    Installing USB Soundcard using seperate USB Mic
    12 Posts 3 Posters 8.1k Views 3 Watching
    • MrCoffeeM Offline
      MrCoffee @NoNameRo
      @NoNameRo
      Thank you for your fast response.
      Unfortunately it is still not working. I tried both versions and restarted with the command you told me.
      I even rebootet just to be sure.
      What I didnt do is switching the cable from jack to the usb soundcard, because it is late and the mirror on the wall again. But I expect, that it would be mute if it works, right?
      I forgot to write above, that I can see all 3 devices in the alsamixer.
      • E Offline
        E3V3A @MrCoffee
        @mrcoffee
        I have seen solutions to this here: https://raspberrypi.stackexchange.com
        search there.
        Also, only use ONE sound card for AUX (ouput) and MIC (input). Otherwise you will get confused and so your Pie will be unhappy too. It is also highly recommended to disable the internal broadcom sound card when using a USB card. That you can do in the boot config IIRC.
        "Everything I do (here) is for free – altruism is the way!"
        MrCoffeeM 1 Reply Last reply Reply Quote 0
        • MrCoffeeM Offline
          MrCoffee @E3V3A
          @e3v3a
          Now it is getting weired.
          I disabled the internal broadcom by adding it to the blacklist:
          sudo tee /etc/modprobe.d/blacklist-snd_bcm2835.conf
          blacklist snd_bcm2835
          After reboot it is correctly not shown again:
          aplay -l
          **** Liste der Hardware-Geräte (PLAYBACK) ****
          Karte 0: Device_1 [USB Audio Device], Gerät 0: USB Audio [USB Audio]
            Sub-Geräte: 1/1
            Sub-Gerät #0: subdevice #0
          But if I start playing a media, the sound still comes from the audio jack.
          How can that be?
          • E Offline
            E3V3A
            dtparam=audio=off
            MrCoffeeM 2 Replies Last reply Reply Quote 0
            • MrCoffeeM Offline
              MrCoffee @E3V3A
              @e3v3a
              Thanks for the help.
              I didn´t tried it yet because meanwhile my mic has some problems too. The “beep” from Alexa ist still there but sounds already not round. After that the mic does not react at all.
              Guess I will reset the whole system. Unfortunately I did not have a backup.
              By the way: If anybody of you knows a raspberry backup programm which I can use under windows please let me know.
              I will inform you when I reseted my system.
              • E Offline
                E3V3A
                @MrCoffee I don’t think resetting it is gonna be helpful, unless you know you have installed a bunch of other apt packages, and messed with system settings without writing down what you did.
                • E Offline
                  E3V3A @MrCoffee
                  @mrcoffee
                  Try this: https://github.com/shivasiddharth/GassistPi/tree/master/audio-drivers/USB-MIC-JACK/scripts
                  • MrCoffeeM Offline
                    MrCoffee @E3V3A
                    @E3V3A
                    Hi, I tried the steps from “cloning” to "sudo /home/pi/GassistPi/audio-drivers/USB-MIC-JACK/scripts/usb-mic-onboard-jack.sh " (I have got Alexa not google assistant;-))
                    The alexa beep sounds normal again, but after that there is silence. And I can still force the beep only once per reboot.
                    • MrCoffeeM Offline
                      MrCoffee @E3V3A
                      @e3v3a said in Installing USB Soundcard using seperate USB Mic:
                      dtparam=audio=off
                      I just tried it. Unfortunately with no luck.
                      Sound still comes from the audio jack.
                      • MrCoffeeM Offline
                        MrCoffee
                        I reinstalled the whole system using another SD-card.
                        Now I can use the seperate USB-Mic and the audio Out comes from the other USB-Soundcard.
                        After that I installed all my modules like MMM-Podcast.
                        I played the video and … sound comes from the audio jack again:-(
                        However the usb mic and alexa are still working fine. It is just MMM-Podcast which uses the audio jack.
                        How can that be? I installed the dependecies especially the omxplayer. But that can´t be the reason, or what do you think?
                        lsusb
                        Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
                        Bus 001 Device 005: ID 0d8c:0014 C-Media Electronics, Inc.
                        Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
                        Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
                        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                        aplay -l
                          Sub-Geräte: 1/1
                        sudo nano ~/.asoundrc
                        pcm.!default {
                            type asym
                            playback.pcm "plughw:0"
                            capture.pcm  "plughw:1"
                        ctl.!default {
                                type hw
                                card 0
                        Do you have an idea? Seems like I am almost there.
                        Thanks.
