Solved Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
Thank you for your answers.
I am using stretch, see the
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)" NAME="Raspbian GNU/Linux" VERSION_ID="9" VERSION="9 (stretch)" ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
I followed the steps in this guide Complete Setup Tutorial
DISPLAY=:0 npm start
can not solve the problem.I will try to install MM with the Guide on GitHub you posted and I will see that comes out.
I will keep you updated.EDIT: So I followed the guide on GitHub and it works perfectly.
Thank you very much for this suggestion. -
Just tried again following this guide:
https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
so:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xinit xserver-xorg
sudo apt-get install lxde-core
sudo apt-get install lightdm
sudo apt-get install git
sudo apt-get install libxss1
sudo apt-get install libnss3
sudo apt-get install unclutter
then once it said to use the autoinstaller i went with manual installation.
After git clone i cd into MM and tried npm install… Ofc i didn’t work cause of missing npm so i tried with the simplest sudo apt-get install npm. After that i tried to verify node version with node -v but it did not gave any response. I tried anyway with sudo npm install into mm folder and it started… after a while it failed. This is the error i got, log attached.
[0_1515066236979_npm-debug.log](Uploading 100%)npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen) npm WARN engine webdriverio@4.9.11: wanted: {"node":">= 4.8.5"} (current: {"node":"4.8.2","npm":"1.4.21"}) > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron > node install.js sh: 1: node: not found npm WARN This failure might be due to the use of legacy binary "node" npm WARN For further explanations, please read /usr/share/doc/nodejs/README.Debian npm ERR! electron@1.4.15 postinstall: `node install.js` npm ERR! Exit status 127 npm ERR! npm ERR! Failed at the electron@1.4.15 postinstall script. npm ERR! This is most likely a problem with the electron package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node install.js npm ERR! You can get their info via: npm ERR! npm owner ls electron npm ERR! There is likely additional logging output above. npm ERR! System Linux 4.9.59-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v4.8.2 npm ERR! npm -v 1.4.21 npm ERR! code ELIFECYCLE - > uws@0.14.5 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/uws > node-gyp rebuild > build_log.txt 2>&1 || exit 0 > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver > node ./download-chromedriver.js sh: 1: node: not found npm WARN This failure might be due to the use of legacy binary "node" npm WARN For further explanations, please read /usr/share/doc/nodejs/README.Debian npm ERR! tar.unpack untar error /root/.npm/webdriverio/4.9.11/package.tgz npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0
@mafin could you give me the exact command lint you used? In that guide the only thing said about the installation is to use the automatic installer…
Using it i’m stuck here: (is it complete or stuck?)pi@raspberrypi:~ $ sudo bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)" $$\ $$\ $$\ $$\ $$\ $$\ $$$$$$\ $$$\ $$$ | \__| $$$\ $$$ |\__| $$ __$$\ $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ \__/ $$ | $$\$$\$$ $$ | \____$$\ $$ __$$\ $$ |$$ _____|$$\$$\$$ $$ |$$ |$$ __$$\ $$ __$$\ $$ __$$\ $$ __$$\ $$$$$$ | $$ \$$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ \$$$ $$ |$$ |$$ | \__|$$ | \__|$$ / $$ |$$ | \__|$$ ____/ $$ |\$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |\$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ | $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ | $$ | \$$$$$$ |$$ | $$$$$$$$\ \__| \__| \_______| \____$$ |\__| \_______|\__| \__|\__|\__| \__| \______/ \__| \________| $$\ $$ | \$$$$$$ | \______/ Updating packages ... Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease Hit:2 http://archive.raspberrypi.org/debian stretch InRelease Reading package lists... Done Installing helper tools ... Reading package lists... Done Building dependency tree Reading state information... Done build-essential is already the newest version (12.3). curl is already the newest version (7.52.1-5+deb9u3). git is already the newest version (1:2.11.0-3+deb9u2). unzip is already the newest version (6.0-21). wget is already the newest version (1.18-5+deb9u1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Check current Node installation ... Node.js is not installed. Installing Node.js ... ## Installing the NodeSource Node.js v6.x repo... ## Populating apt-get cache... + apt-get update Hit:1 http://archive.raspberrypi.org/debian stretch InRelease Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease Reading package lists... Done ## Confirming "stretch" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_6.x/dists/stretch/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add - OK ## Creating apt sources list file for the NodeSource Node.js v6.x repo... + echo 'deb https://deb.nodesource.com/node_6.x stretch main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src https://deb.nodesource.com/node_6.x stretch main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update Hit:1 http://archive.raspberrypi.org/debian stretch InRelease Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease Get:3 https://deb.nodesource.com/node_6.x stretch InRelease [4,635 B] Get:4 https://deb.nodesource.com/node_6.x stretch/main armhf Packages [1,006 B] Fetched 5,641 B in 2s (2,019 B/s) Reading package lists... Done ## Run `apt-get install nodejs` (as root) to install Node.js v6.x and npm Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: nodejs 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 8,790 kB of archives. After this operation, 41.1 MB of additional disk space will be used. Get:1 https://deb.nodesource.com/node_6.x stretch/main armhf nodejs armhf 6.12.3-1nodesource1 [8,790 kB] Fetched 8,790 kB in 11s (771 kB/s) Selecting previously unselected package nodejs. (Reading database ... 63014 files and directories currently installed.) Preparing to unpack .../nodejs_6.12.3-1nodesource1_armhf.deb ... Unpacking nodejs (6.12.3-1nodesource1) ... Setting up nodejs (6.12.3-1nodesource1) ... Processing triggers for man-db (2.7.6.1-2) ... Node.js installation Done! Cloning MagicMirror ... Cloning into 'MagicMirror'... remote: Counting objects: 8976, done. remote: Compressing objects: 100% (8/8), done. remote: Total 8976 (delta 3), reused 3 (delta 1), pack-reused 8967 Receiving objects: 100% (8976/8976), 11.48 MiB | 1.09 MiB/s, done. Resolving deltas: 100% (5077/5077), done. Cloning MagicMirror Done! Installing dependencies ... npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen) npm WARN prefer global coffee-script@1.10.0 should be installed with -g npm WARN prefer global jsonlint@1.6.2 should be installed with -g > uws@0.14.5 install /root/MagicMirror/node_modules/uws > node-gyp rebuild > build_log.txt 2>&1 || exit 0
No you are stuck ^^
It is done. You can safely ignore warnings ;)
Just copy and rename the sample config.js and start the mirror in the MagicMirror folder with using „npm Start“
Or better use pm2
Take a look at the great tutorials in the Forum. -
@cruunnerr
I won’t be so sure…
ahahahaha> magicmirror@2.2.2 start /home/pi/MagicMirror > sh run-start.sh /home/pi/MagicMirror/node_modules/electron/index.js:9 throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again') ^ Error: Electron failed to install correctly, please delete node_modules/electron and try installing again at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.require (module.js:497:17) at require (internal/module.js:20:19) at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16) at Module._compile (module.js:570:32) npm ERR! Linux 4.9.59-v7+ npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start" npm ERR! node v6.12.3 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE npm ERR! magicmirror@2.2.2 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sh run-start.sh npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs magicmirror npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/MagicMirror/npm-debug.log
didn’t expect that ^^
try going to your MagicMirror folder and type
npm install electron@1.4.15
Maybe it will say, that this version is invalid.
Check the version here:/home/pi/MagicMirror/node_modules/electron/dist/version
or try it global
sudo npm install -g electron@1.4.15
Question: Did u first install it manually and then with the automatic installer?
If so, did u delete your MagicMirror folder before using the automatic installer? If not, maybe this causes the error.
So try deleting the MagicMirror folder and then use the automatic installer again. -
This post is deleted! -
@cruunnerr I went to jessie, tried again… it failed… reinstalled electron 3 times… still fails… always the same damn error…
i think i’m gonna build my own webpage with blackjack and hookers…This is so incredible…
Hi
i have the same Problem npm install electron@1.4.15 dasen`t work. it was of no use a blank mirror with the same error log.
have now one any idea ???
@Homerj i’m desperate, 2 days no result… i’d love an img to flash with everything working… anyone?
