Position of module moves
5 Posts 2 Posters 3.1k Views 2 Watching
  • K Offline
    krazykraka
    I’ve been trying to position a module (compliments) better to gain more real estate on the screen. I was successfully able to move it in the custom.css file, but once the compliments module reaches the interval timer and updates to a new compliment, it moves back to the original position on the screen. I’m at a loss as to why this is happening. Can anybody point me or guide me as to why this is happening?
    Thanks!
    ? 1 Reply Last reply Aug 23, 2017, 7:04 AM Reply Quote 0
      A Former User @krazykraka
      @krazykraka Why don’t you use position in config.js ?
      Every time the module should be redrawn(via .getDom()), MagicMirror puts the DOM into the region container which is defined in your config.js.
        A Former User
        So, if you want to hook this mechanism, You should modify your module not to be dependent on .getDom(), and you should draw and insert your DOM by yourself.
        K 1 Reply Last reply Aug 24, 2017, 5:45 AM Reply Quote 0
        • K Offline
          krazykraka
          Ok gotcha. I’ll give that a try after work. Thanks!
          • K Offline
            krazykraka @Guest
            @Sean It worked! Thanks! Time to continue on the other modules.
