    AM/PM times shown even with timeFormat: 24,
    6 Posts 4 Posters 4.2k Views 4 Watching
    • L Offline
      looolz
      Fresh install of Raspbian, with MagicMirror working. The default clock module shows a 24 hour clock, but the calendar module, and other third party modules (MMM-Ruter) that show times for public transport show times with AM/PM (which I don’t want).
      -I’ve set the locale and timezone on Raspbian to Norwegian.
      -I’ve checked that I can make the default clock change to a 12 hour AM/PM clock with the config.js file.
      Is there a separate secret spot I can choose 24 hour times to affect all other modules?
      • L Offline
        looolz
        Figured it out. In the config.js file, I had to put
            language: 'nb',
        I had:
            language: 'en',
        and tried, (but didn’t work) with:
            language: 'no',
          aitoribanez
          First message/response on the forum. I start using and reading code some weeks ago and I want to give thanks to all contributor of MM. :-)
          The translations files of MM are under translate folder: https://github.com/MichMich/MagicMirror/tree/master/translations. I think that Norwegian is on nn.json so try with “nn” on config file.
            roramirez Core Contributors
            said in AM/PM times shown even with timeFormat: 24,:
            The format time for default modules can be set in timeFormat configuration.
            https://github.com/MichMich/MagicMirror#configuration
              Richard238
              Same issue here, config is set to 24, yet calendar shows 10:35pm.
              Google calendar shows 22:35, why is MM showing PM rather than 24hr?
              Thank you.
                roramirez Core Contributors @Richard238
                @Richard238 Is a knowed issue
                https://github.com/MichMich/MagicMirror/issues/776
                If you can help with that go ahead with a Pull Request.
