    MMM-Slack stop randomise messages
    14 Posts 4 Posters 10.0k Views 4 Watching
    • saibamS
      saibam
      I am trying to get rid of the randomiser in MMM-Slack module. I want the messages to show in order from oldest to newest. I’m sure I’m approaching it the wrong way but I just can’t get it to work without the randomiser. Pls help!
      saibamS mediathreatM 2 Replies Last reply Reply Quote 0
      • saibamS
        saibam @saibam
        if(this.slackMessages.length > 0) {
             var randomMessageId = Math.floor(Math.random() * this.slackMessages.length);
             var randomMessage = this.slackMessages[randomMessageId].message;
        I want just ‘x’ instead of the ‘randomMessageId’ on the last line and can’t figure out how to do it.
        • N
          ninjabreadman @saibam
          Hi @saibam,
          Just change:
          to the following:
          var randomMessageId = 0;
          It should work (unrandomizing the order), so long as the slackMessages array is in ascending order. If not, and it’s in descending order, set to this.slackMessages.length - 1 instead of 0.
          saibamS 1 Reply Last reply Reply Quote 0
          • saibamS
            saibam @ninjabreadman
            @ninjabreadman thanks for the answer but this will only show the latest message. I solved it in a rather long but still nice way. The idea is to show the latest 10 messages and when a new message is sent it will show it instantly.
            currentMessageCount and currentMessgeId are global variables instantiated to 0. emoji_replace is my own function to include emojis in the message.
            if (currentMessageCount < this.slackMessages.length || currentMessageCount == 0){
            	currentMessageId = 0;
            	currentMessageCount = this.slackMessages.length;
            var maxAllowed = 10;
            var topMessages = this.slackMessages.slice(0, (maxAllowed - 1));
            var maxCount = Math.min(maxAllowed, topMessages.length);
            if (currentMessageId == maxCount - 1) { currentMessageId = 0; }
            var currentMessage = topMessages[currentMessageId].message;
            currentMessage = emoji_replace(currentMessage);
            messageElement.innerHTML = currentMessage;
            currentMessageId ++;
            • G
              gekberlin @saibam
              @saibam That sounds pretty good. I wanted to achive the same for the last 5 messages. So i would simpley exchange the 10 for a 5. But where do I have to put the code into ? In the mmm-slack.js ?
              I would relay appreciate any help.
              • saibamS
                saibam @gekberlin
                @gekberlin Yes. Change maxAllowed to 5. Put it in MMM-Slack.js under the getDom: function() where it creates the html elements. I also noticed that it didnt work as expected where I had (maxCount -1) and (maxAllowed - 1). I removed the -1 and it worked like a charm.
                G 1 Reply Last reply Reply Quote 1
                • G
                  gekberlin @saibam
                  @saibam Thanks for your fast reply!
                  I’ve put in the code but then I didn’t get any message displayed anymore.
                  Did I have done something wrong ?
                  	getDom: function() {
                  		var messageElement = document.createElement('div');
                  var maxAllowed = 5;
                  var topMessages = this.slackMessages.slice(0, (maxAllowed 0));
                  if (currentMessageId == maxCount 0) { currentMessageId = 0; }
                  		return messageElement;
                  • saibamS
                    saibam @gekberlin
                    @gekberlin Yes.
                    will not work as emoji_replace is my own function for replacing :smiley: with an emoji.
                    so just get rid of that line and it will work.
                    And you will also have to instantiate currentMessageId and currentMessageCount globally. I.e.
                    var currentMessageId = 0
                    var currentMessageCount = 0
                    at the top of the js file.
                    • mediathreatM
                      mediathreat @saibam
                      @saibam Which Slack token do you use to connect to slack and do you have to put the leading # hash sign in the config file for the channel where it listens?
                      saibamS 2 Replies Last reply Reply Quote 0
                      • saibamS
                        saibam @mediathreat
                        @mediathreat we followed the link in the readme https://api.slack.com/tokens and from there we created our own app. I’m sorry I can’t find where I found the token in there, you will have to try and error your way :) I will keep looking some but can’t guarantee I find anything. Slack API pages are a mess imo. And no you don’t need the leading # in the config file.
                        • saibamS
                          saibam @mediathreat
                          @mediathreat here is the correct link to create your token: https://api.slack.com/custom-integrations/legacy-tokens
                          mediathreatM 1 Reply Last reply Reply Quote 0
                          • mediathreatM
                            mediathreat
                            Thanks! This nailed it perfectly! Hopefully the MMM-SLACK package maintainer might add this info to be clearer. Now that I have it working, I wonder if I can go in and see if I can add showing photos from a slack channel to the code base
                            • mediathreatM
                              mediathreat @saibam
                              @saibam do you think its possible to modify the code to get images or links that are posted into the slack channel and display them on the magic mirror?
                              • saibamS
                                saibam @mediathreat
                                @mediathreat I think it is possible, as long as the images have some kind of html address or similar, but I have no idea how to do it. I’ve moved on to other projects now :) almost finished an arcade cabinet :D
