    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 75.8k Views 9 Watching
    • michael24hM Offline
      michael24h @fox
      @fox
      I share on my local net. photo album
      http://192.168.0.12/photo/#!Albums!0_1489511516394_Screen Shot 2017-03-14 at 17.09.56.png
      • F Offline
        fox @michael24h
        @michael24h said in Display web widget on mirror through iFrame?:
        @fox
        Ok i understand. But why is it not working on my screen :(
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          michael24h
          @fox said in Display web widget on mirror through iFrame?:
          http://poolpi/home.html
          Because this address http://poolpi/home.html don’t exist.
          you pooling public domain ->poolpi
          you basically telling MM to pull public domain which this is address -> http://poolpi/home.html
          but in local network need be local address
          ->http://192.168.0.12/photo/#!Albums
            michael24h
            if I’m go to my documents and create folder called 5html. and in this folder paste my tample home.html. and then open on thisame pc or mac computer using web browser will work ok.
            but from another machine won’t open, because I’m not sharing this doc on my local network
            • F Offline
              fox
              I changed it to the local ip:
              alt text
              also the config
                                      module: "MMM-iFrameReload",
                                      header: "",
                                              url: "http://192.168.188.30/home.html",
                                              width: "100%",
                                              height: "100%px"
              then restarted mm but still nothing :(
              alt text
              Despite, thank you very much @michael24h that you help me in such details :)
                michael24h
                can you open this html doc from anather machine ? in local network
                if not you not sharing this document called .html in local net
                  michael24h
                  next
                  next
                  • F Offline
                    fox @michael24h
                    Now i have created also a folder “pool” and point to the folder (file is now index.html) and the config points only to the folder. but also no effect.
                    alt text
                    Also checked with another computer in same network, the PC shows the page… Only mm, respective the MMM-iFrame module does not show the content
                    • F Offline
                      fox
                      I also copied the html file to the Magic-Mirror-Raspi:
                      http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html
                                              header: "",
                                                      url: "http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html",
                                                      width: "100%",
                                                      height: "100%px"
                      Also no effect
                        michael24h
                        I’m not to sure what is the problem.
                        I share page html form my mac to local network
                        page called cookie-policy.html
                        place in iframe
                        Just wanted ask have you tried with another page. youtube or anything ?
                          michael24h
                          url: “http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html”,
                          See if this works
                          http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4
                          • F Offline
                            fox
                            @michael24h
                            I got it… really weird:
                            This works: https://github.com/desertblade/iFrame
                            This does not work: https://github.com/TheBogueRat/MMM-iFrameReload
                            alt text
                            I checke the posts in this tread and i saw that you are using iFrame instead of iFrameReload :)
                            Now i must update this but i will likely do this with shedule updater. Thank you michael
                              michael24h
                              Actually I Didn’t know there two different iframe modules.
                              I’m glad you work out this
                              • F Offline
                                fox @michael24h
                                I think the diffference is, that the Reload-module can update the content.
                                Thank you :)
                                  michael24h
                                  I didn’t help much. but thanks
                                    michael24h
                                    Hi I did think about iframe iFrameReload.
                                    and works very good. no problem so far…
                                    html doc going too
                                    MagicMirror/modules/MMM-iFrameReload
                                    module: ‘MMM-iFrameReload’,
                                    header:‘Traffic Map’,
                                    position: ‘bottom_left’, // This can be any of the regions.
                                    url: “http://localhost:8080/modules/MMM-iFrameReload/anyname.html”,
                                    width: “380px”,
                                    height: “400px”,
                                    refreshInterval: 800
                                      michael24h
                                      this will help you with traffic map for example
                                      https://support.google.com/maps/answer/18539?co=GENIE.Platform%3DDesktop&hl=en
                                      • Mitch1138M Offline
                                        Mitch1138
                                        There are some comments on the github section for TheBogueRat-MMM-iFrameReload that it will not refresh with some url’s. I have a similar problem. Some suggested appending the current time/date to the url but this gives an invalid url. Has anyone got this to work? My config is:
                                        module: 'MMM-iFrameReload',
                                        position: 'top_center', // This can be any of the regions.
                                                    url: "http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland",
                                                    width: "100%", // Optional. Default: 400px
                                                    height: "450px", // Optional. Default: 800px
                                                    refreshInterval: 1800  //Optional. Default: 3600 = 1 hour
                                        Many thanks.
                                        • 3 / 3
