder. but also no effect.
                alt text
                Also checked with another computer in same network, the PC shows the page… Only mm, respective the MMM-iFrame module does not show the content
                • F
                  fox
                  I also copied the html file to the Magic-Mirror-Raspi:
                  http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html
                                          header: "",
                                                  url: "http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html",
                                                  width: "100%",
                                                  height: "100%px"
                  Also no effect
                  • michael24hM
                    michael24h
                    I’m not to sure what is the problem.
                    I share page html form my mac to local network
                    page called cookie-policy.html
                    place in iframe
                    Just wanted ask have you tried with another page. youtube or anything ?
                    • michael24hM
                      michael24h
                      url: “http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html”,
                      See if this works
                      http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4
                      • F
                        fox
                        @michael24h
                        I got it… really weird:
                        This works: https://github.com/desertblade/iFrame
                        This does not work: https://github.com/TheBogueRat/MMM-iFrameReload
                        alt text
                        I checke the posts in this tread and i saw that you are using iFrame instead of iFrameReload :)
                        Now i must update this but i will likely do this with shedule updater. Thank you michael
                        • michael24hM
                          michael24h
                          Actually I Didn’t know there two different iframe modules.
                          I’m glad you work out this
                          • F
                            fox @michael24h
                            I think the diffference is, that the Reload-module can update the content.
                            Thank you :)
                            • michael24hM
                              michael24h
                              I didn’t help much. but thanks
                              • michael24hM
                                michael24h
                                Hi I did think about iframe iFrameReload.
                                and works very good. no problem so far…
                                html doc going too
                                MagicMirror/modules/MMM-iFrameReload
                                module: ‘MMM-iFrameReload’,
                                header:‘Traffic Map’,
                                position: ‘bottom_left’, // This can be any of the regions.
                                url: “http://localhost:8080/modules/MMM-iFrameReload/anyname.html”,
                                width: “380px”,
                                height: “400px”,
                                refreshInterval: 800
                                • michael24hM
                                  michael24h
                                  this will help you with traffic map for example
                                  https://support.google.com/maps/answer/18539?co=GENIE.Platform%3DDesktop&hl=en
                                  • Mitch1138M
                                    Mitch1138
                                    There are some comments on the github section for TheBogueRat-MMM-iFrameReload that it will not refresh with some url’s. I have a similar problem. Some suggested appending the current time/date to the url but this gives an invalid url. Has anyone got this to work? My config is:
                                    module: 'MMM-iFrameReload',
                                    position: 'top_center', // This can be any of the regions.
                                                url: "http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland",
                                                width: "100%", // Optional. Default: 400px
                                                height: "450px", // Optional. Default: 800px
                                                refreshInterval: 1800  //Optional. Default: 3600 = 1 hour
                                    Many thanks.
                                    • 3 / 3
