    simple web-radio
    4 Posts 2 Posters 2.4k Views 1 Watching
      Blackmirror
      I search for a simple web-radio that I can use with buttons,
      Volume , on, off, and chance the different streams.
      Only show short the station, after change.
      • brobergB Offline
        broberg Project Sponsor @Blackmirror
        @Blackmirror https://github.com/gismo2006/MMM-Myvoiceradio
        That one can be used to recieve commands from the gpio module
        Or if by buttons you mean on screen buttons then you have https://github.com/brobergp/MMM-TouchPlayerBasic
          Blackmirror @broberg
          So, I Have modified, and hope it will doing what I want:
          Module.register(“MMM-Myvoiceradio”,{
          // Default module config.
          defaults: { text: “
          Sender1: BigFM
          Sender2: Einslive
          var self = this;
          Sender = 0;
          If (notification === “Sender+”){
          Sender = Sender+1;
          If (Sender > 1){
          Sender = 2;
          If (notification === “Sender-”){
          Sender = Sender-1;
          If (Sender < 1){
          Sender = 2;
          if (Sender === 1){
              self.sendSocketNotification('einslive', {});
          if (Sender === 2){
          self.sendSocketNotification(‘bigfm’, {});
          if (notification === “Volume+”){
          self.sendSocketNotification(‘VolumeUp’, {});
          if (notification === “Volume-”){
          self.sendSocketNotification(‘VolumeDown’, {});
          if (notification === “radiostop”){
          self.sendSocketNotification(‘radiostop’, {});
          This was the Myvoiceradio.js
            Blackmirror
            I have a issue in the code, the Buttons will not work. How I can control the voiceradio with Buttons?
            Blackmirror
