    python script into MagicMirror module
    4 Posts 2 Posters 4.3k Views 2 Watching
      sureshkocherla
      Hi, I want to run the python script into MagicMirror module. Kindly give the solution to my requirement.
        [[global:former-user]] @sureshkocherla
        @sureshkocherla
        You can execute an external program with Child Process of node.js. After reading this, create or modify your module.
        https://nodejs.org/api/child_process.html
          sureshkocherla
          Hi, Sean Thanks for your valuable reply,
          I have one python script. I want to create a new custom module for the requirement and also run this python script automatically in the module.
          Kindly guide me.
            @sureshkocherla
            Ok, Let’s see the example.
            MMM-Tools is using several external shell scripts in the module.
            https://github.com/eouia/MMM-Tools
            See the node_helpers.js (https://github.com/eouia/MMM-Tools/blob/master/node_helper.js)
            First, Child process could not be used on the frontend, so you need to build node_helpers.js for it.
            in line 10
            var exec = require('child_process').exec
            child_proces.exec is declared to use. You might need other methods like spawn or fork for your purpose.
            in line 123.
            getIP : function() {
                exec (this.scripts['IP'], (err, stdout, stderr)=>{
                  if (err == null) {
                    var matched = stdout.trim().match(/\b\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}\b/)
                    this.status['IP'] = (matched) ? matched[0] : "Unknown"
            this is all for your using exec.
            exec ("your command", function callback(error, outputonsuccess, outputonerr) {
               console.log(error, outputonsuccess, outputonerror)
            Try this in your module.
            ※ child_process.exec is a just simple method to get result of external command. But when you need more complexed function, you could consider spawn or fork or execFile instead exec
            https://dzone.com/articles/understanding-execfile-spawn-exec-and-fork-in-node
            this doc will be help.
