    Schedule Module with XML/Feed source
    5 Posts 3 Posters 3.0k Views 3 Watching
    • kruemelK Offline
      kruemel
      Hello
      Iam looking for help to fulfill my girlfriends request :-)
      I was able to filter out the course plan for her with feed43
      http://feed43.com/5546442377204284.xml (xml example 1)
      http://feed43.com/6082708764845543.xml (xml example 2)
      Now i need to be able to display this feed data like this module:
      https://github.com/pinsdorf/MMM-WeeklySchedule
      But not filled from the config file. Instead from the sources above.
      I think you understand it, otherwise ask me to explain it more detailed ;)
      Example:
      ONE Training Center
      Today
      8:30 - 9:25 Spinning
      8:30 - 9:25 Fun Tone
      9:30 - 10:25 Power Yoga
      (Data from xml file 1)
      Tomorrow
      8:30 - 9:25 Dances
      9:30 - 10:25 BODYPUMP
      (Data from xml file 2)
      So, a mix of the newsfeed and WeeklySchedule module i think ^^
      I did not found a similar solution, maybe someone know one or can help me because iam not a programmer :/
      Thank you very much!
      • N Offline
        ninjabreadman @kruemel
        @kruemel You can make a mashup of MMM-WeeklySchedule for display and MMM-HTTPRequestDisplay to fetch data which handles an XML response.
        • kruemelK Offline
          kruemel
          Thank you ninjabreadman but this is to high for me ^^ i cant code
            shakir
            is there an example where we change the quoted text in WeeklySchedule to XML. the Chicago CTA api is what i’m trying to resolve to a schedule based on the array they return
            like here - https://www.dmcinfo.com/latest-thinking/blog/id/8568/cta-bus-tracking-with-the-raspberry-pi
            • sorry if this is super basic
            • N Offline
              ninjabreadman @shakir
              Hi @shakir, I suggest you switch to using a JSON (vs XML) response. You just need to add &format=json to your query URL, according to the API documentation from CTA. Then you can look at any of the transit modules for MM, most of which handle a JSON response. It might even be easier to modify one of those than MMM-WeeklySchedule. Personally, I did something similar with MMM-json-feed customizing the output to show what I wanted from the json feed for my nearest bus stop.
