    Creating a module with existing Nodejs client?
    3 Posts 2 Posters 1.4k Views 3 Watching
      Baxer
      Is it possible to create a module with a existing Nodejs Client?
      • N Offline
        ninjabreadman @Baxer
        @Baxer An API (and client) give you a way to ask for information; it doesn’t stipulate what information to request, or how to display it. However, you could use MagicMirror-Module-Template then run npm install --save open-shl within your module folder to install open-shl.
        You would then add the code featured here to load the API and start querying data. I recommend loading the API in your node_helper.js and passing back the data to display via this.sendSocketNotification(notification, payload).
          Baxer @ninjabreadman
          @ninjabreadman Thanks for the explanation!!
