    Not updating after network lost
    5 Posts 4 Posters 3.3k Views 4 Watching
      retroflex Project Sponsor Module Developer
      I have a pi3 powered mirror that works great when first powering up. A few times a day I can see via the ping module that I loose network. I guess that is normal since the pi is behind the frame, using wifi and is placed some distance from the router.
      But after wifi has dropped once, the modules (calendar and MMM-ResRobot) are never updated again. The calendar is stuck in time. Even though network comes back. It seems the ping module is updated though.
      If I restart the mirror, the modules will update. And if I access the mirror remotely (with MMM-RemoteControl) it shows correctly remotely.
      Any ideas what to do?
      • L
        Lange @retroflex
        It seems like the browser is crashing or not auto updating since it works when you access from a new location/browser
          retroflex Project Sponsor Module Developer @Lange
          @Lange but the ping module is updated along with the clock module, so a crash seems unlikely. But what can I do to debug this?
          da4throuxD 1 Reply Last reply Reply Quote 0
          • rcollieR
            rcollie
            The Pi may be turning off the wifi to conserve energy. So, you might need to turn off power management. Here’s a good walkthrough courtesy of modmypi (https://www.modmypi.com/blog/disable-wifi-power-management).
            If you are experiencing drop outs on your wifi interent connection, it could be that your dongle is turning itself off after an idle period. To stop your wifi dongle doing this, we need to disable its power management.
            Either SSH to your Pi, or login to its desktop and open up a terminal.
            First, make a backup of your existing interfaces file:
            sudo cp /etc/network/interfaces /etc/network/interfaces.backup
            Now edit the original interfaces file:
            sudo nano /etc/network/interfaces
            Assuming you haven’t edited this file before all you need to do is delete its entire contents, and copy the following into it:
            auto lo
            iface lo inet loopback
            iface eth0 inet dhcp
            auto wlan0
            allow-hotplug wlan0
            iface wlan0 inet dhcp
            wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
            wireless-power off
            iface default inet dhcp
            The important block of code here is:
            auto wlan0
            allow-hotplug wlan0
            wireless-power off
            So only add that section if you have a custom configuration for any other network interfaces.
            Now exit the nano editor and save your changes:
            Ctrl+x
            Y
            Enter
            Now reboot your raspberry pi:
            sudo reboot
            Once the raspberry pi has rebooted, check that the wifi dongle’s power management has been disabled by typing this command:
            iwconfig
            And checking for: “Power Management:off”
            • da4throuxD
              da4throux @retroflex
              @retroflex I think I have a similar issue, did @rcollie suggestion solved the issue for you ?
