    Update says to "commit your changes or stash them before you can merge." ?
    26 Posts 8 Posters 46.1k Views 8 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Richard238
      @Richard238 yes this should colorize the calendar icon fa-calendar-check-o in your first instance and fa-trash-o in your second.
        Richard238
        • strawberry 3.141S
          @Richard238 check the part between calendar and compliments module
          R 1 Reply Last reply
            Richard238 @strawberry 3.141
            @strawberry-3.141 I’ve no idea what I’m looking for, sorry…
              Richard238
              Just tried the default sample config.js, and that doesn’t work either!
              • strawberry 3.141S
                @Richard238 you pasted the start function into your config file, but if the config sample doesnt work either your problem is somewhere else
                  Richard238
                  Powered off & on, default config OK, and mine too.
                  But, cannot see Mirror from PC, despite full whitelisting in config.
                  ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                    Richard238
                    And suddenly it come back into life! :)
                      pepemujica @yawns
                      @yawns Hi! I’ve never change neither te default modules or the main.css. Any idea why I get the same error?
                        bminer1 @yawns
                        @yawns I dont know what im doing wrong. Trying to follow your Option 2.
                        pi@raspberrypi:~/MagicMirror $ git reset
                        Unstaged changes after reset:
                        M	css/custom.css
                        M	modules/default/alert/alert.js
                        M	modules/default/calendar/calendar.css
                        M	modules/default/calendar/calendar.js
                        M	modules/default/currentweather/currentweather.js
                        M	modules/default/weatherforecast/weatherforecast.js
                        pi@raspberrypi:~/MagicMirror $ git pull
                        Updating 8010e62..5c41e24
                        error: Your local changes to the following files would be overwritten by merge:
                        Please, commit your changes or stash them before you can merge.
                        Aborting
                        Y 1 Reply Last reply
                        • Y
                          yawns Moderator @bminer1
                          @bminer1
                          please run
                          git reset --hard
                          git pull
                          npm install
                          You left out the --hard option :)
                          • rudibaraniR
                            rudibarani Project Sponsor
                            I am trying to update my Docker version to 2.5.0. Do I need to update the Docker image itself or can I just use the regular update path?
                            I keep getting the error to commit or stash my changes. Doing so does not change a thing:
                            root@magic_mirror:/opt/magic_mirror# git reset --hard && git pull
                            HEAD is now at 6aa156d Merge pull request #1343 from MichMich/develop
                            Updating 6aa156d..6db61b4
                                    config/config.js.sample
                                    css/main.css
                                    modules/default/calendar/calendarfetcher.js
                                    modules/default/compliments/README.md
                                    modules/default/compliments/compliments.js
                                    modules/default/newsfeed/README.md
                                    modules/default/newsfeed/newsfeed.js
                                    modules/default/updatenotification/updatenotification.js
                            Aborting        ```
                            Stashing the changes does not help either. Does someone have an idea?
