    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 39.7k Views 8 Watching
    • cruunnerrC Offline
      cruunnerr
      No you are stuck ^^
      It is done. You can safely ignore warnings ;)
      Just copy and rename the sample config.js and start the mirror in the MagicMirror folder with using „npm Start“
      Or better use pm2
      Take a look at the great tutorials in the Forum.
      • L Offline
        L_i_v_e @cruunnerr
        @cruunnerr
        I won’t be so sure…
        ahahahaha
        > magicmirror@2.2.2 start /home/pi/MagicMirror
        > sh run-start.sh
        /home/pi/MagicMirror/node_modules/electron/index.js:9
          throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
        Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
            at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
            at Module._compile (module.js:570:32)
            at Object.Module._extensions..js (module.js:579:10)
            at Module.load (module.js:487:32)
            at tryModuleLoad (module.js:446:12)
            at Function.Module._load (module.js:438:3)
            at Module.require (module.js:497:17)
            at require (internal/module.js:20:19)
            at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
        npm ERR! Linux 4.9.59-v7+
        npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
        npm ERR! node v6.12.3
        npm ERR! npm  v3.10.10
        npm ERR! code ELIFECYCLE
        npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
        npm ERR! If you do, this is most likely a problem with the magicmirror package,
        npm ERR! not with npm itself.
        npm ERR!     sh run-start.sh
        npm ERR!     npm bugs magicmirror
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!     npm owner ls magicmirror
        npm ERR!     /home/pi/MagicMirror/npm-debug.log
          cruunnerr
          didn’t expect that ^^
          try going to your MagicMirror folder and type npm install electron@1.4.15
          Maybe it will say, that this version is invalid.
          Check the version here: /home/pi/MagicMirror/node_modules/electron/dist/version
          or try it global sudo npm install -g electron@1.4.15
          Question: Did u first install it manually and then with the automatic installer?
          If so, did u delete your MagicMirror folder before using the automatic installer? If not, maybe this causes the error.
          So try deleting the MagicMirror folder and then use the automatic installer again.
          • L Offline
            L_i_v_e
            • L Offline
              L_i_v_e @cruunnerr
              @cruunnerr I went to jessie, tried again… it failed… reinstalled electron 3 times… still fails… always the same damn error…
              i think i’m gonna build my own webpage with blackjack and hookers…
              This is so incredible…
              • H Offline
                Homerj
                Hi
                i have the same Problem npm install electron@1.4.15 dasen`t work. it was of no use a blank mirror with the same error log.
                have now one any idea ???
                • L Offline
                  L_i_v_e @Homerj
                  @Homerj i’m desperate, 2 days no result… i’d love an img to flash with everything working… anyone?
                  • H Offline
                    Homerj
                    I have restored an old backup with which it ran with version 2.13 since 01:18 I have no chance to get it to work.
                    I have a rp3 with stretch on the run where synonymous fhem over it runs. if any one idea would be great
                    • L Offline
                      L_i_v_e @Homerj
                      @Homerj could you share it?
                        cruunnerr
                        @L_i_v_e
                        Ok i checked your earlier posts again.
                        U did execute the whole stuff as root user. Thats not necessary and even not good!
                        I don’t know what else u did as root, but maybe first try to delete the whole MagicMirror Folder and run the command without sudo.
                        bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                        Or try a new installation of the raspbian and begin with this (for a full raspbian) or this (for a lite raspbian) tutorial. Do it exactly as its wrote down!
                        L 2 Replies Last reply Reply Quote 0
                        • L Offline
                          L_i_v_e @cruunnerr
                          @cruunnerr From when sudo is a bad thing? I’ll try now
                          • L Offline
                            L_i_v_e @cruunnerr
                            @cruunnerr after an auto install without sudo, made it work starting the installation of electron for the 2nd time in it’s folder. Now everything runs smooth if i give him commands but 1:
                            -server only does not work, i can’t access it remotely
                            -pm2 start does not work, the display goes all black but no module is loaded, it stays black. I tried with both my old config and the example config
                            -maybe local launch does not work too? i have no idea since it’s really hard to connect a mouse and keyboard. If i use a VNC can i start it with npm start only?
                            any idea?
                            cruunnerrC 1 Reply Last reply Reply Quote 0
                              cruunnerr @L_i_v_e
                              @L_i_v_e said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                              Yes.
                              Since i started my project a few weeks/month ago i have had some trouble, too. But it was all about my inexperience. So at this point im out at all, sorry.
                              Hope someone can help you.
                              But if i said before: Reading the many tutorials and do it like it’s written there brought me to the goal.
                              Only difference to you was, that i was using the early magic mirror versions.
                              Maybe u should give it a last try with Version 2.1.3 and updating later or hoping that there are other guys who can help you. :(
                                carltonb
                                I too have the same problems. In another thread started a few days ago because I have the same issues.
                                Started with Stretch, then went back to an old Jessie Lite version.
                                I have done the automatic install, the manual install, as root and not as root.
                                All fail at the same place. I currently have 5 MM running on PI3, then the update came and tried on one device when it crashed. I will not touch the others until this is resolved.
                                If someone fixes this can they post the steps they used and a link to the image that they used as well.
                                This is getting very frustrating. All my mirrors went together in a matter of an hour or so with no problems. Setting the modules and css is another thing though.
                                Any help is very much appreciated.
                                carltonb
                                  cruunnerr
                                  Because i am very interested why there are so much problems i will install a complete new Raspbian and MagicMirror. Let me try, i will report soon
                                  • L Offline
                                    L_i_v_e
                                    Please let me know. If you make It work could you share It as an ISO ti flash? Would be so good
                                      carltonb
                                      I too am keeping abreast of this. I have had 5 installs that went so well that after the update, I can not get it installed.
                                      Are we the only ones having problems.
                                      Do the install directions need to be changed. Luckily I have backed up every sd card so I am safe, but need to figure out if I do anything to them now (besides the MM upgrade) will they crash.
                                        cruunnerr
                                        I think i figured out what went wrong ;)
                                        i set up a new raspbian (Desktop Version) and could install the MagicMirro without any issues.
                                        IMPORTANT:
                                        while the installation of MagicMirror (automatic installer) u will see this:
                                        Cloning MagicMirror Done!
                                        Installing dependencies ...
                                        npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                        npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                                        npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                                        > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
                                        > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                                        When u arrived this, it seems the installation is done. But wrong! just wait. it will take some time even if there is no cursor blinking.
                                        Just wait and you will see some more installation steps:
                                        Wait again:
                                        wait again ^^ and u will be asked if u want to use pm2. say YES! :
                                        Finally u will see this:
                                        And after a few seconds the magic mirror will start automatically and u can enjoy :D
                                        Edit:
                                        so just to get sure, here are the quick steps i did:
                                        1. loaded the newest raspbian stretch with desktop from here
                                        2. copy to SD card with ApplePi-Baker
                                        3. put an empty file named “ssh” on the boot directory to enable ssh
                                        4. start the pi
                                        5. via ssh sudo raspi-config
                                          set up some configurations like Network-Name, Screen resolution, enabled VNC, expand filesystem etc.
                                        6. reboot
                                        7. sudo apt-get update ; sudo apt-get upgrade
                                          this will take a while
                                        8. sudo rpi-update
                                          this will take a while, too
                                        9. reboot
                                        10. bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                                        Then just wait! ;)
                                          carltonb @cruunnerr
                                          @cruunnerr said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                                          VNC
                                          No NPM install or other necessary pi setup as listed on the site at Configuring the Raspberry Pi?
                                            cruunnerr
                                            @carltonb said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                                            Oh sorry, i enabled display rotate in the config. And to disable the screensaver i used sudo apt get install xscreensaver, then via VNC on the Desktop move to the upper left corner (the raspberry button) and go to Preference -> Screensaver and disable it.
                                            Maybe use sudo apt-get install unclutter to hide mouse.
                                            I just set it up to proof, if there are any issues ^^ So this was a quick install “guide”
                                            But yes, there is no extra npm install or something like that necessary.
                                            VNC can be enabled with raspi-config
                                            edit:
                                            oh, and keep in mind that u have to set pm2 to automatically start at reboot.
                                            maybe after the first restart after installation finished there is no automatically startet MagicMirror.
                                            https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                            L C 2 Replies Last reply Reply Quote 0
