    AM/PM times shown even with timeFormat: 24,
    6 Posts 4 Posters 4.0k Views 4 Watching
    • L Offline
      looolz
      Figured it out. In the config.js file, I had to put
          language: 'nb',
      I had:
          language: 'en',
      and tried, (but didn’t work) with:
          language: 'no',
        aitoribanez
        First message/response on the forum. I start using and reading code some weeks ago and I want to give thanks to all contributor of MM. :-)
        The translations files of MM are under translate folder: https://github.com/MichMich/MagicMirror/tree/master/translations. I think that Norwegian is on nn.json so try with “nn” on config file.
          roramirez Core Contributors
          said in AM/PM times shown even with timeFormat: 24,:
          Is there a separate secret spot I can choose 24 hour times to affect all other modules?
          The format time for default modules can be set in timeFormat configuration.
          https://github.com/MichMich/MagicMirror#configuration
            Richard238
            Same issue here, config is set to 24, yet calendar shows 10:35pm.
            Google calendar shows 22:35, why is MM showing PM rather than 24hr?
            Thank you.
              roramirez Core Contributors @Richard238
              @Richard238 Is a knowed issue
              https://github.com/MichMich/MagicMirror/issues/776
              If you can help with that go ahead with a Pull Request.
