    OwnCloud integration
    Scheduled Pinned Locked Moved Unsolved General Discussion
    13 Posts 7 Posters 13.0k Views 7 Watching
      Shampooman
      I would also like to sync the MM with my owncloud calendar. The bad news is, that you need a username and a password for the owncloud ical file. I didn’t find an option to enter a user and password in the MM-Modul. So I tried to do a workaround (this project is my first expirience with JS, so it’s pretty hard for me to understand.) I found a little bash script to download the ical file to my homefolder. But I can’t enter the homefolder location with the MM-Modul. Perhaps someone has a good idea to do this job. :)
      #!/bin/bash
      ical=‘http://ownclouddomain.de/remote.php/caldav/calendars/admin/blubb?export’
      dir=/home/pi/
      user=‘admin’
      pw=‘blablabla’
      curl $ical -u$user:$pw > $dir’MYical.ics’
        Shampooman
        I found another important information. It’s still very dirty, and everyone who knows how to do something like this will just laugh about me, but I got a working way to import my owncloud calendar. I just changed the directory to /home/pi/MagicMirror/modules/default/calendar/public
        and added the following to the config.js:
                                                    symbol: 'calendar-check-o ',
                                                    url: 'http://127.0.0.1:8080/calendar/MYical.ics'
        this is my bash script now:
        #!/bin/bash
        ical='http://ownclouddomain.de/remote.php/caldav/calendars/admin/blubb?export’
        dir=/home/pi/MagicMirror/modules/default/calendar/public
        user='admin’
        pw=‘blablabla’
        so you only have to make a cronjob now, which starts the bash script.
        I hope this helps someone, even if it is very, very dirty… :)
          paviro
          Why not do username:password@yourdomain.com in the config?
          – The Doctor
            Shampooman @paviro
            @paviro said in OwnCloud integration:
            because it doesn’t work. :) I got this Error in the console:
            logger.js:23 Calendar Error. Could not fetch calendar: user:password@myowncloud.de/remote.php/caldav/calendars/user/calendar?export
              paviro
              Can you try executing curl -L http://user:password@myowncloud.de/remote.php/caldav/calendars/user/calendar?export in a shell?
              – The Doctor
                Shampooman
                hmmm… that works…
                  Shampooman
                  ok, now it works completly. Perhaps I had a mistake inside my code. Thank you for your help!
                    charliwest
                    @Shampooman do you have this publicly anywhere? I have a bash script that does something I want an MMM to do but have no idea how to get it working and it looks to me thats what you are doing.
                      A Former User
                      I can make the curl call work, adding a -k to it, to get around the certificate.
                      Can I do something similar in the module ?
                      Thanks.
                        raymonvdm
                        I`m using NextCloud and i figured it out using the following config
                                            header: "username",
                                                     symbol: "calendar-check-o ",
                                                     url: "https://username:app_password@nexctcloud.domain.nl/remote.php/dav/calendars/username/8a757113-03ae-4d7a-a6a1-8db4350eee54_shared_by_username?export"
                        I got the calander name from the webinterface by clicking on the dots right behind the specific calender.
                        Note: I am using a dedicated user to login to nextcloud. This user is recieving the “shared” calanders from the actual users. In this way i don`t need to login with my own nextcloud credentials
