Calendar module width limit
3 Posts 2 Posters 2.6k Views 2 Watching
  • Y Offline
    yomm
    Hello all !
    My installation is on a rpi3. My mirror/screen is a 20’ with a 1650*1050 resolution. MM² and modules are up to date.
    I use Calendar module for a while, his position on the mirror is top_left.
    Recently I add some other calendars with some long name meetings.
    I got a strange behavior : the calendar module expands from the left of the screen to the middle. This happens when long name event are schedule.
    I tried MyCalendar module which is based on Calendar. Same thing happens.
    So is there a way to limit the width of the calendar module to prevent it spreading on the half of the screen ?
    Thanks for your help !
    N 1 Reply Last reply Feb 24, 2018, 10:53 PM Reply Quote 0
    • N Offline
      ninjabreadman @yomm
      @yomm There are different regions, but most will expand to try to accommodate your content/text.
      See this post moments ago here, where I give advice on how to limit the width. In your case, I believe the selector is .module.calendar.
      You can also use the CSS word-wrap property to make your events break to the next line, or text-overflow to display an ellipsis when they’re cut off.
      • Y Offline
        yomm
        Thank you ninjjabreadman !
        Exactly what I need !
        .module.MMM-MyCalendar {
        max-width: 300px;
