    Bluetooth connectivity using Raspberry pi3
    1 Posts 1 Posters 999 Views 1 Watching
    • N Offline
      nitz.j2412
      Hello Everyone,
      Great to be a part of this community. A big thanks to all the contributors and developers.
      I built a custom module to connect Adafruit Bluetooth module nrf8001 with the MM2. I am not seeing anything on the mirror and can’t figure out the issue. Please find attached the module files:
      node_helper.js
      var nrfuart = require('./index.js');
        start: function () {
          console.log('BLE helper started ...');
              if (notification === 'TEMP') {
                  console.log('Notification TEMP in ' + this.name + ' received');
                this.sendNotificationTest(this.anotherFunction());
      	else
      	console.log('ERRRRROR');
      sendNotificationTest:function(payload){
      this.sendSocketNotification('TEMPER',payload);
      anotherFunction: function(){
      	nrfuart.discoverAll(function(ble_uart) {
          	'use strict';
          	ble_uart.on('disconnect', function() {});
          	ble_uart.connectAndSetup(function() {
              	var writeCount = 0;
              	ble_uart.readDeviceName(function(devName) {});
              	ble_uart.on('data', function(data) {
      		var x = data.toString();
      		var con = x.substring(0,2);
      		var dec = x.substring(2,4);
      		con = con.concat('.');
      		con = con.concat(dec);
      		console.log(con);
      		return con;
              setInterval(function() {}, 3000);
      index.js
       * Adafruit nRF8001 breakout in UART mode. This might also work for other
       * nRF8001 boards but has only been tested with the Adafruit board.
      var NobleDevice = require('noble-device');
      var events = require('events');
      var util = require('util');
      var NRFUART_SERVICE_UUID = '6e400001b5a3f393e0a9e50e24dcca9e';
      var NRFUART_NOTIFY_CHAR  = '6e400003b5a3f393e0a9e50e24dcca9e';
      var NRFUART_WRITE_CHAR   = '6e400002b5a3f393e0a9e50e24dcca9e';
      var nrfuart = function(peripheral) {
          // call nobles super constructor
          NobleDevice.call(this, peripheral);
          // setup or do anything else your module needs here
      // tell Noble about the service uuid(s) your peripheral advertises (optional)
      nrfuart.SCAN_UUIDS = [NRFUART_SERVICE_UUID];
      util.inherits(nrfuart, events.EventEmitter);
      // and/or specify method to check peripheral (optional)
      nrfuart.is = function(peripheral) {
          'use strict';
          //return (peripheral.advertisement.localName === 'UART');
          return true;
      // inherit noble device
      NobleDevice.Util.inherits(nrfuart, NobleDevice);
      // Receive data using the 'data' event.
      nrfuart.prototype.onData = function(data) {
          'use strict';
          this.emit("data", data);
      // Send data like this
      // nrfuart.write('Hello world!\r\n', function(){...});
      // or this
      // nrfuart.write([0x02, 0x12, 0x34, 0x03], function(){...});
      nrfuart.prototype.write = function(data, done) {
          'use strict';
          if (typeof data === 'string') {
              this.writeDataCharacteristic(NRFUART_SERVICE_UUID, NRFUART_WRITE_CHAR, new Buffer(data), done);
          else {
              this.writeDataCharacteristic(NRFUART_SERVICE_UUID, NRFUART_WRITE_CHAR, data, done);
      nrfuart.prototype.connectAndSetup = function(callback) {
          'use strict';
          var self = this;
          NobleDevice.prototype.connectAndSetup.call(self, function() {
              self.notifyCharacteristic(NRFUART_SERVICE_UUID,
                  NRFUART_NOTIFY_CHAR, true, self.onData.bind(self), callback);
      // export device
      module.exports = nrfuart;
      bleEchoTst.js
      Module.register("bleEchoTst",{
      	temper: '999',
      	defaults: {
      	text: '100'
      	start: function() {
      	this.temper = this.config.text;
      	this.sendSocketNotification('TEMP',this.config);
      	socketNotificationReceived: function(notification,payload)
      	if(notification === 'TEMPER')
      	this.temper = payload;
      	//this.temper = '999';
      	this.updateDom();
              // Override dom generator.
      	getDom: function() {
      		wrapper.innerHTML = this.temper;
      		return wrapper;
      Any help is appreciated.
