    Installing MM2
    20 Posts 6 Posters 20.1k Views 5 Watching
      berry @berry
      Added the full error message
      @berry said in Installing MM2:
      npm ERR! Linux 4.4.9-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
      npm ERR! node v6.2.1
      npm ERR! npm v3.9.3
      npm ERR! code ELIFECYCLE
      npm ERR! electron-prebuilt@1.2.3 postinstall: node install.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron-prebuilt@1.2.3 postinstall script ‘node install.js’.
      npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
      npm ERR! not with npm itself.
      npm ERR! node install.js
      npm ERR! npm bugs electron-prebuilt
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls electron-prebuilt
      npm ERR! /root/MagicMirror/npm-debug.log
      • G Offline
        gzot
        I got the same problem with the auto-installer:
        Cloning MagicMirror Done!
        Installing dependencies ...
        npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
        npm WARN prefer global coffee-script@1.10.0 should be installed with -g
        npm WARN prefer global colorguard@1.2.0 should be installed with -g
        > electron-prebuilt@1.2.4 postinstall /root/MagicMirror/node_modules/electron-prebuilt
        > node install.js
        module.js:442
           throw err;
        Error: Cannot find module '/root/MagicMirror/node_modules/electron-prebuilt/install.js'
            at Function.Module._resolveFilename (module.js:440:15)
            at Function.Module._load (module.js:388:25)
            at Function.Module.runMain (module.js:575:10)
            at startup (node.js:160:18)
            at node.js:456:3
        npm ERR! Linux 4.4.13-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
        npm ERR! npm  v3.9.3
        npm ERR! electron-prebuilt@1.2.4 postinstall: `node install.js`
        npm ERR!
        npm ERR! Failed at the electron-prebuilt@1.2.4 postinstall script 'node install.js'.
        npm ERR! Or if that isn't available, you can get their info via:
        You can find the npm-debug.log file here : http://s000.tinyupload.com/index.php?file_id=35118371794828376162
        I used a Raspberry pi 2 with a fresh install of Raspbian Jessie and I followed the step by step tutorial (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial)
        • KirAsh4K Offline
          KirAsh4 Moderator
          I believe @paviro is the Electron God around here. But he’s busy with school at the moment so it may be a bit before he responds.
          • N Offline
            Neokamikaze
            Same error for me (Raspberry Pi 3 / Jessie)
            • BangeeB Offline
              Bangee Module Developer
              as I c, you’ve installed your MagicMirror in the /root directory.
              I’m not sure if this is working so far.
              Try to install everything as pi and not as root in the /home/pi directory and let us know what happend.
              try whoami -> pi
              update your distribution with sudo apt-get update && sudo apt-get upgrade
              then cd /home/pi or only cd
              and install again: curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
              G B B 3 Replies Last reply Reply Quote 0
              • G Offline
                gzot @Bangee
                @Bangee
                I just try to launch the autoinstaller as pi in /home/pi and it works !
                Thanks a lot ;)
                • N Offline
                  Neokamikaze
                  Yes, when i installing with the user pi, it’s work. But now i Have this message
                  npm ERR! npm  v3.9.3
                  npm ERR! electron-prebuilt@1.2.5 postinstall: `node install.js`
                  npm ERR!
                  npm ERR! Failed at the electron-prebuilt@1.2.5 postinstall script 'node install.js'.
                  npm ERR!     /home/pi/MagicMirror/npm-debug.log
                  • BangeeB Offline
                    ok, and whats inside of this file: /home/pi/MagicMirror/npm-debug.log
                    Can you share this with us?
                      berry @Bangee
                      @Bangee said in Installing MM2:
                      try whoami -> pi
                      worked for me !! thanks
                      at least i shouldnt tried to install MM2 as root
                      • N Offline
                        Neokamikaze
                        Hi Bangee,
                        Sorry for this late. Find this my npm file.
                        0_1467112984554_npm-debug.log
