    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • cruunnerrC
      cruunnerr
      1. Can u turn on GPIO27 with gpio -g write 27 1 and off with gpio -g write 27 0 ?
      2. Have u tried just to connect a LED on GPIO27 ?
      3. What relay do u use and how exactly is it connected? ?
        MadScientist
        Hmm, I get
        Unable to determine hardware version. I see: Hardware   : BCM2835
         - expecting BCM2708 or BCM2709. Please report this to projects@drogon.net
        when I run gpio -g write 27 1 .
        randomnoiseR 1 Reply Last reply
        • cruunnerrC
          cruunnerr
          @MadScientist said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
          Huh… a quick google search tells, that this could be several causes. Some wrote to update or downgrade the kernel., some wrote to update wiring pi and so on.
          So its not a problem of the module at all. I’m sorry but for the first u should try to google.
          Maybe start with this: https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=182191
          However you should start a new thread if you cannot get to target :(
          • randomnoiseR
            randomnoise @MadScientist
            Hmm, I get
            I had the same issue. I just followed the instructions on the wiring pi site to install. Don’t have my notes but there was a different version depending if you use wiringpi or wiring-pi. I’ll see if I can find the right one.
            • randomnoiseR
              randomnoise
              So I think as wiring-pi is the npm specific version the reason it didn’t work was because they haven’t compiled it to work with the pi3 chip.
              Try http://wiringpi.com/download-and-install/
                MadScientist
                Thanks so far. I did npm uninstall wiring-pi and installed wiringpi via git. Now I don’t get the error anymore but the relay still does nothing. It’s getting late and won’t have the time today anymore to look into it. Let me know if you have other ideas and I will continue tomorrow.
                Thanks so far.
                • randomnoiseR
                  randomnoise
                  I think I kept the npm wiring-pi on there as well… There’s probably some other stuff in there that makes it work in mm.
                  • cruunnerrC
                    cruunnerr
                    U could also quick try the script from this tutorial (at point 5). It will be done in 2 minutes ^^
                    Maybe u missed the connection?
                      MadScientist
                      Two minutes if you know what you’re doing…
                      The problem is I don’t have a button. I did create the relay.py script and run it. It triggers the relay exactly once and then stays like this. I can’t even stop the script anymore once it’s running…
                      Man, I really thought setting up the relay would be as easy as adding one line to the config. Wish I had tried to set it up earlier.
                      Still need help with this. :-(
                      • cruunnerrC
                        cruunnerr
                        Ah I see…
                        I will write u this evening. We will get it working ;)
                          MadScientist
                          Thank you so much!
                          • cruunnerrC
                            cruunnerr
                            @MadScientist
                            Alright…
                            Because your relay turns on i think you did everything right. Probably there is a problem with your Module installation… but thats just a guess. Maybe u didn’t give the module the rights to turn on gpio’s?
                            sudo usermod -a -G gpio pi (the „pi“ at the end stands for your username)
                            If u did that and it doesn’t work at all you can try to do it with an external script. Follow these steps:
                            cd
                            nano monitor_on.sh
                            put in this:
                            gpio -g mode 27 out
                            sleep 0.2
                            gpio -g write 27 1
                            save with “ctrl+x” and “y”
                            nano monitor_off.sh
                            put in this:
                            gpio -g mode 27 out
                            sleep 0.2
                            gpio -g write 27 0
                            chmod +x monitor_on.sh (to make it executable)
                            chmod +x monitor_off.sh
                            nano pir.py
                            put in this:
                            #!/usr/bin/env python
                            import sys
                            import time
                            import RPi.GPIO as io
                            import subprocess
                            io.setmode(io.BCM)
                            SHUTOFF_DELAY = 120 # in seconds, how long the monitor will be on until next button press or PIR detection
                            PIR_PIN = 22       # 15 on the board (this needn't to be a PIR. Can be a button also)
                            LED_PIN = 16      # optional
                            def main():
                                io.setup(PIR_PIN, io.IN)
                                io.setup(LED_PIN, io.OUT)
                                turned_off = False
                                last_motion_time = time.time()
                                while True:
                                    if io.input(PIR_PIN):
                                        io.output(LED_PIN, io.LOW)
                                        print ".",
                                        sys.stdout.flush()
                                        if turned_off:
                                            turned_off = False
                                            turn_on()
                                    else:
                                        if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                            turned_off = True
                                            turn_off()
                                        if not turned_off and time.time() > (last_motion_time + 1):
                                            io.output(LED_PIN, io.HIGH)
                                    time.sleep(.1)
                            def turn_on():
                            	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                            def turn_off():
                            	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                            if __name__ == '__main__':
                                try:
                                    main()
                                except KeyboardInterrupt:
                                    io.cleanup()
                            chmod +x pir.py
                            You can check if your button works by simply typing python pir.py. Every time u move through the PIR or press the button it will show you several …
                            End the test with “ctrl+c”
                            The Shutoff delay in the script defines how long the relay will be turned on after detection through the pir.
                            If that works u can add the script to the rc.local to start it automatically when booting up.
                              MadScientist
                              Ok, I did all that and I do get the “…” when I run the pir.py, but the relay doesn’t get triggered. Tried the monitor_oX.sh with and without sudo. Maybe I should just start all over new. Everything seems to be a bit messed up. I reverted back to motion detector only and also that isn’t working anymore in MM.
                              Edit: Started a new thread here.
                              • cruunnerrC
                                cruunnerr
                                @MadScientist
                                sorry, did a mistake. I edited my post above. just edit the *.sh files.
                                  MadScientist
                                  Thanks a lot to cruunnerr, who has the patience of an angel!
                                  I think there were two problems in my case and I write them here in case someone else has trouble getting the PIR+relay to work.
                                  First: By installing the MMM-PIR-sensor module I used the wrong wiring-pi. npm install wiring-pi installs an old version (2.25) which - so I’ve read - doesn’t work with the Raspberyy Pi 3. It’s best to install wiringpi according to this site.
                                  Second: I used a relay which was supposed to run on 3V to 7V, but apparently that’s not the case. I guess the seller shipped the wrong relay. So I had an old relay lying around which should only run on 5V but it works nicely on my RPi.
                                  Now everything is working, except I get some phantom triggers of the relay every couple of minutes. But I will look into it once everything is set up completely. Maybe I have something around here that can trigger the PIR sensor even if it’s covered by a cloth.
                                  • cruunnerrC
                                    cruunnerr
                                    @MadScientist
                                    that is nice to know… So wiring-pi installs an old version?! Than i need to update my tutorial ^^Thanks mate
                                    And how do you connect the relay? What relay do u use? is it active low or active high? U can try to connect a transistor or an pull up/down resistor to it, so that should disable the trigger from it. If u want to try i can send an image how to connect. It can also be, that your Power supply of the RPi is to small…
                                      MadScientist
                                      The is connected to pin 15 (GPIO 27), 17 (3.3V), and 20 (GND). I tried to post a link to the it, but then this post is flagged as spam. It’s just a cheap relay from Aliexpress.
                                      No idea if that relay is active high or low, but does it matter? It just switches between to connections, so if the relay port 1-2 or 2-3 are active shouldn’t matter, right?
                                      I am using a 3.1A power supply for the Pi. Later I will connected it via a 8A buck-boost-module to a 12V/5A power supply that will power the screen. The Pi will get the power from before the relay so it won’t switch itself off ;-)
                                      Please send a picture, I will gladly try, once I have the extra party I might need (transistor or resistor).
                                      • cruunnerrC
                                        cruunnerr
                                        I am sorry bro, but u did it wrong :(
                                        U need to connect the relay with the 5v pin! Look at my tutorial at around Point 5. There is a picture how to connect. Just leave the button away
                                        Relay                        Raspberry
                                        +                            Pin 2 or 4 (5V)
                                        -                            Pin 6 or any other GND (GND)
                                        in                           PIN 13 (GPIO 27)
                                          MadScientist
                                          I did that in the very beginning but then relay isn’t working at all. It only works with 3.3V. No idea why.
                                          • randomnoiseR
                                            @MadScientist
                                            That pretty much sums up my experience as well… I used to have the pir module working great (I didn’t use a relay, just screen off/on). It started acting up so I tried all of the following:
                                            Using script
                                            Putting pir sensor in a box to avoid trigger sources
                                            A different pir sensor (same type as I had previously working)
                                            Completely different type of pir sensor
                                            Complete rebuild of pi from scratch & reinstall mm.
                                            An acoustic noise driven sensor.
                                            No matter what I did I get random triggers usually every couple of mins. All I can think is its either an issue with the input ‘floating’ and being pulled down (all though tried pull up & pull down option in wiring pi).
                                            Only thing I can think is that I’ve possibly fried my gpio somehow.
                                            Anyway I went with a pir / relay which is stand alone so doesn’t use the pi to turn monitor on / off.
                                            Be interested if you ever manage to resolve the random triggers.
                                            • 2 / 9
