Thx. In the meanwhile: I’d like to change the font size you use for display to small/tiny (I have about a zillion emails in 12+ different accounts)… so I have to fix my custom.css
Judging from previous problems (look at the bottom of
https://forum.magicmirror.builders/topic/254/sachin-s-mirror/21
) I stink at finding the properties myself - any hints would be most welcome. -
@amanzimdwini
That’s a good idea. Note:- Number of emails to display is customizable and the default is 5.
- Instead of enforcing people to play around with css, I can have a config property where you can set the font size as ‘big’, ‘medium’, ‘small’.
Please let me know when you get this module up and running, and whether the above helps.
Git pull was easy.
npm install yieldedpi@MagicMirror2:~/MagicMirror/modules $ npm install npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/packa ge.json' npm WARN modules No description npm WARN modules No repository field. npm WARN modules No README data npm WARN modules No license field.
I’ll go ahead, but thought you might want to know.
Note from admin: Please use Markdown on code and shell snippets!
@amanzimdwini
I am sorry if my instructions weren’t clear, I’ll update the README. You need to run “npm install” inside the “email” folder. -
pi@MagicMirror2:~/MagicMirror/modules $ npm install npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/packa ge.json' npm WARN modules No description npm WARN modules No repository field. npm WARN modules No README data npm WARN modules No license field. pi@MagicMirror2:~/MagicMirror/modules $ ^C pi@MagicMirror2:~/MagicMirror/modules $ cd .. pi@MagicMirror2:~/MagicMirror $ cd config/ pi@MagicMirror2:~/MagicMirror/config $ ls config.1 config.2 config.5.keep config.good config.good.js config.good.swap config.js config.js.sample config.js.save config.js.save.1 pi@MagicMirror2:~/MagicMirror/config $ sudo nano config.js pi@MagicMirror2:~/MagicMirror/config $ cd .. pi@MagicMirror2:~/MagicMirror $ cd modules/ pi@MagicMirror2:~/MagicMirror/modules $ ls default email MMM-HTTPRequestDisplay MMM-wordnik MMM-WunderGround MMM-Wunderlist node_modules README.md TR_swap pi@MagicMirror2:~/MagicMirror/modules $ cd email/ pi@MagicMirror2:~/MagicMirror/modules/email $ npm install email@0.0.1 /home/pi/MagicMirror/modules/email ├─┬ debug@2.2.0 │ └── ms@0.7.1 ├─┬ imap@0.8.17 │ ├─┬ readable-stream@1.1.14 │ │ ├── core-util-is@1.0.2 │ │ ├── inherits@2.0.1 │ │ ├── isarray@0.0.1 │ │ └── string_decoder@0.10.31 │ └── utf7@1.0.0 ├─┬ mailparser@0.4.9 │ ├─┬ encoding@0.1.12 │ │ └── iconv-lite@0.4.13 │ ├── mime@1.3.4 │ ├─┬ mimelib@0.2.19 │ │ └── addressparser@0.3.2 │ └── uue@1.0.0 └── underscore@1.8.3 npm WARN email@0.0.1 No repository field. npm WARN email@0.0.1 No license field.
@amanzimdwini Yes, you should be all set! Thanks for the updates. :D
@ronny3050
Thx for updating the README.
Followed instructions (requested app-pwd since I have 2-factor authentication).
My config.js:{ module: 'email', position: 'bottom_left', header: 'Email', config:{ user: 'XXX@gmail.com', password: '****************', host: 'imap.gmail.com', port: 993, tls: true, authTimeout: 10000, numberOfEmails: 5, fade: true }
Restarted (NOT REBOOTED) Pi.
Got this:
Rebooted (just to be safe) - same result.
@amanzimdwini you are missing a ‘}’ which closes the config block. It should look like:
{ module: 'email', position: 'bottom_left', header: 'Email', config:{ user: 'XXX@gmail.com', password: '****************', host: 'imap.gmail.com', port: 993, tls: true, authTimeout: 10000, numberOfEmails: 5, fade: true } }
@ronny3050
Sorry - pasted only partial copy; I had the trailing }.
My Config.js was correct…Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
So - I think the problem is elsewhere. Sorry
@amanzimdwini Could you please report the logs?
