    I need help for module trafic
    13 Posts 2 Posters 7.3k Views 2 Watching
    • G Offline
      greda
      I can’t get the trafic module to work. Is it possible to switch to French ?
      My config:
      module: ‘MMM-Traffic’,
      position: ‘top_left’,
      classes: ‘dimmed medium’, //optional, default is ‘bright medium’, only applies to commute info not route_name
      api_key: ‘MyApiKey’,
      mode: ‘driving’,
      language: “fr”,
      origin: ‘Paris, France’,
      destination: ‘Rouen, France’,
      arrival_time: ‘0825’, //optional, but needs to be in 24 hour time if used.
      route_name: ‘Maison vers le bureau’,
      changeColor: true,
      showGreen: false,
      limitYellow: 5, //Greater than 5% of journey time due to traffic
      limitRed: 20, //Greater than 20% of journey time due to traffic
      traffic_model: ‘pessimistic’,
      interval: 120000, //2 minutes
      showWeekend: false,
      allTime: false
      My mirror screen
      Thank you for your help.
      • kruemelK Offline
        kruemel
        Did you generated an Google Maps (Java Script) API Key with your Google-Account?
        https://developers.google.com/maps/documentation/javascript/get-api-key?hl=fr
        • G Offline
          greda
          I generated a key api (googleAPIs). Nothing appears on the screen.
          • G Offline
            greda @greda
            @greda :
            I created a standard API key
            • kruemelK Offline
              kruemel
              Just to be sure :-)
              You added your API Key to ?
              And you navigated in your MagicMirror/modules folder and executed “npm install” ?
              Maybe try to be more specific like
              destination: ‘2 Rue Saint-Denis, Rouen, France’
              If that is not working i recommend you the Module MMM-MyCommute from j.e.f.f
              It looks nicer and i can say it works 100%
              • G Offline
                greda
                I just tested and I have no more information. Can I send you my private API to test ?
                • G Offline
                  greda
                  I try MMM-MyCommute now.
                  • kruemelK Offline
                    kruemel
                    sure, if its still not working with mycommute you can
                    • G Offline
                      greda
                      Kruemel,
                      Can you show me the configuration of your example please?
                      • kruemelK Offline
                        kruemel
                        			module: 'MMM-MyCommute',
                        			position: 'top_left',
                        			header: 'Verkehr nach',
                        				apikey: 'KEY',
                        				origin: 'AddressXY, Schweiz',
                        				startTime: '00:00',
                        				endTime: '23:59',
                        				nextTransitVehicleDepartureFormat: "[ab] HH:mm",
                        				travelTimeFormat: "h[h] m[m]",
                        					destinations: [
                        							destination: 'Address, Schweiz',
                        							label: 'Name Blabla',
                        							alternatives: true,
                        							showSummary: true,
                        							hideDays: [0,6],
                        							color: "#FACC2E"
                        							label: 'Name Blabla2',
                        							alternatives: true,
                        							showSummary: true,
                        							hideDays: [0,6],
                        							color: "#FACC2E"
                        							destination: 'Bahnhof Luzern, Zentralstrasse 1, 6002 Luzern, Schweiz',
                        							label: 'Luzern Bahnhof',
                        							mode: 'transit',
                        							transitMode: 'train',
                        							showNextVehicleDeparture: true,
                        							alternatives: true,
                        							color: "#2E9AFE"
