    MMM-Scrobble question - confused re: API
    12 Posts 2 Posters 6.3k Views 2 Watching
    • pyrosmileyP Offline
      pyrosmiley @ChrisEW
      @ChrisEW Is your issue with getting up and running to track with LFM? If so, the next step depends on what you’re using to listen to music. It will work with just about anything, and you can use several at once! You just have to point each music player/service at last.fm so that it can actually get the data. This page is your friend when it comes to that.
      For iTunes, you have to download the desktop program from that page and install it. It’ll scrobble anything playing from iTunes as you go, and will scrobble plays from an ipod/iphone whenever you sync it with your computer.
      For Spotify, it’s actually all built-in already! In each player you use (e.g. the Desktop player and the mobile app), go to the preferences, and under the “Social” section is a spot to sign in to LFM. Just do that and voilà! It will automatically update LFM as long as you’re not in a Private Session.
        ChrisEW @pyrosmiley
        @pyrosmiley Thanks. I am using an iPad mini to listen to music via Spotify. Although I did not see a “Preferences” button, I did find a last.fm on/off switch within the Spotify app on my iPad. So at least that’s done. But don’t i have to do something with the new config.js file I grabbed? On the rPi, I mean? Right now its just sitting in a separate new folder I made for it when I downloaded it. I’ve enteredthe API into that file.
        Maybe I’m making this overly complex?..
        pyrosmileyP 1 Reply Last reply Reply Quote 0
          pyrosmiley @ChrisEW
          @ChrisEW Ah, gotcha! You don’t need a new config.js file at all. The lines of code from the MMM-Scrobbler readme get copied and pasted into your main config file that you changed to set up the MagicMirror in the first place — that’s how it knows to look for the modules that you’ve downloaded to the ‘’’/modules/‘’’. That file is where you put in your information and set up all your modules, including this one.
          If you need help with the config file, there are several very comprehensive guides around these forums that should help.
          C 2 Replies Last reply Reply Quote 0
            ChrisEW @pyrosmiley
              ChrisEW @ChrisEW
                ChrisEW @pyrosmiley
                @pyrosmiley Bingo! Thanks so much!!
                pyrosmileyP 1 Reply Last reply Reply Quote 1
                  pyrosmiley @ChrisEW
                  @ChrisEW Absolutely! Glad to help.
