    MMM-Wunderlist-Enhanced javascript error
    14 Posts 2 Posters 5.8k Views 2 Watching
    • G Offline
      geeklimit
      Running MMM-Wunderlist-Enhanced via PM2 on Raspbian Jessie Lite. MM 2.1.3 and Electron 1.4.5.
      MMM-Wunderlist-Enhanced doesn’t show on screen. Checking PM2 error logs shows:
      ** Message: console message: [native code] @0: Load script: modules/MMM-Wunderlist-Enhanced//MMM-Wunderlist-Enhanced.js
      ** Message: console message: http://localhost:8080/modules/MMM-Wunderlist-Enhanced//MMM-Wunderlist-Enhanced.js @59: SyntaxError: Unexpected token '>'
      I’ve tried the following, just to make sure all dependencies and files are up to date and correct:
      pi@kitchenpi:~/MagicMirror/modules/MMM-Wunderlist-Enhanced $ git fetch --all
      Fetching origin
      pi@kitchenpi:~/MagicMirror/modules/MMM-Wunderlist-Enhanced $ git reset --hard origin/master
      HEAD is now at 4f01f5d Update README.md
      pi@kitchenpi:~/MagicMirror/modules/MMM-Wunderlist-Enhanced $ npm install
      up to date in 37.436s
      Seems OK. The section of code in MMM-Wunderlist-Enhanced.js that’s giving the problem is:
          this.config.lists.forEach((listValue, listKey) => {
      and in context here (line 59):
        getTodos: function() {
          var tasks = [];
            let list = this.tasks[listValue];
            if (list && list.length)
              list.forEach(todo => {
                if (this.config.order === 'reversed') {
                  tasks.push(todo);
                } else {
                  tasks.unshift(todo)
      It seems like the ‘=>’ is the problem?
      I’m not a javascript coder, so I can’t tell if it’s supposed to be that way or not.
      I tried changing it to just ‘=’, but that doesn’t fix the problem.
        A Former User @geeklimit
        @geeklimit what is your device? => is ES6 style syntax, so old js engine cannot parse it.
        • G Offline
          geeklimit
          It’s a Pi Zero W.
          pi@kitchenpi:~/MagicMirror/modules/MMM-NOAA $ npm version
          { 'mmm-noaa': '1.0.0',
            npm: '5.4.2',
            ares: '1.10.1-DEV',
            cldr: '31.0.1',
            http_parser: '2.7.0',
            icu: '59.1',
            modules: '57',
            node: '8.3.0',
            openssl: '1.0.2l',
            tz: '2017b',
            unicode: '9.0',
            uv: '1.13.1',
            v8: '6.0.286.52',
            zlib: '1.2.11' }
          Looks like node is at version 8.3.0.
          So…downgrade node or update the syntax?
            A Former User
            You can modify that with old style like this.
            to
            function (...) {...}
              @geeklimit I think pi zewo would use Midori instead Chromium as default browser. So you can try my above solution.
                A Former User
                Watchout! You should change all of this to self in function and prepend var self = this before function.
                • G Offline
                  geeklimit
                  I am using Midori as part of my startup script. Specifically:
                  #!/bin/sh
                  unclutter &
                  xset -dpms # disable DPMS (Energy Star) features.
                  xset s off # disable screen saver
                  xset s noblank # don’t blank the video device
                  matchbox-window-manager &
                  midori -e Fullscreen -a http://localhost:8080
                    @geeklimit can you change midori to chromium? I think its easier than code modifying.
                    • G Offline
                      geeklimit
                      You’re losing me, but I think you mean I should edit the line causing the error from:
                      to
                      this.config.lists.forEach ((listValue, listKey) {
                      Or does this section of the code need a complete rewrite?
                        @geeklimit sorry but i think there is not the only place where es6 style used. You should find and modify every place of that kinds. Browser changing is more easier.
