    Installing MM2
    20 Posts 6 Posters 20.3k Views 5 Watching
      berry
      i’m a noobie and wants to install MM2 on a raspberry 2.
      Equal if i choose the autoinstaller or the manuel installation - i’ll allways gets an error with the electron-prebuilt.
      Maybe someone of you can help me with this problem.
      thank you in advance
      npm ERR! Linux 4.4.9-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
      npm ERR! node v6.2.1
      npm ERR! npm v3.9.3
      npm ERR! code ELIFECYCLE
      npm ERR! electron-prebuilt@1.2.3 postinstall: node install.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron-prebuilt@1.2.3 postinstall script ‘node install.js’.
      npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
      npm ERR! not with npm itself.
      npm ERR! node install.js
      npm ERR! npm bugs electron-prebuilt
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls electron-prebuilt
      npm ERR! /root/MagicMirror/npm-debug.log
        berry @berry
        Added the full error message
        @berry said in Installing MM2:
        npm ERR! npm v3.9.3
        npm ERR!
        • G Offline
          gzot
          I got the same problem with the auto-installer:
          Cloning MagicMirror Done!
          Installing dependencies ...
          npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
          npm WARN prefer global coffee-script@1.10.0 should be installed with -g
          npm WARN prefer global colorguard@1.2.0 should be installed with -g
          > electron-prebuilt@1.2.4 postinstall /root/MagicMirror/node_modules/electron-prebuilt
          > node install.js
          module.js:442
             throw err;
          Error: Cannot find module '/root/MagicMirror/node_modules/electron-prebuilt/install.js'
              at Function.Module._resolveFilename (module.js:440:15)
              at Function.Module._load (module.js:388:25)
              at Function.Module.runMain (module.js:575:10)
              at startup (node.js:160:18)
              at node.js:456:3
          npm ERR! Linux 4.4.13-v7+
          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
          npm ERR! npm  v3.9.3
          npm ERR! electron-prebuilt@1.2.4 postinstall: `node install.js`
          npm ERR!
          npm ERR! Failed at the electron-prebuilt@1.2.4 postinstall script 'node install.js'.
          npm ERR! Or if that isn't available, you can get their info via:
          You can find the npm-debug.log file here : http://s000.tinyupload.com/index.php?file_id=35118371794828376162
          I used a Raspberry pi 2 with a fresh install of Raspbian Jessie and I followed the step by step tutorial (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial)
          • KirAsh4K Offline
            KirAsh4 Moderator
            I believe @paviro is the Electron God around here. But he’s busy with school at the moment so it may be a bit before he responds.
            • N Offline
              Neokamikaze
              Same error for me (Raspberry Pi 3 / Jessie)
              • BangeeB Offline
                Bangee Module Developer
                as I c, you’ve installed your MagicMirror in the /root directory.
                I’m not sure if this is working so far.
                Try to install everything as pi and not as root in the /home/pi directory and let us know what happend.
                try whoami -> pi
                update your distribution with sudo apt-get update && sudo apt-get upgrade
                then cd /home/pi or only cd
                and install again: curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                G B B 3 Replies Last reply Reply Quote 0
                • G Offline
                  gzot @Bangee
                  @Bangee
                  I just try to launch the autoinstaller as pi in /home/pi and it works !
                  Thanks a lot ;)
                  • N Offline
                    Neokamikaze
                    Yes, when i installing with the user pi, it’s work. But now i Have this message
                    npm ERR! npm  v3.9.3
                    npm ERR! electron-prebuilt@1.2.5 postinstall: `node install.js`
                    npm ERR!
                    npm ERR! Failed at the electron-prebuilt@1.2.5 postinstall script 'node install.js'.
                    npm ERR!     /home/pi/MagicMirror/npm-debug.log
                    • BangeeB Offline
                      ok, and whats inside of this file: /home/pi/MagicMirror/npm-debug.log
                      Can you share this with us?
                        berry @Bangee
                        @Bangee said in Installing MM2:
                        try whoami -> pi
                        worked for me !! thanks
                        at least i shouldnt tried to install MM2 as root
                        • N Offline
                          Neokamikaze
                          Hi Bangee,
                          Sorry for this late. Find this my npm file.
                          0_1467112984554_npm-debug.log
                          • N Offline
                            Neokamikaze
                            I restart all installation and now my depencies is OK. But when i start “npm start” i have one erreur. This debug file:
                            1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                            2 info using npm@3.9.5
                            3 info using node@v6.2.2
                            5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                            6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                            7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                            8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                            9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/$
                            10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                            11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
                            12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
                            13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                            14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
                            14 verbose stack Exit status 1
                            14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:245:16)
                            14 verbose stack     at emitTwo (events.js:106:13)
                            14 verbose stack     at EventEmitter.emit (events.js:191:7)
                            14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                            14 verbose stack     at ChildProcess.emit (events.js:191:7)
                            14 verbose stack     at maybeClose (internal/child_process.js:852:16)
                            14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                            15 verbose pkgid magicmirror@2.0.0
                            16 verbose cwd /home/pi/MagicMirror
                            17 error Linux 4.4.14-v7+
                            18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                            19 error node v6.2.2
                            20 error npm  v3.9.5
                            21 error code ELIFECYCLE
                            22 error magicmirror@2.0.0 start: `electron js/electron.js`
                            22 error Exit status 1
                            23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                            23 error Make sure you have the latest version of node.js and npm installed.
                            23 error If you do, this is most likely a problem with the magicmirror package,
                            23 error not with npm itself.
                            23 error Tell the author that this fails on your system:
                            23 error     electron js/electron.js
                            23 error You can get information on how to open an issue for this project with:
                            23 error     npm bugs magicmirror
                            23 error Or if that isn't available, you can get their info via:
                            23 error     npm owner ls magicmirror
                            23 error There is likely additional logging output above.
                            24 verbose exit [ 1, true ]
                            • N Offline
                              Neokamikaze
                              I found my problem. I need start “npm start” directly on my session “pi”.
                              Thanks all
                                Bu52 @Bangee
                                @Bangee
                                first, I’m rather new to the RPi.
                                Second, I’m having issues installing MM2.
                                1. started with a 32G sd and installed Raspian.
                                2. then did sudo apt-get update, followed by sudo apt-get upgrade.
                                3. cd /home/pi.
                                4. Then curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                                5. All went well, except the last lines, which were:
                                  Installing dependencies …
                                  bash: line 108: npm: command not found
                                  Unable to install dependencies!
                                6. the cd ~/MagicMirror followed by npm start
                                  I get the following error message, “bash: npm: command not found”.
                                  What am I doing wrong, please.
                                • KirAsh4K Offline
                                  KirAsh4 Moderator
                                  Missing some info here: Which Raspberry Pi? Which version of Rasbian? Have you tried following the complete installation guide, from unboxing to having MM² up and running?
                                    Bu52 @KirAsh4
                                    @KirAsh4 It is a RPi 3. Raspian is version 1.9.2. I did it all with one exception. I used Noobs to install Raspian instead of installing Raspian directly to my SD Card. All else is the same.
                                    I will try it again without using Noobs.
                                    • KirAsh4K Offline
                                      KirAsh4 Moderator
                                      The NOOBS installation isn’t a complete version of Jessie, unfortunately. It’s a slightly “lighter” version to fit on the card with the other OS versions.
                                        Bu52 @KirAsh4
                                        @KirAsh4 Thank-you. I think I’m making good progress because it is getting past the dependancies. However, when I start ‘npm start’ I get about a list of error lines. If I can figure out how to upload files, I will send a text file of the error responses and the npm-debug.log file.
                                        1_1468859943952_npm-debug.log 0_1468859943950_err.txt
                                          Bu52 @KirAsh4
                                          Hi @KirAsh4 ,
                                          I found the problem. Well, I didn’t. It was under Neokamikaze’s post. I had been using PuTTY in the installation because it made it easier and more accurate to cut and paste directions. The errors were during that PuTTY session. When I key in “npm start” from a command windows directly on the RPi 3, it comes up with the proper screen.
                                          I still have some additional issues, but IT RUNS!! thank-you for your help. I proved I couldn’t have done it myself.
                                          And thank-you, too, Neokamikaze.
                                          • KirAsh4K Offline
                                            KirAsh4 Moderator
                                            Right. If you had followed the guide, you would’ve noticed that nowhere does it talk about using a client to connect and perform the various commands. You need to access it with a keyboard attached anyway to do the initial configuration before you can connect remotely, so rather than introduce another variable (having someone install something else), I opted not to do that.
                                            That said, I’ll make a note in the guide. When connecting remotely, you must run the command as:
                                            $ DISPLAY=:0 npm start
