MMM-UkNationalRail - stops updating on mirror
@nwootton Mainly going with defaults, but here is what I’m using.
{ module: 'MMM-UKNationalRail', position: 'top_left', config: { stationCode: '[My 3 letter station code]', // CRS code for station app_id: '[My ID]', // TransportAPI App ID app_key: '[My api key]', // TransportAPI App Key maxResults: 4, //Optional - Maximum results to display. showOrigin: false //Optional - Show the origin of the train in the table } },
@randomnoise Can you tell me the station code? I can’t try to replicate or even figure out if it’s the provider without it.
OK, I’ve had my test environment running for a couple of days running both my station and your config with the provided station ID.
So far I’ve not seen the module fail to update, although the mirror itself has frozen on 1 occasion. I’ll keep trying it, but it’s quite difficult to debug without actually figuring out how to replicate it.
@nwootton Hmm, that’s weird. I guess it could be an issue specific to my mirror. What os do you use? Have you also upgraded to 2.1.3 of mm as well?
I might try a rebuild & see if that improves it.
Is there any way to add in debug logging to text file? Perhaps when it updates the data from transport api & refreshes the screen.
What I found strange was that even while it’s stopped updating on my actual mirror, it will work fine in a browser on another machine on my network (does this actually run another version of node helper etc or is the mirror still fetching the data?)
I used to run the mirror 2.1.2 on a RPi3, but that PI got repurposed for another project and is unlikely to make it back. For dev work I run it in either server or dev mode on a Mac. I’m running v2.1.3 on Node v8.7.0/npm v5.5.1 on the dev machine.
As it the mirror is a client-server architecture, it makes sense that the server part would be still receiving info from the Transport API. This seems to point to either Electron (UI) or Sockets.io failure rather than data ingest.
What version of Node & npm is running on your mirror? Are you running it as an all-in-one or are you running it in a different way (server only, docker)?
There is a simple “debug” : true setting you can add to the module config, but that mostly just gives the params & url that would be used by the module to contact the TransportAPI. The only other way is to launch the mirror using:
npm start dev
which will start Electron and also display a debug console on the right hand side of the screen.
@nwootton not sure what version of node I’m running atm (I’m away for work)… I’ll try the npm start dev when I’m back & see if anything stands out.
I run the mirror standalone so, yes I guess it could be an issue with something in the pi browser, but it is a fairly standard mm build installed following the instructions from mm git page.
I’ll report back once I’ve tried the dev start.
BTW does the npm dev start give any detail beyond what is logged to the mm_error_log file seen when running using pm2?
So still running without issues.
Got all the expected “No departure info” errors in the console for the overnight period where trains don’t actually run.
Have you updated the module itself?
@randomnoise The mm_error_log file is not something I’ve come across, I assume it is the failure report generated by PM2 that lists all the times it has had to restart a service.
npm start dev displays the mirror, but also has a full JS console output running down the side of the screen. The “No departure info” message in my previous post is an example of that output.
Still running without issue this morning, although I’m now getting emails about hitting my daily API usage allowance from the Transport API.
The only errors I’m getting are ones that the module generates when it doesn’t get the expected train info from Transport API - generally around 02:00 when no passenger trains are actually running.
Sorry to say that without being able to replicate the issue, there is very little more I can do.
