MMM-PIR-Sensor wont do anything
2 Posts 1 Posters 1.2k Views 1 Watching
  • T Offline
    TS77UK
    This is really bugging me! Ok, I am new to Pi programming but I have knowledge of a few programming languages and can usually tweak my head around problems but this has really stumped me!
    I turned the PIR sensor away from me to show no movement. When I use “sudo ./test.sh” I get a load of 0’s on the screen displaying no movement. When I wave my hand in front I get a load of 1’s. So its working correctly.
    I setup MMM-PIR-Sensor and change the pin from default to number 7 in the config file. Nothing happens on the screen. It doesn’t switch off when it senses no movement (like its supposed to)
    This is my test.sh code (which works):
    echo "4" > /sys/class/gpio/export
    echo "in" > /sys/class/gpio/gpio4/direction
    while true;  do
            trap 'echo "4" > /sys/class/gpio/unexport' 0
            stat=`cat /sys/class/gpio/gpio4/value`
            echo $stat
    done
    exit 0
    And my config code:
    module: 'MMM-PIR-Sensor',
    sensorPIN: 7
    I just know its something simple but I am stumped!
    • T Offline
      TS77UK
      @TS77UK said in MMM-PIR-Sensor wont do anything:
      echo “4” > /sys/class/gpio/export
      Ignore that! I was looking at the wrong pin map for my model Pi! I should have been in number 4 not 7! As soon as I typed it I realised the answer lol
      Thank you for your time
