Thin Monitor Solution
I’m looking to make a shallow-depth mirror and I was wondering if there was a better solution than using a tiny, recycled laptop monitor + LCD controller board. Shopping for regular monitors, it’s tough to know what the total depth of the guts that I’ll need (once the plastic is ripped off). Can anyone recommend a super thin-traditional LCD monitor?
@mizzoudavis
My 17inch lcd(LP173WF3) has 0.4cm. Normal lcd monitor is usually thicker than that, I guess. -
I used an Asus MB169B+
https://www.asus.com/de/Monitors/MB169BPlus/ -
@Sean Thanks. Did you need an LCD controller board as well?
@sero Interesting solution. Does it take USB only as an input? Any issues there?
@mizzoudavis small palm sized board is needed. You can purchase in amazon, ebay or other replacement shop.
@mizzoudavis
I removed the controller (which has just USB) and replaced it with a controller from eBay that has HDMI, VGA, etc.:eBay item 360626141655 :)
I live in Germany. So i link these in amazon.de however you can find these in any country.
@Sean Thank you! I wonder if the USB output of the controller board is enough to power the RPi?
@mizzoudavis enough but sometimes not stable. I use another hub.
