    MMM-PIR-Sensor Black screen..
    9 Posts 5 Posters 6.0k Views 4 Watching
      Desertswing
      Hey guys could someone help me what am i doing wrong…?
      i keep getting this error:
      Error: Cannot find module 'onoff'
          at Module._resolveFilename (module.js:470:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:418:25)
          at Module.require (module.js:498:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:11:14)
          at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:88:3)
          at Module._compile (module.js:571:32)
          at Object.Module._extensions..js (module.js:580:10)
          at Module.load (module.js:488:32)
      { Error: Cannot find module 'onoff'
          at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      This is my config.js file:
                                module: 'MMM-PIR-Sensor',
                                  sensorPIN: 22,
                                  powerSaving: true,
                              relayOnState: 1
        beck0r
        Facing the same issue… The sensor itself works. Tested with a python script…
        As soon as I implement the config for the sensor the screen stays black (via VNC) and the MM is not reachable via browser.
        By the way, I have connected my GPIO-data-cable to PIN wiringPi 7. The description says that BCM numbering should be used, so I used 4 instead of 7 in the config. Is that correct?
        0_1495955558091_upload-4326d89c-c750-454d-baea-0405235938ca
        (Sorry for german screenshot)
        • E Offline
          envedede
          You are correct about the BCM pin numbering beck0r, it is not the same as the actual pin number (the BCM pin numbering origins from the processor pins if I am correct).
          What I advise is to forget about this module and use https://github.com/cowboysdude/Pir-Sensor instead.
          I made some slight changes to this myself, because it was still not turning on the monitor correctly.
          RUN apt-get update && apt-get install -y libraspberrypi-bin and replace the scripts from the above link as follows: monitor_on.sh contains only vcgencmd display_power 1 and monitor_off.sh only the line vcgencmd display_power 0. This solved my problem for every display I used so far, being HDMI, VGA and DVI displays.
            beck0r
            Thank’s for your answer. As you have already seen I was able to solve it nealry like cowboysdude did
              Desertswing @envedede
              @envedede
              How do i need to:
              chmod all files: From a terminal window in your root directory:
              sudo chmod +x pir.py
              sudo chmod +x monitor_off.sh
              sudo chmod +x monitor_on.sh
              Editing pir.py
              could u explain, i`m master noob with raspberry :P
                Desertswing @Desertswing
                @Desertswing
                I found out how to, i forgot to place the files in root :)
                But my screen isen`t going off yet but the light bulb i attached goed on and off when motion detected??
                  Desertswing
                  fixed this one !
                  • DuskeD Offline
                    Duske
                    I solved the Error: Cannot find module 'onoff'- Error by removing the node_modules from the MMM-PIR-Sensor directory and reinstall them by using npm i. This time, some dependencies seem to be built in with electron, and the error disappeared.
                      Richard238
