    Fresh install
    6 Posts 0 Posters 3.5k Views 2 Watching
    • PointPubMediaP Offline
      PointPubMedia
      Hey guys…
      Just finish installing a fresh install of MM2 with Raspberry pi 3, everything looks good except having issue with 2 default modules.
      News feed and Calendar are never showing something. Even using the default feed and calendar!
      mochmanM 1 Reply Last reply Reply Quote 0
      • mochmanM Offline
        mochman Module Developer @PointPubMedia
        @PointPubMedia Can you show us your config.js setup? Thanks. Just a dummy check, is your pi connected to the internet?
          PointPubMedia
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
                  port: 8080,
                  language: 'en',
                  timeFormat: 24,
                  units: 'metric',
                                  module: 'alert',
                                          alert_effect: 'genie',
                                          welcome_message: '*** Command Center started.'
                                  module: 'clock',
                                  position: 'top_left'
                                  module: 'calendar',
                                  header: 'CA Holidays',
                                  position: 'top_left',
                                                          symbol: 'calendar-check-o ',
                                  module: 'currentweather',
                                  position: 'top_right',
                                          locationID: '',  //ID from bulk.openweather.org/sample/
                                          appid: 'fa2606456c60a3cb0feceaad88b5f4be'
                                  module: 'weatherforecast',
                                  header: 'Weather Forecast',
                                          locationID: '5128581',  //ID from bulk.openweather.org/sample/
                                  module: 'newsfeed',
                                  position: 'bottom_bar',
                                          feeds: [
                                                          title: "LaPresse",
                                                          title: "BBC",
                                                          url: "http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk",
                                          showSourceTitle: true,
                                          showPublishDate: true
          And yes I have access to Internet, weather is working ;)
            PointPubMedia
            That’s very strange…
            I reboot the raspberry for another reason and now, everything is working…
            • mochmanM Offline
              Glad I could help! :-/
              • KirAsh4K Offline
                KirAsh4 Moderator
                That likely happened because the respective node fetchers didn’t start when you first tried it. Killing the app and restarting it would’ve fixed that … and by rebooting the pi, you accomplished the same thing.
