MMM-PIR-SENSOR after updating
2 Posts 1 Posters 1.4k Views 1 Watching
  • F Offline
    Fonfon
    sorry for this noob question but how i can fix this problem ?
    WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
    was compiled against a different Node.js version using
    NODE_MODULE_VERSION 50. This version of Node.js requires
    NODE_MODULE_VERSION 53. Please try re-compiling or re-installing
    the module (for instance, using npm rebuild ornpm install).
    no one have this problem ?
    • F Offline
      Fonfon
      ok i find the solution …
      I have delete the folder MagicMirror/modules/MMM-PIR-Sensor
      git clone
      npm install
      and its ok .
