    Bash install command on MagicMirror front page doesn't work but the command in github does
    3 Posts 1 Posters 2.6k Views 1 Watching
    • A
      alberttwong
      The command curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash doesn’t work but bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh) works just fine.
      Latest version of Raspiberry OS
      • A
        alberttwong
        Log of the error… error in bash script.
        pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        Updating packages ...
        Get:1 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
        Get:2 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
        Get:3 http://mirrordirector.raspbian.org jessie/main armhf Packages [9,533 kB]
        Get:4 http://archive.raspberrypi.org jessie/main armhf Packages [163 kB]
        Get:5 http://archive.raspberrypi.org jessie/ui armhf Packages [57.9 kB]
        Get:6 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [43.3 kB]
        Get:7 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [84.2 kB]
        Get:8 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
        Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
        Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
        Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
        Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
        Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
        Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
        Fetched 9,920 kB in 19s (514 kB/s)
        Reading package lists... Done
        Installing helper tools ...
        Building dependency tree
        build-essential is already the newest version.
        curl is already the newest version.
        Suggested packages:
          git-daemon-run git-daemon-sysvinit git-doc git-el git-email git-gui gitk
          gitweb git-arch git-cvs git-mediawiki git-svn zip
        The following packages will be upgraded:
          git unzip wget
        3 upgraded, 0 newly installed, 0 to remove and 77 not upgraded.
        Need to get 3,342 kB of archives.
        After this operation, 0 B of additional disk space will be used.
        Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main wget armhf 1.16-1+deb8u2 [475 kB]
        Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u3 [2,725 kB]
        Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main unzip armhf 6.0-16+deb8u3 [142 kB]
        Fetched 3,342 kB in 2s (1,540 kB/s)
        Reading changelogs... Done
        (Reading database ... 112359 files and directories currently installed.)
        Preparing to unpack .../wget_1.16-1+deb8u2_armhf.deb ...
        Unpacking wget (1.16-1+deb8u2) over (1.16-1+deb8u1) ...
        Preparing to unpack .../git_1%3a2.1.4-2.1+deb8u3_armhf.deb ...
        Unpacking git (1:2.1.4-2.1+deb8u3) over (1:2.1.4-2.1+deb8u2) ...
        Preparing to unpack .../unzip_6.0-16+deb8u3_armhf.deb ...
        Unpacking unzip (6.0-16+deb8u3) over (6.0-16+deb8u2) ...
        Processing triggers for install-info (5.2.0.dfsg.1-6) ...
        Processing triggers for man-db (2.7.0.2-5) ...
        Processing triggers for mime-support (3.58) ...
        Setting up wget (1.16-1+deb8u2) ...
        Setting up git (1:2.1.4-2.1+deb8u3) ...
        Setting up unzip (6.0-16+deb8u3) ...
        bash: line 48: unexpected EOF while looking for matching `"'
        bash: line 49: syntax error: unexpected end of file
        • A
          alberttwong
          pi@raspberrypi:~ $ uname -a
          Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
