    Installing MM2
    20 Posts 6 Posters 20.3k Views 5 Watching
    • G Offline
      gzot @Bangee
      @Bangee
      I just try to launch the autoinstaller as pi in /home/pi and it works !
      Thanks a lot ;)
      • N Offline
        Neokamikaze
        Yes, when i installing with the user pi, it’s work. But now i Have this message
        npm ERR! Linux 4.4.13-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
        npm ERR! node v6.2.1
        npm ERR! npm  v3.9.3
        npm ERR! code ELIFECYCLE
        npm ERR! electron-prebuilt@1.2.5 postinstall: `node install.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the electron-prebuilt@1.2.5 postinstall script 'node install.js'.
        npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
        npm ERR! not with npm itself.
        npm ERR!     node install.js
        npm ERR!     npm bugs electron-prebuilt
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!     npm owner ls electron-prebuilt
        npm ERR!     /home/pi/MagicMirror/npm-debug.log
        • BangeeB Offline
          Bangee Module Developer
          ok, and whats inside of this file: /home/pi/MagicMirror/npm-debug.log
          Can you share this with us?
            berry @Bangee
            @Bangee said in Installing MM2:
            as I c, you’ve installed your MagicMirror in the /root directory.
            I’m not sure if this is working so far.
            Try to install everything as pi and not as root in the /home/pi directory and let us know what happend.
            try whoami -> pi
            update your distribution with sudo apt-get update && sudo apt-get upgrade
            then cd /home/pi or only cd
            and install again: curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
            worked for me !! thanks
            at least i shouldnt tried to install MM2 as root
            • N Offline
              Neokamikaze
              Hi Bangee,
              Sorry for this late. Find this my npm file.
              0_1467112984554_npm-debug.log
              • N Offline
                Neokamikaze
                I restart all installation and now my depencies is OK. But when i start “npm start” i have one erreur. This debug file:
                1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                2 info using npm@3.9.5
                3 info using node@v6.2.2
                5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/$
                10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
                12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
                13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
                14 verbose stack Exit status 1
                14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:245:16)
                14 verbose stack     at emitTwo (events.js:106:13)
                14 verbose stack     at EventEmitter.emit (events.js:191:7)
                14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                14 verbose stack     at ChildProcess.emit (events.js:191:7)
                14 verbose stack     at maybeClose (internal/child_process.js:852:16)
                14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                15 verbose pkgid magicmirror@2.0.0
                16 verbose cwd /home/pi/MagicMirror
                17 error Linux 4.4.14-v7+
                18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                19 error node v6.2.2
                20 error npm  v3.9.5
                21 error code ELIFECYCLE
                22 error magicmirror@2.0.0 start: `electron js/electron.js`
                22 error Exit status 1
                23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                23 error Make sure you have the latest version of node.js and npm installed.
                23 error If you do, this is most likely a problem with the magicmirror package,
                23 error not with npm itself.
                23 error Tell the author that this fails on your system:
                23 error     electron js/electron.js
                23 error You can get information on how to open an issue for this project with:
                23 error     npm bugs magicmirror
                23 error Or if that isn't available, you can get their info via:
                23 error     npm owner ls magicmirror
                23 error There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                • N Offline
                  Neokamikaze
                  I found my problem. I need start “npm start” directly on my session “pi”.
                  Thanks all
                    Bu52 @Bangee
                    @Bangee
                    first, I’m rather new to the RPi.
                    Second, I’m having issues installing MM2.
                    1. started with a 32G sd and installed Raspian.
                    2. then did sudo apt-get update, followed by sudo apt-get upgrade.
                    3. cd /home/pi.
                    4. Then curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                    5. All went well, except the last lines, which were:
                      Cloning MagicMirror Done!
                      Installing dependencies …
                      bash: line 108: npm: command not found
                      Unable to install dependencies!
                    6. the cd ~/MagicMirror followed by npm start
                      I get the following error message, “bash: npm: command not found”.
                      What am I doing wrong, please.
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      Missing some info here: Which Raspberry Pi? Which version of Rasbian? Have you tried following the complete installation guide, from unboxing to having MM² up and running?
                        Bu52 @KirAsh4
                        @KirAsh4 It is a RPi 3. Raspian is version 1.9.2. I did it all with one exception. I used Noobs to install Raspian instead of installing Raspian directly to my SD Card. All else is the same.
                        I will try it again without using Noobs.
                        • KirAsh4K Offline
                          KirAsh4 Moderator
                          The NOOBS installation isn’t a complete version of Jessie, unfortunately. It’s a slightly “lighter” version to fit on the card with the other OS versions.
                            Bu52 @KirAsh4
                            @KirAsh4 Thank-you. I think I’m making good progress because it is getting past the dependancies. However, when I start ‘npm start’ I get about a list of error lines. If I can figure out how to upload files, I will send a text file of the error responses and the npm-debug.log file.
                            1_1468859943952_npm-debug.log 0_1468859943950_err.txt
                              Bu52 @KirAsh4
                              Hi @KirAsh4 ,
                              I found the problem. Well, I didn’t. It was under Neokamikaze’s post. I had been using PuTTY in the installation because it made it easier and more accurate to cut and paste directions. The errors were during that PuTTY session. When I key in “npm start” from a command windows directly on the RPi 3, it comes up with the proper screen.
                              I still have some additional issues, but IT RUNS!! thank-you for your help. I proved I couldn’t have done it myself.
                              And thank-you, too, Neokamikaze.
                              • KirAsh4K Offline
                                KirAsh4 Moderator
                                Right. If you had followed the guide, you would’ve noticed that nowhere does it talk about using a client to connect and perform the various commands. You need to access it with a keyboard attached anyway to do the initial configuration before you can connect remotely, so rather than introduce another variable (having someone install something else), I opted not to do that.
                                That said, I’ll make a note in the guide. When connecting remotely, you must run the command as:
                                $ DISPLAY=:0 npm start
