Error when trying to start with PM2
Just installed MM2 with PM2 and I can’t start it with PM2. I Get the following error.
/usr/lib/node_modules/pm2/node_modules/semver/semver.js:141 var XRANGEPLAIN = R/;; ^ SyntaxError: Unexpected token ; at new Script (vm.js:51:7) at createScript (vm.js:136:10) at Object.runInThisContext (vm.js:197:10) at Module._compile (internal/modules/cjs/loader.js:618:28) at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10) at Module.load (internal/modules/cjs/loader.js:566:32) at tryModuleLoad (internal/modules/cjs/loader.js:506:12) at Function.Module._load (internal/modules/cjs/loader.js:498:3) at Module.require (internal/modules/cjs/loader.js:598:17) at require (internal/modules/cjs/helpers.js:11:18) -
I just tried to run serveronly mode and get this error.
pi@raspberrypi:~/MagicMirror $ node serveronly /home/pi/MagicMirror/node_modules/escape-html/index.js:14 Var ma�chHtmlRegExp = /[#'&<>]/; ^^ SyntaxError: Unexpected identifier at new Script (vm.js:51:7) at createScript (vm.js:136:10) at Object.runInThisContext (vm.js:197:10) at Module._compile (internal/modules/cjs/loader.js:618:28) at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10) at Module.load (internal/modules/cjs/loader.js:566:32) at tryModuleLoad (internal/modules/cjs/loader.js:506:12) at Function.Module._load (internal/modules/cjs/loader.js:498:3) at Module.require (internal/modules/cjs/loader.js:598:17) at require (internal/modules/cjs/helpers.js:11:18)
