    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 38.7k Views 8 Watching
    • L Offline
      L_i_v_e
      Just tried again following this guide:
      https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
      so:
      sudo apt-get update
      sudo apt-get upgrade
      sudo apt-get install xinit xserver-xorg
      sudo apt-get install lxde-core
      sudo apt-get install lightdm
      sudo apt-get install git
      sudo apt-get install libxss1
      sudo apt-get install libnss3
      sudo apt-get install unclutter
      then once it said to use the autoinstaller i went with manual installation.
      After git clone i cd into MM and tried npm install… Ofc i didn’t work cause of missing npm so i tried with the simplest sudo apt-get install npm. After that i tried to verify node version with node -v but it did not gave any response. I tried anyway with sudo npm install into mm folder and it started… after a while it failed. This is the error i got, log attached.
      [0_1515066236979_npm-debug.log](Uploading 100%)
      npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN engine webdriverio@4.9.11: wanted: {"node":">= 4.8.5"} (current: {"node":"4.8.2","npm":"1.4.21"})
      > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      sh: 1: node: not found
      npm WARN This failure might be due to the use of legacy binary "node"
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR! electron@1.4.15 postinstall: `node install.js`
      npm ERR! Exit status 127
      npm ERR!
      npm ERR! Failed at the electron@1.4.15 postinstall script.
      npm ERR! This is most likely a problem with the electron package,
      npm ERR! not with npm itself.
      npm ERR!     node install.js
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls electron
      npm ERR! System Linux 4.9.59-v7+
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v4.8.2
      npm ERR! npm -v 1.4.21
      npm ERR! code ELIFECYCLE
      > uws@0.14.5 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/uws
      > node-gyp rebuild > build_log.txt 2>&1 || exit 0
      > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      npm ERR! tar.unpack untar error /root/.npm/webdriverio/4.9.11/package.tgz
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • L Offline
        L_i_v_e @mafin
        @mafin could you give me the exact command lint you used? In that guide the only thing said about the installation is to use the automatic installer…
        Using it i’m stuck here: (is it complete or stuck?)
        pi@raspberrypi:~ $ sudo bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        Updating packages ...
        Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
        Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
        Reading package lists... Done
        Installing helper tools ...
        Building dependency tree
        build-essential is already the newest version (12.3).
        curl is already the newest version (7.52.1-5+deb9u3).
        git is already the newest version (1:2.11.0-3+deb9u2).
        unzip is already the newest version (6.0-21).
        wget is already the newest version (1.18-5+deb9u1).
        Node.js is not installed.
        Installing Node.js ...
        ## Installing the NodeSource Node.js v6.x repo...
        ## Populating apt-get cache...
        + apt-get update
        Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
        Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
        ## Confirming "stretch" is supported...
        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_6.x/dists/stretch/Release'
        ## Adding the NodeSource signing key to your keyring...
        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
        OK
        ## Creating apt sources list file for the NodeSource Node.js v6.x repo...
        + echo 'deb https://deb.nodesource.com/node_6.x stretch main' > /etc/apt/sources.list.d/nodesource.list
        + echo 'deb-src https://deb.nodesource.com/node_6.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
        ## Running `apt-get update` for you...
        + apt-get update
        Get:3 https://deb.nodesource.com/node_6.x stretch InRelease [4,635 B]
        Get:4 https://deb.nodesource.com/node_6.x stretch/main armhf Packages [1,006 B]
        Fetched 5,641 B in 2s (2,019 B/s)
        ## Run `apt-get install nodejs` (as root) to install Node.js v6.x and npm
        The following NEW packages will be installed:
          nodejs
        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
        Need to get 8,790 kB of archives.
        After this operation, 41.1 MB of additional disk space will be used.
        Get:1 https://deb.nodesource.com/node_6.x stretch/main armhf nodejs armhf 6.12.3-1nodesource1 [8,790 kB]
        Fetched 8,790 kB in 11s (771 kB/s)
        Selecting previously unselected package nodejs.
        (Reading database ... 63014 files and directories currently installed.)
        Preparing to unpack .../nodejs_6.12.3-1nodesource1_armhf.deb ...
        Unpacking nodejs (6.12.3-1nodesource1) ...
        Setting up nodejs (6.12.3-1nodesource1) ...
        Processing triggers for man-db (2.7.6.1-2) ...
        Node.js installation Done!
        Cloning MagicMirror ...
        Cloning into 'MagicMirror'...
        remote: Counting objects: 8976, done.
        remote: Compressing objects: 100% (8/8), done.
        remote: Total 8976 (delta 3), reused 3 (delta 1), pack-reused 8967
        Receiving objects: 100% (8976/8976), 11.48 MiB | 1.09 MiB/s, done.
        Resolving deltas: 100% (5077/5077), done.
        Cloning MagicMirror Done!
        Installing dependencies ...
        npm WARN prefer global coffee-script@1.10.0 should be installed with -g
        npm WARN prefer global jsonlint@1.6.2 should be installed with -g
        > uws@0.14.5 install /root/MagicMirror/node_modules/uws
        • cruunnerrC Offline
          cruunnerr
          No you are stuck ^^
          It is done. You can safely ignore warnings ;)
          Just copy and rename the sample config.js and start the mirror in the MagicMirror folder with using „npm Start“
          Or better use pm2
          Take a look at the great tutorials in the Forum.
          • L Offline
            L_i_v_e @cruunnerr
            @cruunnerr
            I won’t be so sure…
            ahahahaha
            > magicmirror@2.2.2 start /home/pi/MagicMirror
            > sh run-start.sh
            /home/pi/MagicMirror/node_modules/electron/index.js:9
              throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
            Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                at Module._compile (module.js:570:32)
                at Object.Module._extensions..js (module.js:579:10)
                at Module.load (module.js:487:32)
                at tryModuleLoad (module.js:446:12)
                at Function.Module._load (module.js:438:3)
                at Module.require (module.js:497:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
            npm ERR! Linux 4.9.59-v7+
            npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
            npm ERR! node v6.12.3
            npm ERR! npm  v3.10.10
            npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
            npm ERR!
            npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
            npm ERR! If you do, this is most likely a problem with the magicmirror package,
            npm ERR!     sh run-start.sh
            npm ERR!     npm bugs magicmirror
            npm ERR! Or if that isn't available, you can get their info via:
            npm ERR!     npm owner ls magicmirror
              cruunnerr
              didn’t expect that ^^
              try going to your MagicMirror folder and type npm install electron@1.4.15
              Maybe it will say, that this version is invalid.
              Check the version here: /home/pi/MagicMirror/node_modules/electron/dist/version
              or try it global sudo npm install -g electron@1.4.15
              Question: Did u first install it manually and then with the automatic installer?
              If so, did u delete your MagicMirror folder before using the automatic installer? If not, maybe this causes the error.
              So try deleting the MagicMirror folder and then use the automatic installer again.
              • L Offline
                L_i_v_e
                • L Offline
                  L_i_v_e @cruunnerr
                  @cruunnerr I went to jessie, tried again… it failed… reinstalled electron 3 times… still fails… always the same damn error…
                  i think i’m gonna build my own webpage with blackjack and hookers…
                  This is so incredible…
                  • H Offline
                    Homerj
                    Hi
                    i have the same Problem npm install electron@1.4.15 dasen`t work. it was of no use a blank mirror with the same error log.
                    have now one any idea ???
                    • L Offline
                      L_i_v_e @Homerj
                      @Homerj i’m desperate, 2 days no result… i’d love an img to flash with everything working… anyone?
                      • H Offline
                        Homerj
                        I have restored an old backup with which it ran with version 2.13 since 01:18 I have no chance to get it to work.
                        I have a rp3 with stretch on the run where synonymous fhem over it runs. if any one idea would be great
                        • L Offline
                          L_i_v_e @Homerj
                          @Homerj could you share it?
                            cruunnerr
                            @L_i_v_e
                            Ok i checked your earlier posts again.
                            U did execute the whole stuff as root user. Thats not necessary and even not good!
                            I don’t know what else u did as root, but maybe first try to delete the whole MagicMirror Folder and run the command without sudo.
                            Or try a new installation of the raspbian and begin with this (for a full raspbian) or this (for a lite raspbian) tutorial. Do it exactly as its wrote down!
                            L 2 Replies Last reply Reply Quote 0
                            • L Offline
                              L_i_v_e @cruunnerr
                              @cruunnerr From when sudo is a bad thing? I’ll try now
                              • L Offline
                                L_i_v_e @cruunnerr
                                @cruunnerr after an auto install without sudo, made it work starting the installation of electron for the 2nd time in it’s folder. Now everything runs smooth if i give him commands but 1:
                                -server only does not work, i can’t access it remotely
                                -pm2 start does not work, the display goes all black but no module is loaded, it stays black. I tried with both my old config and the example config
                                -maybe local launch does not work too? i have no idea since it’s really hard to connect a mouse and keyboard. If i use a VNC can i start it with npm start only?
                                any idea?
                                cruunnerrC 1 Reply Last reply Reply Quote 0
                                  cruunnerr @L_i_v_e
                                  @L_i_v_e said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                                  Yes.
                                  Since i started my project a few weeks/month ago i have had some trouble, too. But it was all about my inexperience. So at this point im out at all, sorry.
                                  Hope someone can help you.
                                  But if i said before: Reading the many tutorials and do it like it’s written there brought me to the goal.
                                  Only difference to you was, that i was using the early magic mirror versions.
                                  Maybe u should give it a last try with Version 2.1.3 and updating later or hoping that there are other guys who can help you. :(
                                    carltonb
                                    I too have the same problems. In another thread started a few days ago because I have the same issues.
                                    Started with Stretch, then went back to an old Jessie Lite version.
                                    I have done the automatic install, the manual install, as root and not as root.
                                    All fail at the same place. I currently have 5 MM running on PI3, then the update came and tried on one device when it crashed. I will not touch the others until this is resolved.
                                    If someone fixes this can they post the steps they used and a link to the image that they used as well.
                                    This is getting very frustrating. All my mirrors went together in a matter of an hour or so with no problems. Setting the modules and css is another thing though.
                                    Any help is very much appreciated.
                                    carltonb
                                      cruunnerr
                                      Because i am very interested why there are so much problems i will install a complete new Raspbian and MagicMirror. Let me try, i will report soon
                                      • L Offline
                                        L_i_v_e
                                        Please let me know. If you make It work could you share It as an ISO ti flash? Would be so good
                                          carltonb
                                          I too am keeping abreast of this. I have had 5 installs that went so well that after the update, I can not get it installed.
                                          Are we the only ones having problems.
                                          Do the install directions need to be changed. Luckily I have backed up every sd card so I am safe, but need to figure out if I do anything to them now (besides the MM upgrade) will they crash.
                                            cruunnerr
                                            I think i figured out what went wrong ;)
                                            i set up a new raspbian (Desktop Version) and could install the MagicMirro without any issues.
                                            IMPORTANT:
                                            while the installation of MagicMirror (automatic installer) u will see this:
                                            > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
                                            When u arrived this, it seems the installation is done. But wrong! just wait. it will take some time even if there is no cursor blinking.
                                            Just wait and you will see some more installation steps:
                                            Wait again:
                                            wait again ^^ and u will be asked if u want to use pm2. say YES! :
                                            Finally u will see this:
                                            And after a few seconds the magic mirror will start automatically and u can enjoy :D
                                            Edit:
                                            so just to get sure, here are the quick steps i did:
                                            1. loaded the newest raspbian stretch with desktop from here
                                            2. copy to SD card with ApplePi-Baker
                                            3. put an empty file named “ssh” on the boot directory to enable ssh
                                            4. start the pi
                                            5. via ssh sudo raspi-config
                                              set up some configurations like Network-Name, Screen resolution, enabled VNC, expand filesystem etc.
                                            6. reboot
                                            7. sudo apt-get update ; sudo apt-get upgrade
                                              this will take a while
                                            8. sudo rpi-update
                                              this will take a while, too
                                            9. reboot
                                            10. bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                                            Then just wait! ;)
