    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 36.6k Views 8 Watching
      mafin
      I just installed magicmirror on a clean Raspberry Pi 3 with raspian OS.
      After installing and trying to start in the MM directory with npm start I will get the error message:
      > magicmirror@2.2.2 start /home/pi/MagicMirror
      > sh run-start.sh
      npm ERR! Linux 4.9.73-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
      npm ERR! node v6.12.3
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      pi@raspi_3:~/MagicMirror $ cat npm-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@3.10.10
      3 info using node@v6.12.3
      5 info lifecycle magicmirror@2.2.2~prestart: magicmirror@2.2.2
      6 silly lifecycle magicmirror@2.2.2~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.2.2~start: magicmirror@2.2.2
      8 verbose lifecycle magicmirror@2.2.2~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.2.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.2.2~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.2.2~start: Args: [ '-c', 'sh run-start.sh' ]
      12 silly lifecycle magicmirror@2.2.2~start: Returned: code: 1  signal: null
      13 info lifecycle magicmirror@2.2.2~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.2.2 start: `sh run-start.sh`
      14 verbose stack Exit status 1
      14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
      14 verbose stack     at emitTwo (events.js:106:13)
      14 verbose stack     at EventEmitter.emit (events.js:191:7)
      14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
      14 verbose stack     at ChildProcess.emit (events.js:191:7)
      14 verbose stack     at maybeClose (internal/child_process.js:920:16)
      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      15 verbose pkgid magicmirror@2.2.2
      16 verbose cwd /home/pi/MagicMirror
      17 error Linux 4.9.73-v7+
      18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
      19 error node v6.12.3
      20 error npm  v3.10.10
      21 error code ELIFECYCLE
      22 error magicmirror@2.2.2 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error     sh run-start.sh
      23 error You can get information on how to open an issue for this project with:
      23 error     npm bugs magicmirror
      23 error Or if that isn't available, you can get their info via:
      23 error     npm owner ls magicmirror
      23 error There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      Tried to update nodejs and npm but they are OK, does anyone had the same problem and knows a workaroud?
      Thank you very much
      Regards,
      Max
      • L Offline
        L_i_v_e
        I guess u are in stretch. I’m on a rpi 3 and i find impossible to start MM. I’ll dpwngrade to Jessie and try again. If It does not work you can always make an HTML page and use chromium fullscreen
        • cruunnerrC Offline
          cruunnerr
          Well, i am using Raspberry Pi 3 with raspbian stretch lite and it works great.
          what OS are u using?
          Did u use the automatic installer or u did it manually?
          via ssh u have to use: DISPLAY=:0 npm start
          • cowboysdudeC Offline
            Install it manually not via the installer…too many issues.
            • L Offline
              L_i_v_e
              I have stretch full (mm owner said lite not supported in a comment in this forum)
              I tried both automatic and manual installation, i tried with both node js 9.3.0 and the automatic node update from MM.
              How you installed It? What node version? Did u use -g after npm install?
              Btw i work only from SSH, to make It start i used pm2 before this new clean install
              I think my installer can’t install electron from what i read at installation fail
                cruunnerr
                i did it exactly as wrote in this tutorial:
                https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
                only difference:
                i used Raspbian stretch lite and to disable the screensaver i used xscreensaver
                does need a little bit longer because u need to install the dependancies first, but it runs from the beginning without issues.
                but to be on the safety side, you can use raspbian jesse full as many users wrote about problems with stretch
                  mafin
                  Thank you for your answers.
                  I am using stretch, see the cat /etc/os-release
                  PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="9"
                  VERSION="9 (stretch)"
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                  I followed the steps in this guide Complete Setup Tutorial
                  DISPLAY=:0 npm start can not solve the problem.
                  I will try to install MM with the Guide on GitHub you posted and I will see that comes out.
                  I will keep you updated.
                  EDIT: So I followed the guide on GitHub and it works perfectly.
                  Thank you very much for this suggestion.
                  • L Offline
                    L_i_v_e
                    Just tried again following this guide:
                    so:
                    sudo apt-get update
                    sudo apt-get upgrade
                    sudo apt-get install xinit xserver-xorg
                    sudo apt-get install lxde-core
                    sudo apt-get install lightdm
                    sudo apt-get install git
                    sudo apt-get install libxss1
                    sudo apt-get install libnss3
                    sudo apt-get install unclutter
                    then once it said to use the autoinstaller i went with manual installation.
                    After git clone i cd into MM and tried npm install… Ofc i didn’t work cause of missing npm so i tried with the simplest sudo apt-get install npm. After that i tried to verify node version with node -v but it did not gave any response. I tried anyway with sudo npm install into mm folder and it started… after a while it failed. This is the error i got, log attached.
                    [0_1515066236979_npm-debug.log](Uploading 100%)
                    npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                    npm WARN engine webdriverio@4.9.11: wanted: {"node":">= 4.8.5"} (current: {"node":"4.8.2","npm":"1.4.21"})
                    > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                    > node install.js
                    sh: 1: node: not found
                    npm WARN This failure might be due to the use of legacy binary "node"
                    npm WARN For further explanations, please read
                    /usr/share/doc/nodejs/README.Debian
                    npm ERR! electron@1.4.15 postinstall: `node install.js`
                    npm ERR! Exit status 127
                    npm ERR!
                    npm ERR! Failed at the electron@1.4.15 postinstall script.
                    npm ERR! This is most likely a problem with the electron package,
                    npm ERR!     node install.js
                    npm ERR! You can get their info via:
                    npm ERR!     npm owner ls electron
                    npm ERR! System Linux 4.9.59-v7+
                    npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
                    npm ERR! cwd /home/pi/MagicMirror
                    npm ERR! node -v v4.8.2
                    npm ERR! npm -v 1.4.21
                    > uws@0.14.5 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/uws
                    > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                    > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
                    > node ./download-chromedriver.js
                    npm ERR! tar.unpack untar error /root/.npm/webdriverio/4.9.11/package.tgz
                    npm ERR!
                    npm ERR! Additional logging details can be found in:
                    npm ERR! not ok code 0
                    • L Offline
                      L_i_v_e @mafin
                      @mafin could you give me the exact command lint you used? In that guide the only thing said about the installation is to use the automatic installer…
                      Using it i’m stuck here: (is it complete or stuck?)
                      pi@raspberrypi:~ $ sudo bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                              \______/
                      Updating packages ...
                      Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                      Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
                      Reading package lists... Done
                      Installing helper tools ...
                      Building dependency tree
                      build-essential is already the newest version (12.3).
                      curl is already the newest version (7.52.1-5+deb9u3).
                      git is already the newest version (1:2.11.0-3+deb9u2).
                      unzip is already the newest version (6.0-21).
                      wget is already the newest version (1.18-5+deb9u1).
                      Node.js is not installed.
                      Installing Node.js ...
                      ## Installing the NodeSource Node.js v6.x repo...
                      ## Populating apt-get cache...
                      + apt-get update
                      Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                      Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                      ## Confirming "stretch" is supported...
                      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_6.x/dists/stretch/Release'
                      ## Adding the NodeSource signing key to your keyring...
                      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                      OK
                      ## Creating apt sources list file for the NodeSource Node.js v6.x repo...
                      + echo 'deb https://deb.nodesource.com/node_6.x stretch main' > /etc/apt/sources.list.d/nodesource.list
                      + echo 'deb-src https://deb.nodesource.com/node_6.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
                      ## Running `apt-get update` for you...
                      + apt-get update
                      Get:3 https://deb.nodesource.com/node_6.x stretch InRelease [4,635 B]
                      Get:4 https://deb.nodesource.com/node_6.x stretch/main armhf Packages [1,006 B]
                      Fetched 5,641 B in 2s (2,019 B/s)
                      ## Run `apt-get install nodejs` (as root) to install Node.js v6.x and npm
                      The following NEW packages will be installed:
                        nodejs
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 8,790 kB of archives.
                      After this operation, 41.1 MB of additional disk space will be used.
                      Get:1 https://deb.nodesource.com/node_6.x stretch/main armhf nodejs armhf 6.12.3-1nodesource1 [8,790 kB]
                      Fetched 8,790 kB in 11s (771 kB/s)
                      Selecting previously unselected package nodejs.
                      (Reading database ... 63014 files and directories currently installed.)
                      Preparing to unpack .../nodejs_6.12.3-1nodesource1_armhf.deb ...
                      Unpacking nodejs (6.12.3-1nodesource1) ...
                      Setting up nodejs (6.12.3-1nodesource1) ...
                      Processing triggers for man-db (2.7.6.1-2) ...
                      Node.js installation Done!
                      Cloning MagicMirror ...
                      Cloning into 'MagicMirror'...
                      remote: Counting objects: 8976, done.
                      remote: Compressing objects: 100% (8/8), done.
                      remote: Total 8976 (delta 3), reused 3 (delta 1), pack-reused 8967
                      Receiving objects: 100% (8976/8976), 11.48 MiB | 1.09 MiB/s, done.
                      Resolving deltas: 100% (5077/5077), done.
                      Cloning MagicMirror Done!
                      Installing dependencies ...
                      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                      > uws@0.14.5 install /root/MagicMirror/node_modules/uws
                        cruunnerr
                        No you are stuck ^^
                        It is done. You can safely ignore warnings ;)
                        Just copy and rename the sample config.js and start the mirror in the MagicMirror folder with using „npm Start“
                        Or better use pm2
                        Take a look at the great tutorials in the Forum.
                        • L Offline
                          L_i_v_e @cruunnerr
                          @cruunnerr
                          I won’t be so sure…
                          ahahahaha
                          > sh run-start.sh
                          /home/pi/MagicMirror/node_modules/electron/index.js:9
                            throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                              at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                              at Module._compile (module.js:570:32)
                              at Object.Module._extensions..js (module.js:579:10)
                              at Module.load (module.js:487:32)
                              at tryModuleLoad (module.js:446:12)
                              at Function.Module._load (module.js:438:3)
                              at Module.require (module.js:497:17)
                              at require (internal/module.js:20:19)
                              at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                          npm ERR! Linux 4.9.59-v7+
                          npm ERR!
                            cruunnerr
                            didn’t expect that ^^
                            try going to your MagicMirror folder and type npm install electron@1.4.15
                            Maybe it will say, that this version is invalid.
                            Check the version here: /home/pi/MagicMirror/node_modules/electron/dist/version
                            or try it global sudo npm install -g electron@1.4.15
                            Question: Did u first install it manually and then with the automatic installer?
                            If so, did u delete your MagicMirror folder before using the automatic installer? If not, maybe this causes the error.
                            So try deleting the MagicMirror folder and then use the automatic installer again.
                            • L Offline
                              L_i_v_e
                              • L Offline
                                L_i_v_e @cruunnerr
                                @cruunnerr I went to jessie, tried again… it failed… reinstalled electron 3 times… still fails… always the same damn error…
                                i think i’m gonna build my own webpage with blackjack and hookers…
                                This is so incredible…
                                • H Offline
                                  Homerj
                                  Hi
                                  i have the same Problem npm install electron@1.4.15 dasen`t work. it was of no use a blank mirror with the same error log.
                                  have now one any idea ???
                                  • L Offline
                                    L_i_v_e @Homerj
                                    @Homerj i’m desperate, 2 days no result… i’d love an img to flash with everything working… anyone?
                                    • H Offline
                                      Homerj
                                      I have restored an old backup with which it ran with version 2.13 since 01:18 I have no chance to get it to work.
                                      I have a rp3 with stretch on the run where synonymous fhem over it runs. if any one idea would be great
                                      • L Offline
                                        L_i_v_e @Homerj
                                        @Homerj could you share it?
                                          cruunnerr
                                          @L_i_v_e
                                          Ok i checked your earlier posts again.
                                          U did execute the whole stuff as root user. Thats not necessary and even not good!
                                          I don’t know what else u did as root, but maybe first try to delete the whole MagicMirror Folder and run the command without sudo.
                                          Or try a new installation of the raspbian and begin with this (for a full raspbian) or this (for a lite raspbian) tutorial. Do it exactly as its wrote down!
                                          L 2 Replies Last reply Reply Quote 0
                                          • L Offline
                                            L_i_v_e @cruunnerr
                                            @cruunnerr From when sudo is a bad thing? I’ll try now
