    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 77.7k Views 9 Watching
    • F
      fox
      Here is the output of home.html:
      alt text
      alt text
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      michael24hM 1 Reply Last reply Reply Quote 0
      • michael24hM
        michael24h @fox
        @fox
        I share on my local net. photo album
        http://192.168.0.12/photo/#!Albums!0_1489511516394_Screen Shot 2017-03-14 at 17.09.56.png
        • F
          fox @michael24h
          @michael24h said in Display web widget on mirror through iFrame?:
          @fox
          Ok i understand. But why is it not working on my screen :(
          • michael24hM
            michael24h
            @fox said in Display web widget on mirror through iFrame?:
            http://poolpi/home.html
            Because this address http://poolpi/home.html don’t exist.
            you pooling public domain ->poolpi
            you basically telling MM to pull public domain which this is address -> http://poolpi/home.html
            but in local network need be local address
            ->http://192.168.0.12/photo/#!Albums
            • michael24hM
              michael24h
              if I’m go to my documents and create folder called 5html. and in this folder paste my tample home.html. and then open on thisame pc or mac computer using web browser will work ok.
              but from another machine won’t open, because I’m not sharing this doc on my local network
              • F
                fox
                I changed it to the local ip:
                alt text
                also the config
                                        module: "MMM-iFrameReload",
                                        header: "",
                                                url: "http://192.168.188.30/home.html",
                                                width: "100%",
                                                height: "100%px"
                then restarted mm but still nothing :(
                alt text
                Despite, thank you very much @michael24h that you help me in such details :)
                • michael24hM
                  michael24h
                  can you open this html doc from anather machine ? in local network
                  if not you not sharing this document called .html in local net
                  • michael24hM
                    michael24h
                    next
                    next
                    • F
                      fox @michael24h
                      Now i have created also a folder “pool” and point to the folder (file is now index.html) and the config points only to the folder. but also no effect.
                      alt text
                      Also checked with another computer in same network, the PC shows the page… Only mm, respective the MMM-iFrame module does not show the content
                      • F
                        fox
                        I also copied the html file to the Magic-Mirror-Raspi:
                        http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html
                                                header: "",
                                                        url: "http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html",
                                                        width: "100%",
                                                        height: "100%px"
                        Also no effect
                        • michael24hM
                          michael24h
                          I’m not to sure what is the problem.
                          I share page html form my mac to local network
                          page called cookie-policy.html
                          place in iframe
                          Just wanted ask have you tried with another page. youtube or anything ?
                          • michael24hM
                            michael24h
                            url: “http://192.168.188.25:8080/modules/MMM-iFrameReload/index.html”,
                            See if this works
                            http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4
                            • F
                              fox
                              @michael24h
                              I got it… really weird:
                              This works: https://github.com/desertblade/iFrame
                              This does not work: https://github.com/TheBogueRat/MMM-iFrameReload
                              alt text
                              I checke the posts in this tread and i saw that you are using iFrame instead of iFrameReload :)
                              Now i must update this but i will likely do this with shedule updater. Thank you michael
                              • michael24hM
                                michael24h
                                Actually I Didn’t know there two different iframe modules.
                                I’m glad you work out this
                                • F
                                  fox @michael24h
                                  I think the diffference is, that the Reload-module can update the content.
                                  Thank you :)
                                  • michael24hM
                                    michael24h
                                    I didn’t help much. but thanks
                                    • michael24hM
                                      michael24h
                                      Hi I did think about iframe iFrameReload.
                                      and works very good. no problem so far…
                                      html doc going too
                                      MagicMirror/modules/MMM-iFrameReload
                                      module: ‘MMM-iFrameReload’,
                                      header:‘Traffic Map’,
                                      position: ‘bottom_left’, // This can be any of the regions.
                                      url: “http://localhost:8080/modules/MMM-iFrameReload/anyname.html”,
                                      width: “380px”,
                                      height: “400px”,
                                      refreshInterval: 800
                                      • michael24hM
                                        michael24h
                                        this will help you with traffic map for example
                                        https://support.google.com/maps/answer/18539?co=GENIE.Platform%3DDesktop&hl=en
                                        • Mitch1138M
                                          Mitch1138
                                          There are some comments on the github section for TheBogueRat-MMM-iFrameReload that it will not refresh with some url’s. I have a similar problem. Some suggested appending the current time/date to the url but this gives an invalid url. Has anyone got this to work? My config is:
                                          module: 'MMM-iFrameReload',
                                          position: 'top_center', // This can be any of the regions.
                                                      url: "http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland",
                                                      width: "100%", // Optional. Default: 400px
                                                      height: "450px", // Optional. Default: 800px
                                                      refreshInterval: 1800  //Optional. Default: 3600 = 1 hour
                                          Many thanks.
                                          • 3 / 3
