    Email
    92 Posts 36 Posters 145.3k Views 39 Watching
      amanzimdwini @ronny3050
      @ronny3050
      Thx. In the meanwhile: I’d like to change the font size you use for display to small/tiny (I have about a zillion emails in 12+ different accounts)… so I have to fix my custom.css
      Judging from previous problems (look at the bottom of
      https://forum.magicmirror.builders/topic/254/sachin-s-mirror/21
      ) I stink at finding the properties myself - any hints would be most welcome.
        ronny3050 Module Developer @amanzimdwini
        @amanzimdwini
        That’s a good idea. Note:
        1. Number of emails to display is customizable and the default is 5.
        2. Instead of enforcing people to play around with css, I can have a config property where you can set the font size as ‘big’, ‘medium’, ‘small’.
        Please let me know when you get this module up and running, and whether the above helps.
          @ronny3050
          Git pull was easy.
          npm install yielded
          pi@MagicMirror2:~/MagicMirror/modules $ npm install
          npm WARN enoent ENOENT: no such file or directory, open
          '/home/pi/MagicMirror/modules/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/packa        ge.json'
          npm WARN modules No description
          npm WARN modules No repository field.
          npm WARN modules No README data
          npm WARN modules No license field.
          I’ll go ahead, but thought you might want to know.
          Note from admin: Please use Markdown on code and shell snippets!
          R E 2 Replies Last reply Reply Quote 0
            @amanzimdwini
            I am sorry if my instructions weren’t clear, I’ll update the README. You need to run “npm install” inside the “email” folder.
            A 1 Reply Last reply Reply Quote 1
              @ronny3050
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
              pi@MagicMirror2:~/MagicMirror/modules $ ^C
              pi@MagicMirror2:~/MagicMirror/modules $ cd ..
              pi@MagicMirror2:~/MagicMirror $ cd config/
              pi@MagicMirror2:~/MagicMirror/config $ ls
              config.1  config.2  config.5.keep  config.good  config.good.js  config.good.swap  config.js  config.js.sample  config.js.save  config.js.save.1
              pi@MagicMirror2:~/MagicMirror/config $ sudo nano config.js
              pi@MagicMirror2:~/MagicMirror/config $ cd ..
              pi@MagicMirror2:~/MagicMirror $ cd modules/
              pi@MagicMirror2:~/MagicMirror/modules $ ls
              default  email  MMM-HTTPRequestDisplay  MMM-wordnik  MMM-WunderGround  MMM-Wunderlist  node_modules  README.md  TR_swap
              pi@MagicMirror2:~/MagicMirror/modules $ cd email/
              pi@MagicMirror2:~/MagicMirror/modules/email $ npm install
              email@0.0.1 /home/pi/MagicMirror/modules/email
              ├─┬ debug@2.2.0
              │ └── ms@0.7.1
              ├─┬ imap@0.8.17
              │ ├─┬ readable-stream@1.1.14
              │ │ ├── core-util-is@1.0.2
              │ │ ├── inherits@2.0.1
              │ │ ├── isarray@0.0.1
              │ │ └── string_decoder@0.10.31
              │ └── utf7@1.0.0
              ├─┬ mailparser@0.4.9
              │ ├─┬ encoding@0.1.12
              │ │ └── iconv-lite@0.4.13
              │ ├── mime@1.3.4
              │ ├─┬ mimelib@0.2.19
              │ │ └── addressparser@0.3.2
              │ └── uue@1.0.0
              └── underscore@1.8.3
              npm WARN email@0.0.1 No repository field.
              npm WARN email@0.0.1 No license field.
                @amanzimdwini Yes, you should be all set! Thanks for the updates. :D
                  @ronny3050
                  Thx for updating the README.
                  Followed instructions (requested app-pwd since I have 2-factor authentication).
                  My config.js:
                                          module: 'email',
                                          position: 'bottom_left',
                                          header: 'Email',
                                          config:{
                                          user: 'XXX@gmail.com',
                                          password: '****************',
                                          host: 'imap.gmail.com',
                                          port: 993,
                                          tls: true,
                                          authTimeout: 10000,
                                          numberOfEmails: 5,
                                          fade: true
                  Restarted (NOT REBOOTED) Pi.
                  Got this:
                  0_1469426287738_upload-38a60756-5f8a-4933-b4f3-af564be8f683
                  Rebooted (just to be safe) - same result.
                    @amanzimdwini you are missing a ‘}’ which closes the config block. It should look like:
                                            module: 'email',
                                            header: 'Email',
                                            config:{
                                            port: 993,
                                            tls: true,
                                            authTimeout: 10000,
                                            numberOfEmails: 5,
                                            fade: true
                      @ronny3050
                      Sorry - pasted only partial copy; I had the trailing }.
                      My Config.js was correct…
                      Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
                      So - I think the problem is elsewhere. Sorry
                      R 3 Replies Last reply Reply Quote 0
                        @amanzimdwini Could you please report the logs?
                          @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                            @amanzimdwini It should be working now?
                              @ronny3050
                              Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
                              (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
                                @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
                                • N Offline
                                  Neokamikaze
                                  Thanks for this job.
                                  It’s possible to add number of email don’t read in the header module ?
                                    ronny3050 Module Developer @Neokamikaze
                                    @Neokamikaze Thanks for your kind words!
                                    It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                                    Thanks once more :D
                                      pietrodona
                                      Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                                      I managed the security and everything, it is a Gmail account.
                                      Any idea of what’s going on?
                                        pietrodona
                                        Sorry for double posting. Now it works, but I did nothing but rebooting.
                                          ronny3050 Module Developer @pietrodona
                                          @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                                          Hopefully, all is well now.
                                          • K Offline
                                            KirAsh4 Moderator
                                            When in doubt, pull the plug.
                                            • 1 / 5
