    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 37.1k Views 8 Watching
    • cowboysdudeC Offline
      Install it manually not via the installer…too many issues.
      • L Offline
        L_i_v_e
        I have stretch full (mm owner said lite not supported in a comment in this forum)
        I tried both automatic and manual installation, i tried with both node js 9.3.0 and the automatic node update from MM.
        How you installed It? What node version? Did u use -g after npm install?
        Btw i work only from SSH, to make It start i used pm2 before this new clean install
        I think my installer can’t install electron from what i read at installation fail
        • cruunnerrC Offline
          cruunnerr
          i did it exactly as wrote in this tutorial:
          https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
          only difference:
          i used Raspbian stretch lite and to disable the screensaver i used xscreensaver
          does need a little bit longer because u need to install the dependancies first, but it runs from the beginning without issues.
          but to be on the safety side, you can use raspbian jesse full as many users wrote about problems with stretch
            mafin
            Thank you for your answers.
            I am using stretch, see the cat /etc/os-release
            PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="9"
            VERSION="9 (stretch)"
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            I followed the steps in this guide Complete Setup Tutorial
            DISPLAY=:0 npm start can not solve the problem.
            I will try to install MM with the Guide on GitHub you posted and I will see that comes out.
            I will keep you updated.
            EDIT: So I followed the guide on GitHub and it works perfectly.
            Thank you very much for this suggestion.
            • L Offline
              L_i_v_e
              Just tried again following this guide:
              so:
              sudo apt-get update
              sudo apt-get upgrade
              sudo apt-get install xinit xserver-xorg
              sudo apt-get install lxde-core
              sudo apt-get install lightdm
              sudo apt-get install git
              sudo apt-get install libxss1
              sudo apt-get install libnss3
              sudo apt-get install unclutter
              then once it said to use the autoinstaller i went with manual installation.
              After git clone i cd into MM and tried npm install… Ofc i didn’t work cause of missing npm so i tried with the simplest sudo apt-get install npm. After that i tried to verify node version with node -v but it did not gave any response. I tried anyway with sudo npm install into mm folder and it started… after a while it failed. This is the error i got, log attached.
              [0_1515066236979_npm-debug.log](Uploading 100%)
              npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
              npm WARN engine webdriverio@4.9.11: wanted: {"node":">= 4.8.5"} (current: {"node":"4.8.2","npm":"1.4.21"})
              > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              sh: 1: node: not found
              npm WARN This failure might be due to the use of legacy binary "node"
              npm WARN For further explanations, please read
              /usr/share/doc/nodejs/README.Debian
              npm ERR! electron@1.4.15 postinstall: `node install.js`
              npm ERR! Exit status 127
              npm ERR!
              npm ERR! Failed at the electron@1.4.15 postinstall script.
              npm ERR! This is most likely a problem with the electron package,
              npm ERR! not with npm itself.
              npm ERR!     node install.js
              npm ERR! You can get their info via:
              npm ERR!     npm owner ls electron
              npm ERR! System Linux 4.9.59-v7+
              npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
              npm ERR! cwd /home/pi/MagicMirror
              npm ERR! node -v v4.8.2
              npm ERR! npm -v 1.4.21
              npm ERR! code ELIFECYCLE
              > uws@0.14.5 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/uws
              > node-gyp rebuild > build_log.txt 2>&1 || exit 0
              > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
              > node ./download-chromedriver.js
              npm ERR! tar.unpack untar error /root/.npm/webdriverio/4.9.11/package.tgz
              npm ERR!
              npm ERR! Additional logging details can be found in:
              npm ERR!     /home/pi/MagicMirror/npm-debug.log
              npm ERR! not ok code 0
              • L Offline
                L_i_v_e @mafin
                @mafin could you give me the exact command lint you used? In that guide the only thing said about the installation is to use the automatic installer…
                Using it i’m stuck here: (is it complete or stuck?)
                pi@raspberrypi:~ $ sudo bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                        \______/
                Updating packages ...
                Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
                Reading package lists... Done
                Installing helper tools ...
                Building dependency tree
                build-essential is already the newest version (12.3).
                curl is already the newest version (7.52.1-5+deb9u3).
                git is already the newest version (1:2.11.0-3+deb9u2).
                unzip is already the newest version (6.0-21).
                wget is already the newest version (1.18-5+deb9u1).
                Node.js is not installed.
                Installing Node.js ...
                ## Installing the NodeSource Node.js v6.x repo...
                ## Populating apt-get cache...
                + apt-get update
                Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                ## Confirming "stretch" is supported...
                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_6.x/dists/stretch/Release'
                ## Adding the NodeSource signing key to your keyring...
                + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                OK
                ## Creating apt sources list file for the NodeSource Node.js v6.x repo...
                + echo 'deb https://deb.nodesource.com/node_6.x stretch main' > /etc/apt/sources.list.d/nodesource.list
                + echo 'deb-src https://deb.nodesource.com/node_6.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
                ## Running `apt-get update` for you...
                + apt-get update
                Get:3 https://deb.nodesource.com/node_6.x stretch InRelease [4,635 B]
                Get:4 https://deb.nodesource.com/node_6.x stretch/main armhf Packages [1,006 B]
                Fetched 5,641 B in 2s (2,019 B/s)
                ## Run `apt-get install nodejs` (as root) to install Node.js v6.x and npm
                The following NEW packages will be installed:
                  nodejs
                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                Need to get 8,790 kB of archives.
                After this operation, 41.1 MB of additional disk space will be used.
                Get:1 https://deb.nodesource.com/node_6.x stretch/main armhf nodejs armhf 6.12.3-1nodesource1 [8,790 kB]
                Fetched 8,790 kB in 11s (771 kB/s)
                Selecting previously unselected package nodejs.
                (Reading database ... 63014 files and directories currently installed.)
                Preparing to unpack .../nodejs_6.12.3-1nodesource1_armhf.deb ...
                Unpacking nodejs (6.12.3-1nodesource1) ...
                Setting up nodejs (6.12.3-1nodesource1) ...
                Processing triggers for man-db (2.7.6.1-2) ...
                Node.js installation Done!
                Cloning MagicMirror ...
                Cloning into 'MagicMirror'...
                remote: Counting objects: 8976, done.
                remote: Compressing objects: 100% (8/8), done.
                remote: Total 8976 (delta 3), reused 3 (delta 1), pack-reused 8967
                Receiving objects: 100% (8976/8976), 11.48 MiB | 1.09 MiB/s, done.
                Resolving deltas: 100% (5077/5077), done.
                Cloning MagicMirror Done!
                Installing dependencies ...
                npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                > uws@0.14.5 install /root/MagicMirror/node_modules/uws
                  cruunnerr
                  No you are stuck ^^
                  It is done. You can safely ignore warnings ;)
                  Just copy and rename the sample config.js and start the mirror in the MagicMirror folder with using „npm Start“
                  Or better use pm2
                  Take a look at the great tutorials in the Forum.
                  • L Offline
                    L_i_v_e @cruunnerr
                    @cruunnerr
                    I won’t be so sure…
                    ahahahaha
                    > magicmirror@2.2.2 start /home/pi/MagicMirror
                    > sh run-start.sh
                    /home/pi/MagicMirror/node_modules/electron/index.js:9
                      throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                    Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                        at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                        at Module._compile (module.js:570:32)
                        at Object.Module._extensions..js (module.js:579:10)
                        at Module.load (module.js:487:32)
                        at tryModuleLoad (module.js:446:12)
                        at Function.Module._load (module.js:438:3)
                        at Module.require (module.js:497:17)
                        at require (internal/module.js:20:19)
                        at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                    npm ERR! Linux 4.9.59-v7+
                    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                    npm ERR! node v6.12.3
                    npm ERR! npm  v3.10.10
                    npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                    npm ERR! If you do, this is most likely a problem with the magicmirror package,
                    npm ERR!     sh run-start.sh
                    npm ERR!     npm bugs magicmirror
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls magicmirror
                      cruunnerr
                      didn’t expect that ^^
                      try going to your MagicMirror folder and type npm install electron@1.4.15
                      Maybe it will say, that this version is invalid.
                      Check the version here: /home/pi/MagicMirror/node_modules/electron/dist/version
                      or try it global sudo npm install -g electron@1.4.15
                      Question: Did u first install it manually and then with the automatic installer?
                      If so, did u delete your MagicMirror folder before using the automatic installer? If not, maybe this causes the error.
                      So try deleting the MagicMirror folder and then use the automatic installer again.
                      • L Offline
                        L_i_v_e
                        • L Offline
                          L_i_v_e @cruunnerr
                          @cruunnerr I went to jessie, tried again… it failed… reinstalled electron 3 times… still fails… always the same damn error…
                          i think i’m gonna build my own webpage with blackjack and hookers…
                          This is so incredible…
                          • H Offline
                            Homerj
                            Hi
                            i have the same Problem npm install electron@1.4.15 dasen`t work. it was of no use a blank mirror with the same error log.
                            have now one any idea ???
                            • L Offline
                              L_i_v_e @Homerj
                              @Homerj i’m desperate, 2 days no result… i’d love an img to flash with everything working… anyone?
                              • H Offline
                                Homerj
                                I have restored an old backup with which it ran with version 2.13 since 01:18 I have no chance to get it to work.
                                I have a rp3 with stretch on the run where synonymous fhem over it runs. if any one idea would be great
                                • L Offline
                                  L_i_v_e @Homerj
                                  @Homerj could you share it?
                                    cruunnerr
                                    @L_i_v_e
                                    Ok i checked your earlier posts again.
                                    U did execute the whole stuff as root user. Thats not necessary and even not good!
                                    I don’t know what else u did as root, but maybe first try to delete the whole MagicMirror Folder and run the command without sudo.
                                    Or try a new installation of the raspbian and begin with this (for a full raspbian) or this (for a lite raspbian) tutorial. Do it exactly as its wrote down!
                                    L 2 Replies Last reply Reply Quote 0
                                    • L Offline
                                      L_i_v_e @cruunnerr
                                      @cruunnerr From when sudo is a bad thing? I’ll try now
                                      • L Offline
                                        L_i_v_e @cruunnerr
                                        @cruunnerr after an auto install without sudo, made it work starting the installation of electron for the 2nd time in it’s folder. Now everything runs smooth if i give him commands but 1:
                                        -server only does not work, i can’t access it remotely
                                        -pm2 start does not work, the display goes all black but no module is loaded, it stays black. I tried with both my old config and the example config
                                        -maybe local launch does not work too? i have no idea since it’s really hard to connect a mouse and keyboard. If i use a VNC can i start it with npm start only?
                                        any idea?
                                        cruunnerrC 1 Reply Last reply Reply Quote 0
                                          cruunnerr @L_i_v_e
                                          @L_i_v_e said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                                          Yes.
                                          Since i started my project a few weeks/month ago i have had some trouble, too. But it was all about my inexperience. So at this point im out at all, sorry.
                                          Hope someone can help you.
                                          But if i said before: Reading the many tutorials and do it like it’s written there brought me to the goal.
                                          Only difference to you was, that i was using the early magic mirror versions.
                                          Maybe u should give it a last try with Version 2.1.3 and updating later or hoping that there are other guys who can help you. :(
                                            carltonb
                                            I too have the same problems. In another thread started a few days ago because I have the same issues.
                                            Started with Stretch, then went back to an old Jessie Lite version.
                                            I have done the automatic install, the manual install, as root and not as root.
                                            All fail at the same place. I currently have 5 MM running on PI3, then the update came and tried on one device when it crashed. I will not touch the others until this is resolved.
                                            If someone fixes this can they post the steps they used and a link to the image that they used as well.
                                            This is getting very frustrating. All my mirrors went together in a matter of an hour or so with no problems. Setting the modules and css is another thing though.
                                            Any help is very much appreciated.
                                            carltonb
