    3 tries 3 fails Raspberry b+
    28 Posts 7 Posters 29.3k Views 7 Watching
    • I
      infamoustiggr
      That is honestly amazing that you would take the time. Thanks!
      AlvingerA 1 Reply Last reply
      • AlvingerA
        Alvinger @infamoustiggr
        @infamoustiggr, thanks!
        Just make sure sure to pay it forward if you have the opportuniy to help someone else here in the forums.
        I 1 Reply Last reply
        Reply Quote 4
        • I
          infamoustiggr @Alvinger
          @Alvinger Really sorry! I’ve swapped to dietpi on fresh install and then follows your fine instructions a few times, clean install x3 at least, but keep getting same error:
          Xinit: giving up
          Xinit: unable to connect to X server: connection refused
          Xinit: server error
          Then it dumps me to the command line…
          Any idea how I’ve screwed up your fine instructions?
          Ta!
          Nick
          johnnyboyJ 1 Reply Last reply
          • johnnyboyJ
            johnnyboy @infamoustiggr
            • AlvingerA
              Alvinger @johnnyboy
              @johnnyboy
              Of course you could always buy a Pi 3 and not worry, but what’s the fun in that? It’s much more rewarding to make it run on a Pi 1! :-)
              @infamoustiggr
              The first rule of troubleshopting is to eliminate all things that ARE working! What’s left must be the error.
              I would start with running all commands from the shell, i.e. do not create the systemd scripts, rather run the respective commands from the shell bybtyping them in, that way you will get feedback from each command.
              The error messages you post do not have any context so it’s hard to know when they occur. From where did you cut the errors?
              When installing raspbian or dietpi you should NOT install X or any desktop environment, the relevant packages will be installed when you install the other components.
              • johnnyboyJ
                johnnyboy @Alvinger
                • AlvingerA
                  Alvinger @johnnyboy
                  @johnnyboy
                  That’s technology development for you. Of course, in this case @infamoustiggr has the luxury of having someone with the exact same equipment already having the solution running.
                  As to the speed issue, apart from taking a few extra seconds on boot, I have no issues whatsoever with speed for functionality on my Pi 1. But I must admit it took me a number of tries to get there! Doing it with little to no experience with Linux is really tough.
                  • I
                    I would go for the pi3 option, but it goes against my eco principles! Spare computer must have a job somewhere!
                    Thanks, I’ll try one line at a time and see how things go! Just out of interest though, how much fiddling did it take you? And how did you know the nodes hadn’t downloaded properly?
                    • AlvingerA
                      @infamoustiggr
                      I didn’t fiddle that much with the mirror pi. But ahead of that I’ve been doing quite some fiddling with Pis in general so I didn’t start from scratch.
                      To help you with troubleshooting:
                      After installing DietPi and rebooting you are presented with the dietpi-software screen:
                      0_1488462696670_upload-e5c282b6-f86e-4f85-9db8-c09d2112e649
                      Look under “Software Optimized” and “Software Additional” and make sure that NONE of the options are selected, you want an install that is as clean as possible.
                      Under DietPi-Config make sure that Autostart is set to option 0 (default):
                      0_1488462810956_upload-7d9332c2-e5a0-4048-9a38-cd6b58a09246
                      Change directory to /root and install MagicMirror according to instructions in the README.
                      Following my instructions above to install all systemd scripts and their helpers. My /root contains the following:
                      0_1488463243912_upload-a81285c4-984c-490f-9115-d51ae96b7284
                      Stop magicmirror service (just to make sure it isn’t running) with the command:
                      systemctl stop magicmirror.service
                      Start the magicmirror interactively by running node serveronly from the MagicMirror directory. You should see something similar to this:
                      root@mirrortest:~/MagicMirror# node serveronly
                      Starting MagicMirror: v2.1.1
                      Loading config ...
                      Loading module helpers ...
                      Module helper loaded: MMM-Remote-Control
                      Module helper loaded: MMM-WunderGround
                      Module helper loaded: MMM-ResRobot
                      Module helper loaded: MMM-NetworkScanner
                      All module helpers loaded.
                      Starting server op port 80 ...
                      Server started ...
                      Connecting socket for: MMM-Remote-Control
                      Starting node helper for: MMM-Remote-Control
                      Connecting socket for: MMM-WunderGround
                      MMM-WunderGround helper started ...
                      Starting module: newsfeed
                      Connecting socket for: MMM-ResRobot
                      Starting node_helper for module: MMM-ResRobot
                      Connecting socket for: MMM-NetworkScanner
                      Starting module: MMM-NetworkScanner
                      Ready to go! Please point your browser to: http://localhost:80
                      If any errors are shown, investigate them.
                      Now that MagicMirror is running it’s time to move on to the browser part.
                      Stop MagicMirror with ctrl+C and start the service with systemctl start magicmirror.service.
                      Make sure browser and matchbox are stopped by running the commands:
                      systemctl stop kioskbrowser.service
                      systemctl stop matchbox.service
                      Start matchbox with the command systemctl start matchbox.service. Check that it started ok with systemctl status matchbox.service. If not investigate.
                      Once you get this far the “only” thing left to check is the midori browser. As you don’t have an X Display on the console it is slightly trickier. Let me know if/when you made it this far and we’ll take it from there.
                      • I
                        infamoustiggr
                        Ah… Found it thanks to the checking…
                        Node.js:339
                        Throw err;
                        Error: Cannot find module ‘wtf-8’
                        Then a long list of different places that I’m guessing it’s where it’s missing…
                        I’ll have a blast at this for a bit. If it continues to fail so absolutely, maybe I’ll have to restart my bluetooth lawnmower project…
                        • AlvingerA
                          @infamoustiggr
                          Try installing wtf-8 module by running the command npm install wtf-8 from the MagicMirror directory.
                            Doublefire.Chen @infamoustiggr
                            @infamoustiggr Hello, may I ask you that did you make it? I also want to install MM on B+. Now the new board is so expensive that I just want to use my old B+ to do this awesome project.
                              sdetweil @Doublefire.Chen
                              @Doublefire-Chen last update was 5 years ago… so, unlikely to be helpful.
                              try my script. it’s probably the only hope. arm6l aren’t supported much anymore
                              D 1 Reply Last reply
                                Doublefire.Chen @sdetweil
                                @sdetweil I have a idea. I have a linux server. I can use docker to install MM on my server and B+ open the browser with full screen to display info after I set port forwaring.
                                  @Doublefire-Chen that works too. but don’t need port forwarding…
                                  if u look in my run-start.sh script, u will see the parms I use to launch chromium to look like electron full screen.
                                    @sdetweil Yes, you are right. The port forwarding is not needed.
