Update V2.1.1 error
6 Posts 2 Posters 2.4k Views 2 Watching
  • N Offline
    Nonamexp
    I make the update and have this error:
    root@raspberrypi:/home/pi/MagicMirror# npm install
    npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN deprecated graceful-fs@1.2.3: graceful-fs v3.0.0 and before will fail on node releases >= v7.0. Please update to graceful-fs@^4.0.0 as soon as possible. Use 'npm ls graceful-fs' to find it in the tree.
    npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN prefer global coffee-script@1.10.0 should be installed with -g
    npm WARN prefer global colorguard@1.2.0 should be installed with -g
    > electron-prebuilt@1.4.13 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
    > node install.js
    npm WARN prefer global jsonlint@1.6.2 should be installed with -g
    npm WARN prefer global pm2@2.0.18 should be installed with -g
    npm ERR! Linux 4.4.50-v7+
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
    npm ERR! node v4.7.3
    npm ERR! npm  v2.15.11
    npm ERR! code EPEERINVALID
    npm ERR! peerinvalid The package stylelint@7.4.2 does not satisfy its siblings' peerDependencies requirements!
    npm ERR! peerinvalid Peer stylelint-config-standard@16.0.0 wants stylelint@^7.8.0
    npm ERR!     /home/pi/MagicMirror/npm-debug.log
    help me pls :O
    D 1 Reply Last reply Apr 2, 2017, 7:23 PM Reply Quote 0
      daenick @Nonamexp
      @Nonamexp Hello, some time ago, I get a similar error but no here, was while I want to install node.
      My solution was install those packages:
      Minimatch anda Graceful manually.
      By the way, do yo follow te exact instructions forma the upgrade?
      2.1.1] - 2017-04-01
      Note: This update uses new dependencies. Please update using the following command: git pull && npm install
      N 1 Reply Last reply Apr 2, 2017, 7:48 PM Reply Quote 0
      • N Offline
        Nonamexp @daenick
        @daenick I have first ‘git pull’ and after ‘npm install’
          daenick
          Weird, I have no problem with the update. Try to install each packages manually:
          minimatch and graceful
          N 1 Reply Last reply Apr 2, 2017, 8:29 PM Reply Quote 0
          • N Offline
            Nonamexp @daenick
            @daenick Have your advice followed and the problem persists. At the first magic mirror it went through without problems but the second I have the error
            D 1 Reply Last reply Apr 2, 2017, 8:34 PM Reply Quote 0
              daenick @Nonamexp
              @Nonamexp In this case I think you need to do a clean install…
