    Installing USB Soundcard using seperate USB Mic
    12 Posts 3 Posters 8.1k Views 3 Watching
    • E Offline
      E3V3A @MrCoffee
      @mrcoffee
      I have seen solutions to this here: https://raspberrypi.stackexchange.com
      search there.
      Also, only use ONE sound card for AUX (ouput) and MIC (input). Otherwise you will get confused and so your Pie will be unhappy too. It is also highly recommended to disable the internal broadcom sound card when using a USB card. That you can do in the boot config IIRC.
      "Everything I do (here) is for free – altruism is the way!"
      MrCoffeeM 1 Reply Last reply Reply Quote 0
      • MrCoffeeM Offline
        MrCoffee @E3V3A
        @e3v3a
        Now it is getting weired.
        I disabled the internal broadcom by adding it to the blacklist:
        sudo tee /etc/modprobe.d/blacklist-snd_bcm2835.conf
        blacklist snd_bcm2835
        After reboot it is correctly not shown again:
        aplay -l
        **** Liste der Hardware-Geräte (PLAYBACK) ****
        Karte 0: Device_1 [USB Audio Device], Gerät 0: USB Audio [USB Audio]
          Sub-Geräte: 1/1
          Sub-Gerät #0: subdevice #0
        But if I start playing a media, the sound still comes from the audio jack.
        How can that be?
        • E Offline
          E3V3A
          dtparam=audio=off
          MrCoffeeM 2 Replies Last reply Reply Quote 0
          • MrCoffeeM Offline
            MrCoffee @E3V3A
            @e3v3a
            Thanks for the help.
            I didn´t tried it yet because meanwhile my mic has some problems too. The “beep” from Alexa ist still there but sounds already not round. After that the mic does not react at all.
            Guess I will reset the whole system. Unfortunately I did not have a backup.
            By the way: If anybody of you knows a raspberry backup programm which I can use under windows please let me know.
            I will inform you when I reseted my system.
            • E Offline
              E3V3A
              @MrCoffee I don’t think resetting it is gonna be helpful, unless you know you have installed a bunch of other apt packages, and messed with system settings without writing down what you did.
              • E Offline
                E3V3A @MrCoffee
                @mrcoffee
                Try this: https://github.com/shivasiddharth/GassistPi/tree/master/audio-drivers/USB-MIC-JACK/scripts
                • MrCoffeeM Offline
                  MrCoffee @E3V3A
                  @E3V3A
                  Hi, I tried the steps from “cloning” to "sudo /home/pi/GassistPi/audio-drivers/USB-MIC-JACK/scripts/usb-mic-onboard-jack.sh " (I have got Alexa not google assistant;-))
                  The alexa beep sounds normal again, but after that there is silence. And I can still force the beep only once per reboot.
                  • MrCoffeeM Offline
                    MrCoffee @E3V3A
                    @e3v3a said in Installing USB Soundcard using seperate USB Mic:
                    dtparam=audio=off
                    I just tried it. Unfortunately with no luck.
                    Sound still comes from the audio jack.
                    • MrCoffeeM Offline
                      MrCoffee
                      I reinstalled the whole system using another SD-card.
                      Now I can use the seperate USB-Mic and the audio Out comes from the other USB-Soundcard.
                      After that I installed all my modules like MMM-Podcast.
                      I played the video and … sound comes from the audio jack again:-(
                      However the usb mic and alexa are still working fine. It is just MMM-Podcast which uses the audio jack.
                      How can that be? I installed the dependecies especially the omxplayer. But that can´t be the reason, or what do you think?
                      lsusb
                      Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
                      Bus 001 Device 005: ID 0d8c:0014 C-Media Electronics, Inc.
                      Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
                      Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
                      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                      aplay -l
                        Sub-Geräte: 1/1
                      sudo nano ~/.asoundrc
                      pcm.!default {
                          type asym
                          playback.pcm "plughw:0"
                          capture.pcm  "plughw:1"
                      ctl.!default {
                              type hw
                              card 0
                      Do you have an idea? Seems like I am almost there.
                      Thanks.
