Face Recognition - File can't be opened for writing
Well the Mirror and the modules are working for now.
The next step is to seperate modules to specific users so i use the FaceRec lib.
I trained 10 images first for a quick test.
When im trying to start MMv2 with this module he pushes this error message:[MMM-Facial-Recognition] Facerecognition started... [MMM-Facial-Recognition] Loading training data... [MMM-Facial-Recognition] ALGORITHM: LBPH Whoops! There was an uncaught exception... { [Error: OpenCV Error: Unspecified error (File can't be opened for writing!) in load, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp, line 325 Traceback (most recent call last): File "modules/MMM-Facial-Recognition/facerecognition/facerecognition.py", line 59, in <module> model.load(json.loads(sys.argv[1])["trainingFile"]) cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp:325: error: (-2) File can't be opened for writing! in function load >] executable: 'python', options: null, script: 'modules/MMM-Facial-Recognition/facerecognition/facerecognition.py', args: [ '{"recognitionAlgorithm":1,"lbphThreshold":50,"fisherThreshold":250,"eigenThreshold":3000,"useUSBCam":false,"trainingFile":"~/MagicMirror/modules/MMM-Facial-Recognition/training.xml","interval":1,"logoutDelay":15,"users":["Marvin"],"defaultClass":"default","forAllClass":"for_all"}' ], exitCode: 1 } MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
Looks like it doesn’t have permission to open your trainingFile:
model.load(json.loads(sys.argv[1])[“trainingFile”]) cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp:325: error: (-2) File can’t be opened for writing! in function load
Notice the
message.Wherever it’s trying to create that file, the main process running MM can’t write to that location.
Probably it does not even exist in that path. Be sure to add the training file path to the conduct of put it in the module folder.
The XML file is located in the module path mmm-facial-recognition.
I will answer more precisely when I’m back hat home -
So, my internet is back after a day :D
I reinstalled the module with deleting & cloning it again.
The training.xml is located in
/home/pi/MagicMirror/modules/MMM-Facial-Recognition
I installed open cv with
sudo apt-get install libopencv-dev python-opencv
after this, i went into the folder
and typed
sudo npm install
I still get the same error MSG :(
i also changed the rights on the training.xml to Anyone/Anyone/Anyone
please help <3
@feuerball try putting it somewhere else and set the
trainingFile
setting in your config :) -
well i rewrote the destination of the file @ the config again and now it works.
seems like there was an error anywhere :D
@feuerball I didn’t understand what is the config
I am having the same error
