    3 tries 3 fails Raspberry b+
    28 Posts 7 Posters 29.1k Views 7 Watching
    • I
      infamoustiggr
      Hi Alvinger,
      That sounds exactly what I need thanks, with the only problem being that, being a complete learner, I don’t know what to do with it…
      Do I need to put the scripts into a particular file or just write them into the command line itself?
      On the whole I’ve managed most projects independently thanks to the mighty google and suitable search terms, got my media centre and a pi in my van as a music/film hub, but this is the first thing that’s been a bit more complicated and I’ve failed miserably to this point…
      I’ve been trying to learn this sort of thing for years and just never seem to have the time. I’m a physio by trade, so I don’t even have something close to this as my day job.
      Thanks for your patience!
      Nick
      • A
        Alvinger @infamoustiggr
        @infamoustiggr,
        Installed packages
        If you are running dietpi or Raspbian Jessie systemd should already be installed. Otherwise you need to install and enable it. Google is your friend.
        Midori should also be installed but Matchbox most likely isn’t. Install it with:
        sudo apt-get install matchbox-window-manager
        Systemd
        The systemd scripts are all located in /etc/systemd/system. To create magicmirror.service enter the following command (I’m using the editor nano):
        sudo nano /etc/systemd/system/magicmirror.service
        Paste script from above and edit to suit your needs.
        Make the script executable with the following command:
        sudo chmod +x /etc/systemd/system/magicmirror.service
        Repeat these steps for the other scripts by replacing magicmirror.service with the appropriate name.
        Custom script
        For DietPi the scripts are located in /root and for Raspbian they are located in /home/pi. Change to the appropriate directory with cd.
        nano kioskbrowser
        Paste the code from above and save/exit
        Make the script executable by running:
        chmod +x kioskbrowser
        MagicMirror config
        Make sure that MagicMirror has the correct port set in config.js. (Look for “port”: in config/config.js and make sure it is set to 80. Otherwise modify kioskbrowser.service and change the url http://localhost to http://localhost:port where port is the port number of MagicMirror.)
        Scheduled on/off times
        If you’re like me and do not want your mirror active during the night you can either use a module such as MMM-ModuleScheduler or a cron script that turns the monitor power on/off at set times. I use the latter. To do that you enter the command:
        crontab -e
        and paste the following lines
        59 05 * * *     /usr/bin/vcgencmd display_power 1
        09 23 * * *     /usr/bin/vcgencmd display_power 0
        Exit and save.
        The first line turns the monitor ON at 05:59 and the second line turns if OFF at 23:09. Modify according to needs.
        Reboot your pi and enjoy!
        • I
          infamoustiggr
          That is honestly amazing that you would take the time. Thanks!
          • A
            @infamoustiggr, thanks!
            Just make sure sure to pay it forward if you have the opportuniy to help someone else here in the forums.
            I 1 Reply Last reply Reply Quote 4
            • I
              infamoustiggr @Alvinger
              @Alvinger Really sorry! I’ve swapped to dietpi on fresh install and then follows your fine instructions a few times, clean install x3 at least, but keep getting same error:
              Xinit: giving up
              Xinit: unable to connect to X server: connection refused
              Xinit: server error
              Then it dumps me to the command line…
              Any idea how I’ve screwed up your fine instructions?
              Ta!
              Nick
              johnnyboyJ 1 Reply Last reply Reply Quote 0
              • johnnyboyJ
                johnnyboy @infamoustiggr
                • A
                  Alvinger @johnnyboy
                  @johnnyboy
                  Of course you could always buy a Pi 3 and not worry, but what’s the fun in that? It’s much more rewarding to make it run on a Pi 1! :-)
                  @infamoustiggr
                  The first rule of troubleshopting is to eliminate all things that ARE working! What’s left must be the error.
                  I would start with running all commands from the shell, i.e. do not create the systemd scripts, rather run the respective commands from the shell bybtyping them in, that way you will get feedback from each command.
                  The error messages you post do not have any context so it’s hard to know when they occur. From where did you cut the errors?
                  When installing raspbian or dietpi you should NOT install X or any desktop environment, the relevant packages will be installed when you install the other components.
                  • johnnyboyJ
                    johnnyboy @Alvinger
                    • A
                      Alvinger @johnnyboy
                      @johnnyboy
                      That’s technology development for you. Of course, in this case @infamoustiggr has the luxury of having someone with the exact same equipment already having the solution running.
                      As to the speed issue, apart from taking a few extra seconds on boot, I have no issues whatsoever with speed for functionality on my Pi 1. But I must admit it took me a number of tries to get there! Doing it with little to no experience with Linux is really tough.
                      I 1 Reply Last reply Reply Quote 1
                      • I
                        I would go for the pi3 option, but it goes against my eco principles! Spare computer must have a job somewhere!
                        Thanks, I’ll try one line at a time and see how things go! Just out of interest though, how much fiddling did it take you? And how did you know the nodes hadn’t downloaded properly?
                        • A
                          @infamoustiggr
                          I didn’t fiddle that much with the mirror pi. But ahead of that I’ve been doing quite some fiddling with Pis in general so I didn’t start from scratch.
                          To help you with troubleshooting:
                          After installing DietPi and rebooting you are presented with the dietpi-software screen:
                          0_1488462696670_upload-e5c282b6-f86e-4f85-9db8-c09d2112e649
                          Look under “Software Optimized” and “Software Additional” and make sure that NONE of the options are selected, you want an install that is as clean as possible.
                          Under DietPi-Config make sure that Autostart is set to option 0 (default):
                          0_1488462810956_upload-7d9332c2-e5a0-4048-9a38-cd6b58a09246
                          Change directory to /root and install MagicMirror according to instructions in the README.
                          Following my instructions above to install all systemd scripts and their helpers. My /root contains the following:
                          0_1488463243912_upload-a81285c4-984c-490f-9115-d51ae96b7284
                          Stop magicmirror service (just to make sure it isn’t running) with the command:
                          systemctl stop magicmirror.service
                          Start the magicmirror interactively by running node serveronly from the MagicMirror directory. You should see something similar to this:
                          root@mirrortest:~/MagicMirror# node serveronly
                          Starting MagicMirror: v2.1.1
                          Loading config ...
                          Loading module helpers ...
                          Module helper loaded: MMM-Remote-Control
                          Module helper loaded: MMM-WunderGround
                          Module helper loaded: MMM-ResRobot
                          Module helper loaded: MMM-NetworkScanner
                          All module helpers loaded.
                          Starting server op port 80 ...
                          Server started ...
                          Connecting socket for: MMM-Remote-Control
                          Starting node helper for: MMM-Remote-Control
                          Connecting socket for: MMM-WunderGround
                          MMM-WunderGround helper started ...
                          Starting module: newsfeed
                          Connecting socket for: MMM-ResRobot
                          Starting node_helper for module: MMM-ResRobot
                          Connecting socket for: MMM-NetworkScanner
                          Starting module: MMM-NetworkScanner
                          Ready to go! Please point your browser to: http://localhost:80
                          If any errors are shown, investigate them.
                          Now that MagicMirror is running it’s time to move on to the browser part.
                          Stop MagicMirror with ctrl+C and start the service with systemctl start magicmirror.service.
                          Make sure browser and matchbox are stopped by running the commands:
                          systemctl stop kioskbrowser.service
                          systemctl stop matchbox.service
                          Start matchbox with the command systemctl start matchbox.service. Check that it started ok with systemctl status matchbox.service. If not investigate.
                          Once you get this far the “only” thing left to check is the midori browser. As you don’t have an X Display on the console it is slightly trickier. Let me know if/when you made it this far and we’ll take it from there.
                          • I
                            infamoustiggr
                            Ah… Found it thanks to the checking…
                            Node.js:339
                            Throw err;
                            Error: Cannot find module ‘wtf-8’
                            Then a long list of different places that I’m guessing it’s where it’s missing…
                            I’ll have a blast at this for a bit. If it continues to fail so absolutely, maybe I’ll have to restart my bluetooth lawnmower project…
                            • A
                              @infamoustiggr
                              Try installing wtf-8 module by running the command npm install wtf-8 from the MagicMirror directory.
                                Doublefire.Chen @infamoustiggr
                                @infamoustiggr Hello, may I ask you that did you make it? I also want to install MM on B+. Now the new board is so expensive that I just want to use my old B+ to do this awesome project.
                                  sdetweil @Doublefire.Chen
                                  @Doublefire-Chen last update was 5 years ago… so, unlikely to be helpful.
                                  try my script. it’s probably the only hope. arm6l aren’t supported much anymore
                                    Doublefire.Chen @sdetweil
                                    @sdetweil I have a idea. I have a linux server. I can use docker to install MM on my server and B+ open the browser with full screen to display info after I set port forwaring.
                                      @Doublefire-Chen that works too. but don’t need port forwarding…
                                      if u look in my run-start.sh script, u will see the parms I use to launch chromium to look like electron full screen.
                                        @sdetweil Yes, you are right. The port forwarding is not needed.
