    Module update
    update module
    5 Posts 2 Posters 26.7k Views 2 Watching
      MM-Hans
      I’m afraid this is a newbie question but after long time searching and nothing found I need to ask. My MagicMirror shows there is an update for the MMM-Traffic module but I don’t know how to update this module. Does anyone have an advice or the correct SSH command to update?
      • Nystro0mN
        Nystro0m
        Navigate to your module folder:
        § cd ~/MagicMirror/modules/MMM-Traffic
        use command to pull new git from:
        § git pull
        If you are experiencing the following message “your local changes to the following files would be overwritten by merge” because you have done local edits run this before (NOTE! backup the files you have edited in case you will need to pull some edits back, for exampel the CSS file if you have customized the look of the module:
        § git reset --hard
        Im not sure but someone can please correct me in on this one:
        Sometime you will need to install after git pull by:
        § npm install
        (This also inside the module folder)
        Is not needed, edited out
        Reply Quote 4
          MM-Hans
          Thank you for your advice, after following your instructions (git pull AND npm install) everything looks okay now and my mirror is up to date :-)
          Nystro0mN 1 Reply Last reply
          • Nystro0mN
            Nystro0m @MM-Hans
            @MM-Hans I have updated my post, npm install is not needed. Also added some more information that you may need to now.
            M 1 Reply Last reply
              MM-Hans @Nystro0m
              @Nystro0m Thanks again!
