    Need help for testing modules
    14 Posts 5 Posters 7.7k Views 5 Watching
      A Former User @gauravsacc
      @gauravsacc Frankly, start of this module was stimulated by your module. ;)
      • T
        TheOmran
        Running into the following errors installing the module.
        pi@raspberrypi:~/MagicMirror/modules/MMM-Assistant $ npm install --save-dev electron-rebuild && ./node_modules/.bin/electron-rebuild --pre-gyp-fix
        MMM-TelegramBot@1.0.0 /home/pi/MagicMirror/modules/MMM-Assistant
        └── electron-rebuild@1.6.0
        npm WARN MMM-TelegramBot@1.0.0 No repository field.
        npm WARN MMM-TelegramBot@1.0.0 No license field.
        ✖ Rebuild Failed
        An unhandled error occurred inside electron-rebuild
        gyp info it worked if it ends with ok
        gyp info using node-gyp@3.6.2
        gyp info using node@6.11.3 | linux | arm
        gyp http GET https://atom.io/download/electron/v1.7.8/iojs-v1.7.8.tar.gz
        gyp http 200 https://atom.io/download/electron/v1.7.8/iojs-v1.7.8.tar.gz
        gyp http GET https://atom.io/download/electron/v1.7.8/SHASUMS256.txt
        gyp http 200 https://atom.io/download/electron/v1.7.8/SHASUMS256.txt
        gyp info spawn /usr/bin/python2
        gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp/gyp/gyp_main.py',
        gyp info spawn args   'binding.gyp',
        gyp info spawn args   '-f',
        gyp info spawn args   'make',
        gyp info spawn args   '-I',
        gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/build/config.gypi',
        gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp/addon.gypi',
        gyp info spawn args   '/home/pi/.electron-gyp/.node-gyp/iojs-1.7.8/common.gypi',
        gyp info spawn args   '-Dlibrary=shared_library',
        gyp info spawn args   '-Dvisibility=default',
        gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-1.7.8',
        gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp',
        gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-1.7.8/(target_arch)/iojs.lib',
        gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy',
        gyp info spawn args   '-Dnode_engine=v8',
        gyp info spawn args   '--depth=.',
        gyp info spawn args   '--no-parallel',
        gyp info spawn args   '--generator-output',
        gyp info spawn args   'build',
        gyp info spawn args   '-Goutput_dir=.' ]
        gyp info spawn make
        gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        make: Entering directory '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/build'
          CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o
          SOLINK_MODULE(target) Release/obj.target/snowboy.node
        /usr/bin/ld: cannot find -lcblas
        collect2: error: ld returned 1 exit status
        snowboy.target.mk:130: recipe for target 'Release/obj.target/snowboy.node' failed
        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/build'
        make: *** [Release/obj.target/snowboy.node] Error 1
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp/lib/build.js:258:23)
        gyp ERR! stack     at emitTwo (events.js:106:13)
        gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
        gyp ERR! System Linux 4.9.41-v7+
        gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/.bin/node-gyp" "rebuild" "--target=1.7.8" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/lib/node/binding/Release/electron-v1.7-linux-arm" "--remote_path=./snowboy/v1.2.0/Release/" "--package_name=snowboy-v1.2.0-electron-v1.7-linux-arm.tar.gz" "--host=https://snowboy-release-node.s3-us-west-2.amazonaws.com"
        gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy
        gyp ERR! node -v v6.11.3
        gyp ERR! node-gyp -v v3.6.2
        gyp ERR! not ok
        Failed with exit code: 1
        Error: gyp info it worked if it ends with ok
        gyp info spawn make
        gyp ERR! not ok
            at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/spawn-rx/lib/src/index.js:267:84)
            at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:238:16)
            at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:197:26)
            at Subscriber._error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:128:26)
            at Subscriber.error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:102:18)
            at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:128:26)
            at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:102:18)
            at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/spawn-rx/lib/src/index.js:241:65)
            at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:247:16)
            at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:187:27)
        Solution was to (after going back and forth for hours) install the following.
        sudo apt-get install libatlas-base-dev
        Right now it seems to be installing, still at 2% but will update when it’s done!
        Oh, and great plugin man! :)
        ? 1 Reply Last reply
          A Former User @TheOmran
          @TheOmran thanks. Maybe i missed something in manual. I’ll check and add your result to wiki. Thanks again.
            cxlwill
            I just starred your plugin while wandering at Github and go back to find the post at forum. I’m so excited that this plugin actually published with high level of completeness. You did a wonderful job!
              A Former User @cxlwill
              @cxlwill Thanks for your words. I hope I could find some nice East Asian Alternatives.
              • T
                Txukie
                I have been trying to make this work for a couple of days but I don’t seem to be able to achieve this. I have installed it correctly and add it to my screen, it does detect when I say “snowboy” but then it fails miserably.
                This is the error it throws:
                0|mm       | [ASSTNT] Conversation Error: Service unavailable.
                0|mm       | Recording 16384 bytes
                0|mm       | [ASSTNT] Conversation Error: { Error: Unknown Error.
                0|mm       |     at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:201:19)
                0|mm       |     at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:180:8)
                0|mm       |     at /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:649:14
                0|mm       |   code: 2,
                0|mm       |   metadata: Metadata { _internal_repr: { 'content-disposition': [Object] } } }
                This is the configuration file
                                  module: 'MMM-Assistant',
                                  position: 'bottom_left',
                                    assistant: {
                                      auth: {
                                        keyFilePath: "secret.json", //When you want to change the location of this file, set this.
                                        savedTokensPath: "resources/tokens.js" //When you want to change the location of this file, set this.
                                      audio: {
                                        encodingIn: "LINEAR16", //Ignore this. I think you don't need to change this.
                                        sampleRateOut: 16000 //Ignore this. I think you don't need to change this.
                                    snowboy: {
                                      models: [
                                          file: "resources/smart_mirror.pmdl",
                                          sensitivity: 0.5,
                                          hotwords : "MIRROR" //One of models should be "MIRROR"
                                          file: "resources/snowboy.umdl",
                                          sensitivity: 0.5,
                                          hotwords : "ASSISTANT" //One of models should be "ASSISTANT"
                                    record: {
                                      threshold: 0, //Ignore this. I think you don't need to change this.
                                      verbose:true, //true for checking recording status.
                                      recordProgram: 'rec', //You can use 'rec', 'sox'. But I recommend use 'arecord'.
                                      silence: 2.0 //Ignore this. I think you don't need to change this.
                                    stt: {
                                      auth: [{
                                        projectId: 'magicmirror-gassistant', //ProjectId from Google Console
                                        keyFilename: 'keyfile.json'
                                      }], //You can use multi accounts for saving money.
                                      request: {
                                        encoding: 'LINEAR16', //Ignore this. I think you don't need to change this.
                                        sampleRateHertz: 16000, //Ignore this. I think you don't need to change this.
                                        languageCode: 'en-US' //See https://cloud.google.com/speech/docs/languages
                                    speak: {
                                      useAlert: true, //If you want to show the text of speech, set this true. But It could be ignored by command of modules directly.
                                      language: 'en-US', //If you want to set the default language of speech of command result, set this.
                                    alias: [
                                        "help :command" : ["teach me :command", "what is :command"]
                                    ] // You can use aliases for difficult pronunciation or easy using.
                Any help with this would be greatly appreciated
                  A Former User @Txukie
                  @Txukie
                  Have you tried changing recordProgram to arecord?
                  • T
                    Txukie
                    I have, it fails with another error:
                    [ASSTNT] Assistant Activated
                    Recording with sample rate 16000...
                    Recording 4000 bytes
                    End Recording: 431.071ms
                    Recording 12044 bytes
                    (node:10777) Warning: No such label 'End Recording' for console.timeEnd()
                    [ASSTNT] Conversation Error: { Error: Received RST_STREAM with error code 0
                        at /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:649:14 code: 13, metadata: Metadata { _internal_repr: {} } }
                        A Former User
                        I’ll try to research it tomorrow. I wish good luck to both of you and me.
                        • T
                          Txukie
                          Ok, it does seem that my microphone is indeeed crap. I have managed to make it work by tinkling a little bit but it’s very unstable, seems to stop recording after a while for no apparent reason.
                          Also, when I try to change the language to es-ES it does not work at all, and I’m not sure why.
                            @Txukie as i know google assistant doesn’t support spanish yet(at least, in current grpc api). In configuration, spanish is available in ‘recognition on command mode’ and ‘speech response of command mode’, not ‘google assistant mode’.
